Re: Int. mnfld. ? with a Ron's Injection.
[Re: rt66jim]
#1360902
12/29/12 09:22 PM
12/29/12 09:22 PM
Posts: 2,586 Illinois, Indiana, Louisiana
ProStDodge
Yes. You still need something that flows air well unless you go with forced induction. Adding fuel doesn't help if there is no air to help it burn. The amount of HP you are going to make is still going to be dependent on how much air flow you can get through the engine - In and Out. I did a blow-thru, but never tried it N/A. It was nice to be able to change the jet pill at each cylinder to help get more even exhaust temps. And it did prevent pooling of fuel on the plenum floor. I could probably be talked out of the unit, it has been sitting since I sold the Cuda in 2005.
[Re: rt66jim]
#1360903
12/29/12 09:22 PM
12/29/12 09:22 PM
Posts: 2,449 nc
earthmover
nc
[Re: mac56]
#1360908
12/31/12 02:39 AM
12/31/12 02:39 AM
Posts: 1,165 Central Ohio, USA
Bigbeep
Central Ohio, USA
Pump and mandrel.
Oops, that was my first drive mandrel that I made. I now have a modified moroso on there that also has the drive for my vacuu pump. Beep
[Re: MRMOPAR]
#1360911
12/31/12 03:01 AM
12/31/12 03:01 AM
Posts: 2,401 Tucson, Arizona
MRMOPAR
Tucson, Arizona
Installed . never used . may be looking for a home
68 RR 528" INDY MAXX
07 2500 CTD
Southwest International Raceway - IHRA - Tucson, AZ
[Re: MRMOPAR]
#1360912
12/31/12 12:13 PM
12/31/12 12:13 PM
Posts: 10,011 Frostbitefalls MN (Rocky&Bullw...
gregsdart
Alky is more forgiving, so the benefits of a better intake will be somewhat less than gas and carbs. But total airflow and ram tuning will still be of benefit. Too restrictive with alky would IMHO be the worst situation to have. The alky does take up a bit more runner volume. My question is it worth it to spend over $1300 to go to a tunnelram. I would guess there might be 1/2 the gain of a carb setup, as I already have a huge (2100 cfm) throttle body.
[Re: gregsdart]
#1360913
12/31/12 06:30 PM
12/31/12 06:30 PM
Posts: 2,008 Sweet Home Alabama
MRMOPAR622
Sweet Home Alabama
I like the C-N-C Tunnel Ram,the c-n-c equals the runners which equals each cylinder.But is it worth the extra $$$ I'm not sure. The set up on my old(not really old just have a Bigger one now)engine.
"To Be The Man'You Have Got To Beat The Man"
"T/D and Pro-Bracket Racer"
[Re: Mopar-Al]
#1360918
01/01/13 03:34 AM
01/01/13 03:34 AM
Posts: 159 australia
charger410
australia
I'm not exactly sure but I think with methanol the closer to the intake valve, the more top end hp you'll make, and the further up the intake runner the more mid range hp. With other fuels the injector would be higher up the intake runner because that makes more power better mixing. Methanol takes up more volume With injected sprint-car engines they will have injectors in the cylinder heads and the "intake manifold similar to yours" to get the best of both worlds.
Peter. Australian Charger, alloy block injected 410in, w9 na 9.03@148 leafs 3000lb
1967 barracuda 605 hemi Stage5 millennium 8.2@170
