Re: Why Can't Cross Drilled/Slotted Rotors be Turned? [Re: lilcuda] #1361390
01/05/13 07:03 PM
01/05/13 07:03 PM
Finland
V
V��peli Offline
V��peli  Offline
V
Finland
Now i know why i hated lathe castiron flywheels.... chips are damn hot and sharp.
1 roadrace car builder at Finland sayd, they wont lathe disc because there is hot/hardspots at disc, when at lathe, it will come little bit wave and wont work at racecars.
But when they grind it, hard/hot spots wont matter.
Chrysler Newport 2d ht 383 4bbl 1969.
Re: Why Can't Cross Drilled/Slotted Rotors be Turned? [Re: V��peli] #1361391
01/06/13 02:08 PM
01/06/13 02:08 PM
Irving, TX
feets Offline
Senior Management
feets  Offline
Senior Management
Irving, TX
They are right. If you burn a flywheel it will harden the surface. Those spots are so hard it will push a cutter away. You get lumps.
Grinders don't care about those hard spots. The grinder will win that battle.
- Stu Harmon
