bracket master 2 cams for a 413 opinions
#1362782
01/01/13 04:18 PM
01/01/13 04:18 PM
Posts: 3,696 jersey
Spaceman Spiff
jersey
should have asked before i ordered. replacing the thumpr cam in the wagon 413, stock 906 heads, rpm intake, 850 holley vacuum secondary. ( .486/.473 279/296 108lsa) with a bracket master 2
.480/.480 292 adv dur. 109lsa.
car has a 2600stall and 3.23's. car is a dog with this thumpr cam, of the line, on the hiway, it just sucks. i realize thew 3.23's probably aren't helping, but it was that or the 4.10's, and i've put almost 10,000 miles on the car in 8 months of time.
Would the bracket master be a good choice for this combo, even with the 3.23's? I'sd prefer not to go more than 3.91's, and even that's a lil much. as most rides are 2 hour jaunts.
526 cubes of angry wedge, pushbutton shifted, 9 passenger killer!
Re: bracket master 2 cams for a 413 opinions
[Re: Spaceman Spiff]
#1362784
01/01/13 06:20 PM
01/01/13 06:20 PM
Posts: 3,916 usa
lewtot184
usa
the 906 heads by themselves will probably knock the compression down to low 9's. if your using a fel-pro type gasket that might get you below 9:1 compression. the 850 carb may be a little large, added with low compression, and maybe a little too much cam, and negatives can stack up. you may also have a fuel delivery issue if your using a stock type mech pump. i'd re-think the whole combo.
#1362786
01/01/13 09:08 PM
01/01/13 09:08 PM
Posts: 5,746 Ontario, Canada
Dodgem
Ontario, Canada
I bet it was improperly installed. degreeing a cam is a must! need the @.050 numbers for both cams
#1362787
01/01/13 09:16 PM
01/01/13 09:16 PM
Dodgem
Ontario, Canada
2,000-5,800 Intake Duration at 050 inch Lift:227 Exhaust Duration at 050 inch Lift:241 Duration at 050 inch Lift:227 int./241 exh. Advertised Intake Duration:279 Advertised Exhaust Duration:296 Advertised Duration:279 int./296 exh. That cam should be fine I would install it at 101 or 102 mechanical advance 38 all in by 1800 and make sure the vacuum advance is on ported vacuum plugged and disconnected for initial set up and later when all is right on ported vacuum only it has a set up all it's own later to tune out any ping at light throttle accleration.
[Re: Dodgem]
#1362788
01/02/13 02:28 AM
01/02/13 02:28 AM
Posts: 625 Oakville, Wa
HOTMOPR
Oakville, Wa
I am running the comp extreme hydraulic in my 413 with big valve 906s and a 750 vac. I havent got it out much yet because of the snow but she sure sounds sweet! 3" exhaust and flowmasters.. http://www.summitracing.com/parts/cca-21-228-4/overview/
67 Barracuda, 470" B, Glide, FuelTech FT600, Precision, Ptc, QA1, Calvert, Smith racecraft, Afco, Dana 60. 275 radials
[Re: HOTMOPR]
#1362789
01/02/13 10:12 AM
01/02/13 10:12 AM
Dodgem
Ontario, Canada
Yea gotta love 3" exhaust but you don't have to love flowmasters Im a Dynomax 3" welded kinda guy! The 750 is a good pick for a carb on a combo like that. Degreeing the cams is SO IMPORTANT anyone who has had a sour taste in there moth from a cam almost always had it in retarded with the dots lined up when most like a couple extra degree of advance to be real happy. Seen two new Mancini brand 3 bolt 3 keyways in the straight up position 6 retarted that makes for dogs. look like they are Chinese made.
[Re: Dodgem]
#1362790
01/02/13 10:25 AM
01/02/13 10:25 AM
Posts: 12,675 Columbia, CT
moper
Columbia, CT
I'm no fan of the Thumper line. Buying a cam for sound is like buying a pair of Converse All Stars to play golf in because you wore them when you were younger. You're over cammed and over carbed. I'd step down to something in the 220° @ .050 range and with lift in the .480-.490 area and you'll be much happier. I also agree that degreeing any new camshaft is a must.
