Can someone explain...(I'm an idiot) #136255
10/14/08 02:34 PM
10/14/08 02:34 PM
The New Jersey Hinterlands
Sssnake383 Offline OP
Old and boring
Old and boring
...in simple terms how the Mopar points-style ignition system works? My particular vehicle is a 1969 Plymouth Road Runner with a 383. It does not start. It cranks enthusiastically. Plenty of fuel. The starter relay on the firewall is good. I don't seem to have any spark at the coil. Is this as easy as replacing the coil, or could it be the ballast resistor or something else? Please help!
Re: Can someone explain...(I'm an idiot) [Re: Sssnake383] #136256
10/14/08 02:47 PM
10/14/08 02:47 PM
Andrewh Offline
Andrewh  Offline
well first, what changed?
Did it run fine, then die?
First time you tried to start it in 30 years?
Second did you check for voltage at the ballast resistor, coil?
Re: Can someone explain...(I'm an idiot) [Re: Sssnake383] #136257
10/14/08 02:49 PM
10/14/08 02:49 PM
scratchnfotraction Offline
yes the ballist res could be bad
coil could be bad
I used the pertronix unit that replaces the points and have not had to change the pertronix rotor yet,just a new cap now and then
I guted the porcilin shell of a ballest res and solderd the ends on a piece of #10 stranded wire to hind the fact it was bypassed
you by pass it to give the pertronix the full 12 volts and it has lots of fire with the 40,000 volt pertronix coil
easy hook up red to + and black to - side of coil with the one key wire that is on the coil now with you points
this was on the 68 Dart,another good upgrade is one of the newer soild state voltage regulaters,it was way better and the lights did not go dim when at idle and lights on
I tell you this cause I changed points for 2yrs every 2-3 months with that old car till I replaced it
now I have had that same set up in 3 diff cars and 9 yrs with out ever a problem
Re: Can someone explain...(I'm an idiot) [Re: Sssnake383] #136258
10/14/08 02:51 PM
10/14/08 02:51 PM
Eighty Four, PA
B G Racing Offline
B G Racing  Offline
Eighty Four, PA
It's a very simple system to trouble shoot.If it has a balast resistor,see if you have voltage on both sides,if only on one side put a jumper wire across it(bypass).If you dont have any power to it the problem can be at the ignition switch or the starter relay,also check for a fuseable link in the hot wire running from the battery post.You can bypass everything and run a hot wire from the battery to the coil.If you still don't have power to the points replace the coil,and if you still don't have power replace the condenser and points.Make sure that your points are set correctly-.015-.017 gap or 28-32 degrees dwell.
Re: Can someone explain...(I'm an idiot) [Re: Andrewh] #136259
10/14/08 02:54 PM
10/14/08 02:54 PM
Old and boring
Old and boring
Well, the car is a fair-weather driver. Hasn't moved much in the past few months, but I try to start it every month or 6-weeks or so to keep the juices flowing. It was a tough start last time, and now it won't start at all, just extended cranking. I have not checked voltage at the ballast resistor or coil. I do have a digital multimeter, though. What voltage values am I checking for?
Thanks for your quick response.
Re: Can someone explain...(I'm an idiot) [Re: scratchnfotraction] #136260
10/14/08 02:59 PM
10/14/08 02:59 PM
Old and boring
Old and boring
Thanks for your response. I actually have the Pertronix system (and have had it for about 4 or 5 years), but have yet to install it. I guess this is the kick in the butt I needed in order to put it in...but now that the car won't start on points, I'd like to fix that first and then move forward with the Pertronix. It's on the list of things to do!
Re: Can someone explain...(I'm an idiot) [Re: B G Racing] #136261
10/14/08 03:07 PM
10/14/08 03:07 PM
Old and boring
Old and boring
Hello and thanks for your reply. I am running the OE ballast resistor. So I should measure power on both sides of the resistor...and if it only shows up on one side, then I should jumper it to see if it starts? You are saying that if power doesn't show up at all at the resistor my problem lies with the starter relay (I just replaced this part) or with the ignition switch in the dash? If the resistor tests okay is the coil the problem? Won't I burn up my points if I wire 12v directly from the battery to the coil?
Sorry about all the questions. I just want to make sure I know what I am doing (for once). Thank you for your help.
Re: Can someone explain...(I'm an idiot) [Re: Sssnake383] #136262
10/14/08 03:11 PM
10/14/08 03:11 PM
Andrewh Offline
Andrewh  Offline
Well, by putting in the petronix, you eliminate 2 out of 4 things being bad.
Basically you take out points and the balast being your problem.
The two remaining are the coil and power, which breaks down to two things.
You have key on power in run. That should read 12 volts on one side and around 8 volts on the other of the ballast.
You also have start power which should bypass the ballast and read 12 volts on the coil side when you are turning the key to start the car.
So if you put in the petronix, and the car still doesn't start, then all you have to check is voltage. If there is voltage, then you have a bad coil.
If you try to fix the points, then you have to verify the points aren't burnt out.
That they gap is set correctly, then figure out if the coil or ballast is dead.
Assuming you have voltage at both run and start.
Re: Can someone explain...(I'm an idiot) [Re: Andrewh] #136263
10/14/08 03:12 PM
10/14/08 03:12 PM
Andrewh Offline
Andrewh  Offline
well if you left it like that running a full 12 volts all the time, then yes you could burn up the points and coil.
But the car bypasses it when you start the car normally.
If you don't have power, it could be the switch, or the bulkhead connector.
Not the starter relay.
Re: Can someone explain...(I'm an idiot) [Re: Andrewh] #136264
10/14/08 03:23 PM
10/14/08 03:23 PM
Old and boring
Old and boring
I don't want to compound my problems. I would like to fix the points, that way - if I screw up installing the Pertronix - at least I know where to start. Thank you for explaining what to test for at the resistor. I will try that tonight, hopefully. So, if the ballast checks good with KEY ON run 12v incoming and about 8v outgoing, the next thing to check is voltage at the coil with the key on start. I'm looking for 12v at the coil? If then I take the cap off and check out the points and they look good (no pitting or blackened areas), what next? Condemn the ignition coil?
Thanks for your help. I am feeling a bit better about tackling this.
Re: Can someone explain...(I'm an idiot) [Re: Andrewh] #136265
10/14/08 03:29 PM
10/14/08 03:29 PM
Old and boring
Old and boring
I think I am confused, what do you mean if I don't have power? Are you stating that if I don't have power at the ballast resistor then my problem rests with the ignition switch (in the dash) or the firewall bulkhead?
Again, thank you. I am usually not so, errr, slow, I promise.
Re: Can someone explain...(I'm an idiot) [Re: Sssnake383] #136266
10/14/08 03:30 PM
10/14/08 03:30 PM
Rio Linda, CA
John_Kunkel Online content
John_Kunkel  Online Content
Rio Linda, CA
The "key on" voltage check won't tell you much because the normal RUN circuit is shut off during the start cycle.
On your ballast you will find a double blue wire on one side and a blue/brown on the opposite side. The double blue should have battery voltage only when the key is in the RUN position and the blue/brown should have battery voltage only when the key is in the START position.
Re: Can someone explain...(I'm an idiot) [Re: Sssnake383] #136267
10/14/08 03:31 PM
10/14/08 03:31 PM
Andrewh Offline
Andrewh  Offline
Nope can't say it is the coil yet.
You can check the cap and rotor next, and just for kiss, make sure the rotor spins when trying to start the car. Have heard of that, but not seen it. The cap and rotor would only stop or inhibit some firing. Like a miss. Unless it was cracked or the top was missing, you should still get spark.
You can check for spark at the coil to be sure.
Pull the coil wire instead of a plug wire.
Next up look at the points themselves. Make sure they are opening and closing and the ends are not gone. Though honestly the petronix conversion is so simple, it really took me 15 min to do, I would do that. But if you are stuck on trouble shooting points thats fine.
If the points are not burned away, and are opening and closing, and the distributer is turning, then I would try replacing the coil first.
Re: Can someone explain...(I'm an idiot) [Re: Andrewh] #136268
10/14/08 03:34 PM
10/14/08 03:34 PM
Andrewh Offline
Andrewh  Offline
Yes. If you don't have power at the coil, it could be the ignition switch or a bad connector in the bulkhead connector.
John is correct, that won't test power in start, and does lead to the assumption it isn't the ballast resistor since it is bypassed in start.
Re: Can someone explain...(I'm an idiot) [Re: John_Kunkel] #136269
10/14/08 03:43 PM
10/14/08 03:43 PM
Old and boring
Old and boring
This is different then what I just read from the other posters. So, how do I go about checking the ballast? Just see if voltage exists on the double blue wire side when key is on RUN position...and then verify voltage on the blue/brown wire side with key in START position?
I am getting confused again...
Re: Can someone explain...(I'm an idiot) [Re: Sssnake383] #136270
10/14/08 03:52 PM
10/14/08 03:52 PM
Andrewh Offline
Andrewh  Offline
we are saying the same thing. John just pointed out something I forgot.
If you test in run, you should get the voltages I described.
But you are not really testing the problem.
Since your car won't start, you need to verify voltage in START, while the car is cranking over.
The coil side then should read 12 volts.
This is actually bypassing your balast resistor, so it has nothing to do with your no start problem.
Re: Can someone explain...(I'm an idiot) [Re: Andrewh] #136271
10/14/08 04:07 PM
10/14/08 04:07 PM
Old and boring
Old and boring
OKAY, I see what you guys are saying. So the ballast resistor is not my problem, because the START circuit bypasses it. The RUN circuit uses the ballast to step down voltage so it won't burn up my points. The coil side (of the ballast) needs to read 12v with the key in the START position (car is cranking). Do I have the idea? If the coil side measures 12v (and points check out) then out comes the coil. If the coil side does NOT read 12v, then my problem is...ignition switch or firewall bulkhead. Is this correct?
Re: Can someone explain...(I'm an idiot) [Re: B G Racing] #136272
10/14/08 04:16 PM
10/14/08 04:16 PM
So Cal
HealthServices Offline
Why would you even post that?
So Cal
It's a very simple system to trouble shoot.Make sure that your points are set correctly-.015-.017 gap or 28-32 degrees dwell.
If you have power to the coil This is the first thing you should Check. Your car ran acouple weeks ago. Most common problem is the point gap has changed.
Reset that gap.
Allen Here's a novel idea, let's not throw a bunch of parts at the car hoping it will fix the problem and instead spend a little time diagnosing it first. Life was a little easier when I was just a wrench.
Re: Can someone explain...(I'm an idiot) [Re: HealthServices] #136273
10/14/08 04:25 PM
10/14/08 04:25 PM
Old and boring
Old and boring
Thank you, HealthServices. Check for 12v at the coil (or at the coil side of the ballast?) while key on START. If yes, check and if necessary re-gap points. That is the order in which I will proceed, I think. It is a cast-iron Mopar dual-point distributor currently in the car. Would not point gap have to be WAY off (or points just destroyed) to not even receive a hiccup while starting?
Thank you for the assistance. At least I have some ideas for when I attack the problem.
Re: Can someone explain...(I'm an idiot) [Re: Sssnake383] #136274
10/14/08 04:29 PM
10/14/08 04:29 PM
Andrewh Offline
Andrewh  Offline
not really. I have had points almost completly gone and the car still ran.
I have had a set that looked new and the gap looked right on to me, but would not start because of a .01 gap difference.
You can't see that.
That is why I switched to petronix as well.
You could also have a worn out distributer where it won't hold the gap. But that is an exception rather than the rule.
