That seems to small for stock jetting
There normally around 10 to 13 thousands (.010 to.013)smaller on the hole size on the secondary jets stock. I would put a .086 jet in both sides and see how that works, if you like it try a .089 and on up until it quits making more power. Is your intake manifold stock? If so what casting number is it? I'm not sure when Mopar went to the bigger Carter AVS on the Hi-Po 440 magnum motors, I thought it was 1967
Are your primary butterflys the same size aas the secondarys ones? If not it may not be the correct carb. for your motor
I have some old Carter catalogs, I'll look in them and see if I can find your carb. # and the stock jetting for it, if so I'll add it onto here later this morning
Edited, no luck on the jet sizes, sorry
