Re: 440 Source Parts Quality
[Re: patosmith]
#1362852
01/01/13 07:51 PM
01/01/13 07:51 PM
Posts: 52,972 Romeo MI
MR_P_BODY
Well a few questions will come into play... are you talking a 10.90 or a 10.0.. next is what weight will you be running at.. being that you playing with a E body and they tend to be heavy you either good HP and torque or you plan on spinning it up... now back to the parts... the cranks are forged in China.. they tend to make their steel on a different scale than US steel so a 4340 steel doesnt always end up being what the specs call out for... but if you use the lower RPM high torque approach and light pistons I dont think you have too much of a problem.... if you go with the revs(which I tend to do) you might have a issue using all their parts.... I went with better parts on my 514 B1 M/C ... I went with a Callies crank but I was gonna spin 9000+.............JMO Either way have all the parts checked by a machinist
[Re: tubtar]
#1362854
01/01/13 08:05 PM
01/01/13 08:05 PM
MR_P_BODY
I had a family member ask the other day at a Christmas party on the quality of the 440 Source rockers he was thinking of buying..... I told him to pass and get some better parts now instead of busting up stuff and buying better parts later.... of course he said this is just a street car and then I replied... how much will it cost when you break them... he said... point taken..... now would I use their rotating assm on a street engine.......... I might... but it better be a cruiser
[Re: patosmith]
#1362859
01/01/13 08:45 PM
01/01/13 08:45 PM
Posts: 6,531 Jacksonville, FL
Chris2581
Jacksonville, FL
I have a set of their Stealth heads and no problems with them.I did change the springs retainers and locks as I went with a cam that was more than the 440 source parts were specified for.
[Re: patosmith]
#1362861
01/01/13 09:33 PM
01/01/13 09:33 PM
Posts: 446 oregon
savoyracer
oregon
3200 pound car, 9.60's in quarters, 6.18 or so in eighth, 7500 rpm shift, lotsa torque, well over 700 passes on 440 source stroker kit. been rebuilt once. use other manufacturers parts for valve train stuff, dampner, rings, bearings, etc. etc. Recommend them?? Yes, take with a grain of salt!!......I have indy heads etc. but I would not hesitate a minute to buy a set of BARE stealth heads if I needed them. Source has helped to hold down prices on mopar related products, EVEN for those that "hate"!!
[Re: savoyracer]
#1362862
01/01/13 09:39 PM
01/01/13 09:39 PM
Posts: 2,866 Pattison Texas
CSK
Pattison Texas
SO who still forges cranks in america?
[Re: savoyracer]
#1362863
01/01/13 09:47 PM
01/01/13 09:47 PM
Posts: 20,186 PA.
pittsburghracer
"Little"John
"Little"John
PA.
I used a 440source rotating assembly in my Daytona ans had over 275 passes on it with the quickest being a 8.60@151 mph. I recently sold that rotating assemble to another Moparts member and it will be going in his car soon. There I beem rods were junk and have been discontinued. The only extra work that was required was I had to fit the piston pin to the rod which I did at home and I was told to do this in their instructions.
[Re: pittsburghracer]
#1362864
01/01/13 10:42 PM
01/01/13 10:42 PM
Posts: 4,384 Worst Weather USA
493_DART
Worst Weather USA
I use their 4.15 stroker kit . Raced it since 07. Somewhere around 400 passes or so. No issues yet. Car has went 6.46 in the 1/8 . I can post some pics of broken rods and cranks from Eagle , Manley , Scat , etc..... does that make those brands all junk ??? whatever brand you use--have it all thourougly checked by a machinist and assemble it yourself making sure to carefully double check everything . Works for me
