Any heads up classes that limit camshaft lift?
#1362135
12/31/12 01:07 AM
12/31/12 01:07 AM
Posts: 984 San Diego CA
65 Hemi
San Diego CA
Any heads up classes that limit camshaft lift or cylinder pressure? I think it would be cool to see a class that has a max lift of .600 and use some of the other rules that they already have in other classes.
Doug
MOPAR or NO CAR!!! 1965 Dodge Coronet soon a 6.1 Hemi with a Magnson blower 810 hp on pump gas 1964 Dodge Polara 582" Indy alum Block 426-1RA heads, 1933 Plymouth PE all Steel, LT1 4L60E 1959 Plymouth Savoy 33,000 mile survivor Old cars are never done. They are ongoing projects!
Re: Any heads up classes that limit camshaft lift?
[Re: 65 Hemi]
#1362136
12/31/12 01:49 AM
12/31/12 01:49 AM
Posts: 3,978 Hilltown Pa
1967dartgt
Hilltown Pa
Yes renagade in nmra have to use a hyd roller. They have figured out on a spintron how to make that cam much bigger then it is. They run bottom 8s with blowers on serp belts, so any heads up class will get out of hand with money.
Brett Miller W9 cnc'd heads STR Chassis fabraction
[Re: 65 Hemi]
#1362137
12/31/12 09:13 AM
12/31/12 09:13 AM
Posts: 1,313 Charlotte, NC
LSP
Charlotte, NC
NMCA Mean Street, .550" max lift @ the retainer.
[Re: 65 Hemi]
#1362139
12/31/12 02:40 PM
12/31/12 02:40 PM
Posts: 528 Oak Grove, MN
lowflyingdart
Oak Grove, MN
NHRA Stock and Super Stock.
"I have not failed. I've just found 10,000 ways that won't work."
Thomas A. Edison
[Re: lowflyingdart]
#1362143
01/01/13 07:56 AM
01/01/13 07:56 AM
LSP
Charlotte, NC
Dont think there is a lift limit in Super Stock...Stockers yes.
Correct me if I'm wrong, but NHRA stock classes run off an index, not heads up (unless you're up against a car in the same index).
Both statements are correct.
Only heads up if in the very same class.
