Page 3 of 3 1 2 3
Re: Racers, help me select a battery! [Re: gregsdart] #1360682
01/07/13 10:55 PM
01/07/13 10:55 PM
Chandler, AZ
Duner Offline
Duner  Offline
Chandler, AZ
I ordered the B2317 for it's 17# weight and it's 21# weight savings over the Optima that's failing on me right now. I guess I'll see how well this battery does. I'm cautiously optimistic.
Re: Racers, help me select a battery! [Re: Duner] #1360683
01/08/13 10:28 PM
01/08/13 10:28 PM
dusterjp Offline
dusterjp  Offline
Just a little info to save you a few bucks. That battery you ordered is a Deka etx motorcycle battery with brass automotive adapters. It has no where near 475 cca's. You are better off getting one from a Deka Battery dealer and buying the adapters.
Re: Racers, help me select a battery! [Re: dusterjp] #1360684
01/08/13 10:53 PM
01/08/13 10:53 PM
Chandler, AZ
Duner Offline
Duner  Offline
Chandler, AZ
I guess I'll find out soon enough.... it's already on it's way.
If it has no where near 475CCA - how much does it have, and what other product will be as light and DOES have the advertised CCA available?
(I hate false advertising)
Re: Racers, help me select a battery! [Re: Duner] #1360685
01/08/13 11:32 PM
01/08/13 11:32 PM
Az
Crizila Offline
Crizila  Offline
Az
Good choice IMO. In your situation, RC and cranking amps ( 641 )are much more important than CCA ( unless you are racing in Alaska) . EMT ( enhanced mat technology ) is the way to go.
Fastest 300
Re: Racers, help me select a battery! [Re: Crizila] #1360686
01/08/13 11:43 PM
01/08/13 11:43 PM
Chandler, AZ
Duner Offline
Duner  Offline
Chandler, AZ
Hahaha.... just so the cranking power doesn't go down when it's hot out!
The factory bracket that holds the batter up weighs more than this battery will weigh. Or at least it USED to.
Re: Racers, help me select a battery! [Re: Duner] #1360687
01/09/13 11:26 PM
01/09/13 11:26 PM
dusterjp Offline
dusterjp  Offline
Unfortunately when it comes to batteires, to increase the capacity the physical size usually has to change. I have yet to see an AGM battery in that size with that kind of cold cranking amps. Cold cranking amps is a 0 degree rating, the hotter it gets the better the battery will perform. Hopefully the battery does what you need it to do.
Re: Racers, help me select a battery! [Re: dusterjp] #1360688
01/10/13 12:04 AM
01/10/13 12:04 AM
Chandler, AZ
Duner Offline
Duner  Offline
Chandler, AZ
Thanks. Lucky for me - I'm more concerned about how it reacts to heat.
They refuse to let us race anywhere around here if the track temps get below 65°. It will never ever be used to try and crank anything at any temp below 45° to 50° anyway. I just hope it works fine at a heat soaked 200°.
Page 3 of 3 1 2 3
