trans brake reverse question #1361739
12/30/12 08:05 PM
12/30/12 08:05 PM
Fla
birdboy Offline OP
birdboy  Offline OP
Fla
have a tci trans brake. it must have the button pushed to put car in reverse. do you put shifter in rev then use button or do you hold button then put shifter in rev. someone told me you could burn something up. thanks guys
the more I deal with people the more I like my dog
Re: trans brake reverse question [Re: birdboy] #1361740
12/30/12 08:19 PM
12/30/12 08:19 PM
las vegas
70AARcuda Offline
70AARcuda  Offline
las vegas
put shifter in reverse..press you transbrake button..car backs up..
or put or leave shifter in neutral...press your transbrake button...car backs up
Tony
70 AARCuda Vitamin C
Re: trans brake reverse question [Re: birdboy] #1361741
12/30/12 08:19 PM
12/30/12 08:19 PM
I had one a long time ago, it seems to me if you push the button in nuetral or reverse it would back up Maybe brands and different versions work differently Call the commpany that makes yours and ask them
Re: trans brake reverse question [Re: birdboy] #1361742
12/30/12 08:23 PM
12/30/12 08:23 PM
Ambridge, Pa.
rickraw Offline
rickraw  Offline
Ambridge, Pa.
i have a tranzact t/b vb. i wired in a switch so i don't have to hold in the button for rev. i can back up in neutral. try it in neutral with the button on. it won't hurt anything.
Re: trans brake reverse question [Re: rickraw] #1361743
12/30/12 08:40 PM
12/30/12 08:40 PM
Plymouth Meeting, PA
bigtimeauto Offline
Trophy Winner
bigtimeauto  Offline
Trophy Winner
usually since the TB button activates reverse. neutral is the prefered shifter location. Check with your valve body manufacturer.
BB, TT5,Procharged 3300lb Street Car 4.79/154
Re: trans brake reverse question [Re: bigtimeauto] #1361744
12/30/12 09:04 PM
12/30/12 09:04 PM
Walhalla, SC
BlueDart Offline
BlueDart  Offline
Walhalla, SC
A trick I got from Rick Allison if your reverse lights still work just pickup power at the nuetrel saftey switch out to the the lights wire it in with Tranz brake put it in reverse and you dont have to hold the button I did this when I was still running my dart
Re: trans brake reverse question [Re: BlueDart] #1361745
12/30/12 09:15 PM
12/30/12 09:15 PM
bigtimeauto Offline
Trophy Winner
bigtimeauto  Offline
Trophy Winner
On the TCI instructions it states a turbo 400 can be done in reverse or neutral. nothing is stated for the 727.
Re: trans brake reverse question [Re: bigtimeauto] #1361746
12/30/12 09:29 PM
12/30/12 09:29 PM
las vegas
70AARcuda Offline
70AARcuda  Offline
las vegas
http://www.tciauto.com/tc/727-904-trans-brake-valve-body.html
kind of looks like a tranzact or grinder brake...
NOTE: To engage reverse, the Trans-Brake button must be used
in the instruction for the TCI 727/904 transbrake valve body
http://news.compperformance.com/Instructions/121900.pdf
Tony
