sm blk stroker weiand x-celerator vs. performer air gap #1360461
12/29/12 12:49 AM
12/29/12 12:49 AM
elmira ny
hp340nos Offline OP
hp340nos  Offline OP
elmira ny
was wondering if there is any gain in going from my gasket matched weiand x-celerator single plane to the edelbrock performer air gap intake?motor/vehicle specs as follows;
88 dakota 3360#, 2 wheel drive
pump gas, 9.8compression, 340 stroked to 418cid
street legal drive to track 40 minutes 1 way
cast iron x- heads full port/polish.2.055/1.625 valves
solid roller cam .246/.253 dur at .050. .585in/.600 ex lift
harland 1.5rollers/ shaft
weiand x-celerator single plane intake
aed 850 db pumper carb
1 3/4 tri-y long tube headers into 3"x-pipe to magnaflow stainless muffler ,tailpipes out the back
msd 6al ignition
rplba 727 tranny
10"t/a converter reflashed by ptc flashes 3500 on motor
8 3/4 rear posi with 3.91 gears
m/t street drag radials 25-55-15
100 hp shot of nos
in street form runs7.30@95 1.62 60fts
on 100 shot has been 6.83@102 1.50 60fts
launch at 2000 shift at 5800-6000rpm
looking for input on this intake???
Re: sm blk stroker weiand x-celerator vs. performer air gap [Re: hp340nos] #1360462
12/29/12 12:59 AM
12/29/12 12:59 AM
PA
moparacer Offline
moparacer  Offline
PA
If it were mine I would keep the Xcellerator on it.
We run one on my old Duster with a 360, then 408, and ported X heads and now ported Edelbrocks.
There are better intakes but that Weiand is better then a Air gap IMO.
67 Barracuda street/bracket car 11.27-119
68 Dart 502 BB 8.70s-152
414 cid SB Dragster 7.65-174
Re: sm blk stroker weiand x-celerator vs. performer air gap [Re: hp340nos] #1360463
12/29/12 01:03 AM
12/29/12 01:03 AM
W. Kentucky
justinp61 Offline
justinp61  Offline
W. Kentucky
IMO no, my Dart ran mid 7.20s with an X-Celerator on a pump gas 340. A very good and often overlooked intake.
Re: sm blk stroker weiand x-celerator vs. performer air gap [Re: hp340nos] #1360464
12/29/12 01:12 AM
12/29/12 01:12 AM
MR_P_BODY Offline
MR_P_BODY  Offline
I think with your cubes and the RPM that you turn
you would be past the useful range of the air gap
but it would make more torque
Re: sm blk stroker weiand x-celerator vs. performer air gap [Re: MR_P_BODY] #1360465
12/29/12 12:32 PM
12/29/12 12:32 PM
elmira ny
hp340nos Offline OP
hp340nos  Offline OP
elmira ny
i was always curious on the intakes ,thats why i posted.
Re: sm blk stroker weiand x-celerator vs. performer air gap [Re: hp340nos] #1360466
12/29/12 01:31 PM
12/29/12 01:31 PM
cincinnati ohio
mcat4321 Offline
mcat4321  Offline
cincinnati ohio
airgap hands down . the single plane should never be an option for your set up..
Re: sm blk stroker weiand x-celerator vs. performer air gap [Re: mcat4321] #1360467
12/29/12 01:50 PM
12/29/12 01:50 PM
Portage,michigan
B3422W5 Offline
B3422W5  Offline
Portage,michigan
i love the excellerator on a setup like yours. Its an excellent manifold that is extremely underrated.
No way i would swap it out. Great manifold for up to 7,000 rpm and has great all around performance.
Best so far, low 10.30’s 1/4
1.41 best 60 foot
6.56 at 104.17
Re: sm blk stroker weiand x-celerator vs. performer air gap [Re: B3422W5] #1360468
12/29/12 02:03 PM
12/29/12 02:03 PM
cincinnati ohio
mcat4321 Offline
mcat4321  Offline
cincinnati ohio
this is kind of like asking who makes the best converter...lol (PTC)
Re: sm blk stroker weiand x-celerator vs. performer air gap [Re: mcat4321] #1360469
12/29/12 06:29 PM
12/29/12 06:29 PM
Weddington, N.C.
Streetwize Offline
Streetwize  Offline
Weddington, N.C.
X cellerator is an awesome and often overshadowed ( by the SD, Vic 340 and even the M1) intake.
On an all-motor combo I would lean toward an airgap but on the spray a single plane is almost always the best route in terms of WOT cylinder to cylinder distribution,
WIZE
In Car:
Re: sm blk stroker weiand x-celerator vs. performer air gap [Re: Streetwize] #1360470
12/29/12 09:12 PM
12/29/12 09:12 PM
Washington
skrews Offline
skrews  Offline
Washington
Get one and try it out. IMO AirGap would be faster. Your 60' times are lazy for the MPH you run. I think the added low/mid range TQ would really help the short times. If it don't work to your liking, turn around and sell it. No shortage of guys looking for that intake.
Re: sm blk stroker weiand x-celerator vs. performer air gap [Re: skrews] #1360471
12/29/12 09:19 PM
12/29/12 09:19 PM
Northern Indiana
Dunnuck Racing Offline
Northern Indiana
At the level your at,its pretty much a toss up.
A lot of guys think a dual plane makes more torque but in reality a properly sized single plane will run as good or better.
Keith
