Door lock cylinders frozen. How do I unstick them? #1362571
01/01/13 02:58 AM
01/01/13 02:58 AM
Santa Rosa CA
Bones Offline OP
Bones  Offline OP
Santa Rosa CA
My 1972 Demon has been sitting for so long that when I went to get in it the other day I could not get the door locks to turn with the key. They won't budge. Does anyone know how to remedy this problem. I really need to get in my car and get it running again.
Do not hug a man holding a wrench in his hand.
Re: Door lock cylinders frozen. How do I unstick them? [Re: Bones] #1362572
01/01/13 03:06 AM
01/01/13 03:06 AM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
How long has it been sitting? Are you sure your using the right keys? Santa Rosa isn't exactly the rust belt..... Try some dry graphite, if you don't have that try penetrating oil...
Re: Door lock cylinders frozen. How do I unstick them? [Re: 1_WILD_RT] #1362573
01/01/13 03:17 AM
01/01/13 03:17 AM
Pangaea
B5 Bee Offline
B5 Bee  Offline
Pangaea
Besides my occasionally used auto door locks, I have the same problem with seldom used home door locks.
You may be able to get them to turn with regular lubricating oil. If you use a penetrating oil first, once loose, give them a shot of lubricating oil. I've been using PB50 lubricant, same company that makes PB Blaster penetrant.
BTW, WD40 is not a good penetrant or lubricant, use something better for both needs.
Re: Door lock cylinders frozen. How do I unstick them? [Re: Bones] #1362574
01/01/13 03:50 AM
01/01/13 03:50 AM
get inside with a slim jim then take out the lock cyl. The ones with the chrome removeable covers you can open em up & clean the mini tumblers/spacers/springs. Lube it with powered graphite. On a side note with some spare cyls you can mix/match em so all your cars use the same key (even the trunk) & you can even leave a hole or 2 in the cyl blank, nobody picks locks anymore (except in the movies)
Re: Door lock cylinders frozen. How do I unstick them? [Re: RapidRobert] #1362575
01/01/13 11:31 AM
01/01/13 11:31 AM
Philadelphia
radar Offline
radar  Offline
Philadelphia
Locks only keep the honest people out!
Re: Door lock cylinders frozen. How do I unstick them? [Re: Bones] #1362576
01/01/13 05:07 PM
01/01/13 05:07 PM
Santa Rosa CA
Bones Offline OP
Bones  Offline OP
Santa Rosa CA
I'll try squirting some penetrating oil in there first and if that doesn't work maybe just slim-jim it open. I've never used a slim-jim before, how hard are they to use? Also, if the locks are stuck won't they still be stuck even if I use a slim jim?
Re: Door lock cylinders frozen. How do I unstick them? [Re: B5 Bee] #1362577
01/01/13 06:44 PM
01/01/13 06:44 PM
Kirkland, Washington
Pacnorthcuda Online boogie
Pacnorthcuda  Online Boogie
Actually WD40 is great for frozen door locks . "WD" stands for "water displacing" it literally moves it out of the way.
Re: Door lock cylinders frozen. How do I unstick them? [Re: Bones] #1362578
01/01/13 07:29 PM
01/01/13 07:29 PM
Northern Indiana
Dunnuck Racing Offline
Northern Indiana
A locksmith I know told me the best thing for his business/ worst thing to lubricate locks with is graphite. It clumps up when it gets damp and makes things worse. WD40 works well as said,it displaces moisture . You do need to reapply it occasionally.
On A side note,the best penetrating oil and lubricant I have found is made by Marvel Mystery Oil. Hard to find around here though.
Keith
Re: Door lock cylinders frozen. How do I unstick them? [Re: Bones] #1362579
01/01/13 07:40 PM
01/01/13 07:40 PM
Fitchburg,Massachusetts
MPerry Offline
Mopahts memba'
MPerry  Offline
Mopahts memba'
spray some penetrant in then stick the key in and lightly tap on the end with a rubber mallet(or the handle end of a screw driver)
It will help loosen the pellet waffers in the lock
Re: Door lock cylinders frozen. How do I unstick them? [Re: Dunnuck Racing] #1362580
01/01/13 08:00 PM
01/01/13 08:00 PM
S.E.Mich
drew72 Offline
drew72  Offline
S.E.Mich
That's interesting. My locksmith says just the opposite. A lube attracts dirt and hinders the movement of the pins.
Re: Door lock cylinders frozen. How do I unstick them? [Re: MPerry] #1362581
01/01/13 08:41 PM
01/01/13 08:41 PM
Athens, Greece
Pyper70 Offline
Pyper70  Offline
Athens, Greece
is it rusted? Are the temps really really cold? Will putting your keys through a flame aid in the loosening of the cylinders?
I have found Liquid Wrench works better than WD40 when temperature is a factor
Family owned 1969 Charger R/T DualQuad 440/727/GVO/3.55s
Re: Door lock cylinders frozen. How do I unstick them? [Re: Pacnorthcuda] #1362582
01/01/13 09:44 PM
01/01/13 09:44 PM
Pangaea
B5 Bee Offline
B5 Bee  Offline
Pangaea
He's in CA, I think he means frozen from corrosion, not ice/water.
