9 1/4" diff #1361721
12/30/12 07:29 PM
12/30/12 07:29 PM
Az
Crizila Offline OP
Crizila  Offline OP
Az
Anyone ever try welding up the spiders on one to make it a "quasi" spool? I'm lucky if I can get 12 passes out of my clutch disc unit before it needs new clutches.
Fastest 300
Re: 9 1/4" diff [Re: Crizila] #1361722
12/30/12 07:36 PM
12/30/12 07:36 PM
Park Forest, IL
slantzilla Offline
slantzilla  Offline
Park Forest, IL
You do know welded diffs are illegal, don't you John?
Time for a Dana.
Re: 9 1/4" diff [Re: slantzilla] #1361723
12/30/12 08:31 PM
12/30/12 08:31 PM
Az
Crizila Offline OP
Crizila  Offline OP
Az
Time for a Dana.
Probably why I haven't gotten any responses . Wish some one made a spool for it.
Fastest 300
Re: 9 1/4" diff [Re: Crizila] #1361724
12/30/12 08:38 PM
12/30/12 08:38 PM
New Mexico
Adobedude Offline
Adobedude  Offline
New Mexico
I killed my stock 9.25, then a Auburn LSD. Been using a Detroit locker for a number of years now, no problem.
But I hear you on the spool thing, plus there's the c-clip issue.
2001 Dodge Dakota
408 All Motor
11.27 @ 117.83 mph
2017 NM Mopar Challenge Series Champion.
Re: 9 1/4" diff [Re: Crizila] #1361725
12/30/12 08:39 PM
12/30/12 08:39 PM
Az
Crizila Offline OP
Crizila  Offline OP
Az
Time for a Dana.
I guess my real question is weather or not I can make it strong enough to last. Off road guys do it all the time.
Fastest 300
Re: 9 1/4" diff [Re: Crizila] #1361726
12/30/12 08:46 PM
12/30/12 08:46 PM
Fitchburg,Massachusetts
MPerry Offline
Mopahts memba'
MPerry  Offline
Mopahts memba'
scary stuff happens when they break and it will.
Re: 9 1/4" diff [Re: MPerry] #1361727
12/30/12 09:46 PM
12/30/12 09:46 PM
New Mexico
Adobedude Offline
Adobedude  Offline
New Mexico
Agreed, butI have never heard of a 9.25 breaking...
2001 Dodge Dakota
408 All Motor
11.27 @ 117.83 mph
Re: 9 1/4" diff [Re: Adobedude] #1361728
12/30/12 09:49 PM
12/30/12 09:49 PM
MPerry Offline
Mopahts memba'
MPerry  Offline
Mopahts memba'
he is talking about welding spider gears.
Re: 9 1/4" diff [Re: Adobedude] #1361729
12/30/12 11:29 PM
12/30/12 11:29 PM
Chandler, AZ
Duner Offline
Duner  Offline
Chandler, AZ
I broke the carrier with the factory LSD in mine.
I went with a Detroit Locker for it.
Re: 9 1/4" diff [Re: MPerry] #1361730
12/30/12 11:34 PM
12/30/12 11:34 PM
Park Forest, IL
slantzilla Offline
slantzilla  Offline
Park Forest, IL
John, locked rear also requires aftermarket axles. Tech may not know you have a welded diff, but if they notice you turning you'll get popped for axles.
Aren't you fast enough now to require aftermarket axles anyway?
Re: 9 1/4" diff [Re: slantzilla] #1361731
12/31/12 12:19 AM
12/31/12 12:19 AM
scratchnfotraction Offline
I just scored a 9 1/4 with a 3.55 open diff along with a LOC RITE locker that replaces the spider gears in the open carrier.
use stock axles,installs with hand tools,locks and unlocks for turns. also fits 85 up large bolt truck axles when the c-clip/carrier change in the 9 1/4
mostly seen used in 4x4 and off road rigs and a few B-body cars, it is very strong and durable with a positive locking for
check into the LOC RITE lockers as they have a few to offer. 9 1/4-8 3/4..ect.
cheapest way I have found to get a true locker and not R&R the R&P on a 9 1/4 just swap out the spider gears.
Re: 9 1/4" diff [Re: scratchnfotraction] #1361732
12/31/12 03:58 AM
12/31/12 03:58 AM
Newport, Mi
Evil Spirit Offline
Evil Spirit  Offline
Newport, Mi
I call them Lock Wrongs, because the couple times I had a brain failure and used them I hated driving the car or truck. Any time they were under power it would lock - fine in straight lines, but try pulling out in traffic without squeeling the inside tire - ain't gonna happen. Coasting around corners results in an obnoxious clicking noise as it rachets for the different axle speeds. And both times I ended up breaking the stock carrier (8 1/4's) as soon as I put a tire under it that hooked. Totally different operation than a Detroit Locker - mine in my Spirit has never squeeled a tire I didn't want it to and is bone quiet. Only advantage to a Lock Wrong is not pulling the carrier and swapping the ring gear, which to me isn't an issue - I just check backlash and reset it to that with the new carrier.
Free advice and worth every penny...
Factory trained Slinky rewinder.........
Re: 9 1/4" diff [Re: Evil Spirit] #1361733
12/31/12 04:16 AM
12/31/12 04:16 AM
maryland
buck440 Offline
buck440  Offline
maryland
ditch the 9 1/4 c clips are for chevy's. my duster had one under it when i bought it narrowed. one time both wheel's spin next time 1 tire fire. i put 8.75 under an all's good.
Re: 9 1/4" diff [Re: slantzilla] #1361734
12/31/12 11:43 AM
12/31/12 11:43 AM
Az
Crizila Offline OP
Crizila  Offline OP
Az
Ya big D. section 20, page 14, 2:11 in my 2013 rule book sez it all. Anyway, getting aftermarket axles isn't a problem. Didn't like the detroit locker that was in there. I will look in to the Loc/Rite stuff. It's a good tuff diff that I would like to stick with, but - - - - - .
Fastest 300
Re: 9 1/4" diff [Re: Crizila] #1361735
12/31/12 12:34 PM
12/31/12 12:34 PM
Newport, Mi
Evil Spirit Offline
Evil Spirit  Offline
Newport, Mi
Something else to consider - LockRites transmit all the power through the crosspin and into the weakest part of the case. Factory LSD's transmit some of the power through the cones or clutch plate tabs into a stronger part of the case.
And don't be surprised if when you install a locking style rear axle that the vehicle develops a hard pull to one side on the launch that you will have to tune out, which is the real reason you are working LSD's so hard.
Re: 9 1/4" diff [Re: Evil Spirit] #1361736
12/31/12 02:56 PM
12/31/12 02:56 PM
Az
Crizila Offline OP
Crizila  Offline OP
Az
Good info!! Thank you . I'm considering a cone style unit. Don't know how well they will last and I don't think they are rebuildable?
Fastest 300
Re: 9 1/4" diff [Re: Crizila] #1361737
12/31/12 04:06 PM
12/31/12 04:06 PM
Affton MO
Q
qwkmopardan Offline
qwkmopardan  Offline
Q
Affton MO
I put a Dana-60 in my 79 "300". It was allmost a bolt-in. My Dana 60 was from a 71 Charger. 8-3/4 from 71-72 B-bodys will fit the same and 73-74 B-Bodys are exact fit if you want to keep the quiet ride cushions, and are not to difficult to find. Could get ugly if you break an axle in your 9-1/4 diff.
11.600 at 116mph. 408 sm blk mopar--junkyard heads--4050lbs
Re: 9 1/4" diff [Re: qwkmopardan] #1361738
12/31/12 05:14 PM
12/31/12 05:14 PM
Az
Crizila Offline OP
Crizila  Offline OP
Az
Thanks for the info. The 9 1/4 I'm running came with my car. Spring perches are already modified to take single leaf CalTracs. If I have to change out the entire axle assembly I might just go with a custom Ford 9" to save some weight.
Fastest 300
