Re: Holley Carb Idle mixture screws leaking...Why? Pics..
[Re: Ramrod39]
#1361121
12/29/12 09:54 PM
12/29/12 09:54 PM
Posts: 2,586 Illinois, Indiana, Louisiana
ProStDodge
Looks like the seals dried out. I would count how many turns in it takes on each to seat lightly, then removed the screws completely. Using a small pick, pull the old gasket out, install new gaskets, re-install the screws to their original position.
Likely happened by having a carb built and tested or dyno'ed, then letting the carb sit on a shelf for years, allowing it to dry out.
[Re: ProStDodge]
#1361122
12/30/12 01:05 AM
12/30/12 01:05 AM
Posts: 9,117 Tucson, AZ
Ramrod39
My New Title
My New Title
Tucson, AZ
That describes the history of the carb. Did not know there were gaskets in there, that's why I posted. Where do I get the replacement gaskets? Do they sell them individually or do you have to buy a carb kit?
