Re: Ram 5 speeds... whats the difference?
[Re: Chilort]
#1361781
12/31/12 01:40 AM
12/31/12 01:40 AM
Posts: 454 Ashville, Manitoba, Canada
superbeeman69
super street
super street
My cousin did a 360 swap in a 3.9 shorty, the 3500 is held together with 2 tie straps at the moment. Still, it hauls azz. Try and find a 4500, I've heard some 318 trucks were made with 4500s, probably 4x4s but I've never personally seen one. Good luck!
1970 FM3 Coronet 440, 1971 FJ6 Dude D100
[Re: Lmopar69]
#1361782
12/31/12 02:28 AM
12/31/12 02:28 AM
Posts: 3,310 Walnut Creek, CA
blown340
Walnut Creek, CA
Unless its a 4x4 or you are doing a ton of heavy towing I don't agree with the above calls for the 4500 over the 3500. The 4500 has a granny first, so unless you are towing or off roading its really only a 3 speed + overdrive. The NV3500 has a 4:1 first so its still pretty deep, but is actually useable on the street. The 3500 also shifts nicer and is actually pretty sporty with the hurst shifter setup. In a 2wd application, especially a fairly light vehicle like a 46 dodge, the 3500 will be plenty strong with a street 360 unless you are planning big slicks and drag launches. That said, if youare planning big slicks and drag launches you really really wouldn't want the 4500 either! So I guess what I'm trying to say is, tell us more about the project and what your goals are and it will be easier to recommend a trans. -Jon
70 challenger convertible. 340/5 speed. blown, intercooled, efi, blah blah blah
71 valiant scamp 318/A833OD/AC/PS
00 dakota RC 4.7L 5 spd autoX'r. SRT10/T56 swap in process
73 W200 Power wagon, PTO winch, 4 spd
[Re: blown340]
#1361783
12/31/12 07:20 PM
12/31/12 07:20 PM
Posts: 392 Doniphan, Nebraska
Lmopar69
Doniphan, Nebraska
Project is a 46 Dodge truck. 2wd, boxed frame, IFS, 8 3/4" rear, "street rod" type build. Power will be either a EFI 360 magnum or a LA 360. Nothing crazy, just a nice driver with a bit of oomph under the hood.
I'd love a Richmond or similar 5 or 6 speed, but, Army pay isnt quite good enough for that. So, NV 3500 it is. Just trying to find out the differences between them before I purchase. I will buy an entire vehicle just to make it easy to swap out.
Laine.
[Re: Lmopar69]
#1361786
01/01/13 12:52 AM
01/01/13 12:52 AM
superbeeman69
super street
super street
I'm gonna say no as well, cept if the box is from a 4x4 then I'd check part numbers just to be sure. Is there anything on the cases to determine one from the other? Spline count? PN?
