rear seals and bearings #1362253
12/31/12 01:26 PM
12/31/12 01:26 PM
Oconto wi
tillysuperbee Offline OP
Oconto wi
wheres the best place to buy rear seals amd outer bearings for my 83/4 ? the chunk was out and it was rolled in and out of a trailer a few times and im thinking id be safe than sorry and replace them before i put it back togather thanks
Re: rear seals and bearings [Re: tillysuperbee] #1362254
12/31/12 02:57 PM
12/31/12 02:57 PM
Upper Midwest
MoparforLife Offline
Upper Midwest
Replace the inner axle seals, clean and inspect the bearings, repack with a good quality axle grease, reinstall and adjust the end play and go with it.
Re: rear seals and bearings [Re: MoparforLife] #1362255
01/01/13 01:28 PM
01/01/13 01:28 PM
Oconto wi
Oconto wi
Thanks, I was thinking so but was wanting the reassurance
Re: rear seals and bearings [Re: tillysuperbee] #1362256
01/01/13 03:51 PM
01/01/13 03:51 PM
Raleigh, NC
Meangreen68 Offline
Meangreen68  Offline
Raleigh, NC
Before you tap the axle seal into the housing ends, put a light coat of Permatex into its bore.
Soon after the first time I ever R&R'd axle bearings, I needed to pull one of the axles to replace the left-hand studs. It was then I noticed gear-fluid had crept from around the outer perimeter of the seal.
Maybe I didn't install it correctly but I would think, Sure-Grip additive shouldn't find its way into axle bearings.
Re: rear seals and bearings [Re: Meangreen68] #1362257
01/01/13 04:04 PM
01/01/13 04:04 PM
Puyallup, WA
StealthWedge67 Offline
Puyallup, WA
Although not necessary...... As long as you have it apart, now would be the time to install a set of sealed (green) bearings, and lose the end-play adjustment.
Re: rear seals and bearings [Re: StealthWedge67] #1362258
01/01/13 05:02 PM
01/01/13 05:02 PM
md
mopars4ever Offline
mopars4ever  Offline
md
That`s why I use the mopar seal. It has a rubber like coating on the outside and the aftermarket doesn`t.
Re: rear seals and bearings [Re: StealthWedge67] #1362259
01/01/13 09:07 PM
01/01/13 09:07 PM
scratchnfotraction Offline
I went greens and never had to look back. I dont run the axle tube seals either. the O-ring on the green bearing seals up fine. (I just had it apart today for a gear change.)
although the endplay adjustment is not hard and only takes mins,it is just oneless thing for me to have to do when in a hurry on a gear swap. bolt and play.
either way you go,member DrDiff can fix you up with any of the things you need for the 8 3/4/seals and has the best deal on green bearing kits.
Re: rear seals and bearings [Re: scratchnfotraction] #1362260
01/02/13 02:47 PM
01/02/13 02:47 PM
Oconto wi
Oconto wi
thanks for the help i called drdiff but hes out till the 8th so i will wait cuz i did have a leak on the right side years back after i put it togather
