fresh 383 build wont start #1361989
12/30/12 11:33 PM
12/30/12 11:33 PM
NC
Tommy383 Offline OP
Tommy383  Offline OP
NC
my dad and i just cranked our 383 in the duster. motor freshly rebuilt. everything new. we are getting plenty of fuel, and the dist is getting spark. we are getting backfires through the headers, and no firing. we messed around with the distributor a bit to make sure it wasnt a minor timing adjustment, and still nothing. we swapped the wires 180 degrees and got backfire through the carb. any input appreciated.
Re: fresh 383 build wont start [Re: Tommy383] #1361990
12/30/12 11:44 PM
12/30/12 11:44 PM
N
NITROUSN Offline
NITROUSN  Offline
N
Pull number one plug. Bump the starter so number one is on the compression stroke. Line up the timing marks at tdc. Look were the rotor is and get the dist, in the right place and verify the firing order at its correct rotation. A fresh motor that does not fire right off is a good candidate for a wiped cam lobe.
Re: fresh 383 build wont start [Re: Tommy383] #1361991
12/30/12 11:45 PM
12/30/12 11:45 PM
MYRTLE BEACH SOUTH CAROLINA
E
ek3 Offline
ek3  Offline
E
PULL THE DIST. SET # 1 CYL @ TDC.ON COMPRESSION STROKE .( WHEN BUMPING ENGINE OVER WITH # 1 PLUG OUT AND A FINGR COVERING THE HOLE, OR BOTH VALVES CLOSED at TDC. ) THEN INSTALL DIST WITH ROTOR POINTING TO #5 CYL AND SLIDE IT IN .ROTOR SHOULD BE PONITING TO APPROX # 1 PLUG WHEN DROPPED ALL THE WAY IN. ROUTE WIRES IN ORDER FROM POST ON THE CAP WHERE ROTOR IS POINTING. SOUNDS LIKE TIMING IS OUT 180*. ADVANCING THE TIMING WILL HELP IT START ,IF ITS RETARDED TO MUCH IT WILL BE HARD TO CRANK>
Re: fresh 383 build wont start [Re: Tommy383] #1361992
12/30/12 11:48 PM
12/30/12 11:48 PM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
1 8 4 3 6 5 7 2 Counter Clockwise rotation.. Bring #1 up to TDC on the compression stroke & see were the rotor is pointing.... It should point to #1 located like the picture below...
As mentioned A fresh motor that does not fire right off is a good candidate for a wiped cam lobe
Re: fresh 383 build wont start [Re: 1_WILD_RT] #1361993
12/31/12 12:33 AM
12/31/12 12:33 AM
pull the plugs & bump it at the starter relay till you feel psi start to build significantly on your thumb over the #1 plug hole (front drivers side) then hand turn it some more with a 1&1/4" socket/breaker bar till the timing marks are at 10BTDC if a mild cam or 15BTDC if a wild cam. Turn the dist housing till the magnet is dead even with the tooth that places the #1 dist cap terminal over or nearly over the rotor with the vac can in its' correct general location with room to be turned either way. As said check that the wires are routed 1-8-4-3-6-5-7-2 CCW from that point & you can reroute the wires if needed but keeping the OE #1 wire location is highly recommended for standardization & preventing future mixups & lets the wires nestle neatly with the shortest lengths possible and you can reclock the intergear if need be so #1 is where you want it rather than relocating the wires if you want to do it that way & sometimes different dizzys are phased different between the bottom tang orientation and the rotor clocking & the intergear needs to be lifted up & rotated as having the intergear slot parallel as the book says does not always work. Pull the intake & regoop the cam. You have alot of money and time in this & cam issues are notorious so no time to skimp now expecially since you are so close. Read "breakin secrets" at www.mototuneusa.com (5 minute read). Make a mark with a white marking pen 2&7/32" clockwise from the OE TDC slit on the dampener which is 35 degrees & when it fires have the guy manning the light turn the dist to get that amt at ~2500 rpm with the vac adv capped. Stat out. Front of car elevated (air pockets). Shop fan in front of rad. Any issues/leaks shut it down ASAP then fix it & restart it continuing with the 20 minute time frame. good luck EDIT when you lined up the tchain/gears dot to dot (6&12 o'clock) #6 is firing not #1 as commonly believed and you would want the rotor under #6 plug wire but the above will take care of it for you. Holler how things go
Re: fresh 383 build wont start [Re: RapidRobert] #1361994
01/06/13 05:27 PM
01/06/13 05:27 PM
NC
Tommy383 Offline OP
Tommy383  Offline OP
NC
ok.
just wrapped up for the day.
we pulled the valve cover and triple checked our timing. we are on the correct stroke and now not getting any backfiring at all.
cam looks fine, its a used mopar 484 from my buddy that upgraded.
we pushed the car out of the carport into the sun, and upon trying to crank, we are seeing gas/air being pushed out of the carb. shouldnt it be getting sucked in like a vacuum? carb is also spitting gas out of the front breather tube. it is a 750 holley that came off my 72 RR, over 2 years ago.
thanks for the replies....hoping to get it running!!!
Re: fresh 383 build wont start [Re: Tommy383] #1361995
01/06/13 06:22 PM
01/06/13 06:22 PM
Needle & seat are flooding. Might pull the assy's out & clean them with a shot of starting fluid or replace them & might be a good idea to pull the bowls & see if it's good inside & that'd let you invert the bowls & with a drill bit set the dry float level dead on when you go back together
Re: fresh 383 build wont start [Re: Tommy383] #1361996
01/06/13 07:37 PM
01/06/13 07:37 PM
New Jersey, USA
Y
yella71 Offline
yella71  Offline
Y
New Jersey, USA
make sure that your push rods aren't to long and holding the valves open. run a comp. test see what you have. seen it before . pushrods too long holding the valves open no compression no start.
71 challenger convertable, 64 sport fury 383 ci with factory air 99 sebring convertable 89 CTD pup
Re: fresh 383 build wont start [Re: RapidRobert] #1361997
01/06/13 08:24 PM
01/06/13 08:24 PM
Marlboro, NY, USA
Rick_Ehrenberg Offline
Marlboro, NY, USA
Man, between all the cranking, and now the fuel wash / dilution, that cam will be on borrowed time from day one, and the rings may not be far behind.
Hope I am wrong. Sorry!
Rick
Re: fresh 383 build wont start [Re: Rick_Ehrenberg] #1361998
01/07/13 10:13 AM
01/07/13 10:13 AM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
might want to drain the oil and change the filter. At least pull the dip stick and see if it smells like gas. As for used cam...I hope you got the used lifters that went with the cam and they are all in the correct order. That 484 cam isn't going to be easy to dial in. While the carb is apart I'd drop a 4.5pv in it. Also make sure your floats are set. If not it will push fuel up and out of the bowls.
Good luck
Coming soon!!!!
Re: fresh 383 build wont start [Re: Rick_Ehrenberg] #1361999
01/07/13 10:55 AM
01/07/13 10:55 AM
IL
71383beep Offline
71383beep  Offline
IL
Rick
man. That thing is probably handicapped from the start now...
How old is the gas in the tank? With the ethanol based fuels we are being forced to use now I have noticed that if gas sits untreated in a tank for 4-5 months or more it starts to go bad and varnish.
The last few engine builds I did I had to fire the motor by pouring some good gas down the throat of the carb to get her to fire.
I hope yours is not too out of whack, but cranking for a long time on a fresh motor that does not fire is never a good thing.
'73 GK6 Challenger Rallye - 340 4-Speed
Re: fresh 383 build wont start [Re: 71383beep] #1362000
01/08/13 12:17 AM
01/08/13 12:17 AM
NC
Tommy383 Offline OP
Tommy383  Offline OP
NC
i have not cranked it more than necessary. wednesday i am pulling off the timing cover to check the timing chain. have a feeling it is not properly set. checking pushrods, etc too for any damage. gas is fresh high test, so i doubt that is it. i will let you know what happens on wednesday,
thanks for all of the replies...hopefully you are wrong about the motor being beat up!!!
Re: fresh 383 build wont start [Re: Tommy383] #1362001
01/08/13 11:57 PM
01/08/13 11:57 PM
NC
Tommy383 Offline OP
Tommy383  Offline OP
NC
Alright, I got off a little early today and decided to get a head start. I was happy to get the front end pulled off without having to remove the radiator/fluid. The crank sprocket was installed on the square slot, not the circle. I have everything lined up and feel confident no contact between the cam and piston was made. Small cam. Tomorrow I will get new gaskets and try to fire. No wonder I wasn't getting compression with the finger test!
I will post videos tomorrow.
Re: fresh 383 build wont start [Re: Tommy383] #1362002
01/09/13 01:23 AM
01/09/13 01:23 AM
Chicago
PurpleBeeper Offline
Chicago
Well that was my guess....timing chain off.... glad you found it! I'm also happy you didn't knock a piston up into a valve!!! Put it together and fire that sucker up!
70 Roadrunner convt. street car 440+6, NOS, 4-spd, SS springs '96 Mustang GT convt. street car '04 4.6 SOHC, NOS, auto, lowered "Officer, that button is for short on-ramps"
Re: fresh 383 build wont start [Re: Tommy383] #1362003
01/09/13 10:59 AM
01/09/13 10:59 AM
IL
71383beep Offline
71383beep  Offline
IL
Wow..that is a relief. Hope all goes well and nothing else was missed.
Re: fresh 383 build wont start [Re: Tommy383] #1362004
01/09/13 11:20 AM
01/09/13 11:20 AM
Out in Left Field, NY
bobs66440 Offline
bobs66440  Offline
Even so, on the Cloyes set (which I assume you have) the square slot is only 2 degrees retarded (on the cam). As long as you installed it square to dot with the #1 piston at TDC, it should make little difference and run fine, albeit with a little less low end torque. With the mark at 6:00 on cam gear and 12:00 on crank gear with #1 piston at TDC is exhaust stroke. with the marks at 12:00 and 12:00 and #1 piston at TDC is compression stroke and #1 firing.
Re: fresh 383 build wont start [Re: bobs66440] #1362005
01/09/13 04:59 PM
01/09/13 04:59 PM
NC
Tommy383 Offline OP
Tommy383  Offline OP
NC
Just got through swapping the crank sprocket. lined it all up, regasketed everything and RTV'd it. Fired up 1st try. sounds awesome!!!!!!
no smoking, except the header paint. could not be happier!!!
thanks for all the advice everyone, and thanks moparts!!!
Re: fresh 383 build wont start [Re: Tommy383] #1362006
01/09/13 05:05 PM
01/09/13 05:05 PM
Seattle, WA
rss Offline
rss  Offline
Seattle, WA
Glad you got it figured out
Re: fresh 383 build wont start [Re: Tommy383] #1362007
01/09/13 06:00 PM
01/09/13 06:00 PM
Suffolk,VA
I
ireland383 Offline
ireland383  Offline
I
Suffolk,VA
Finish breaking her in and let her rip!
Awesome news.
Re: fresh 383 build wont start [Re: ireland383] #1362008
01/09/13 07:08 PM
01/09/13 07:08 PM
bobs66440 Offline
bobs66440  Offline
We want to see the burnout videos!
