was wondering if there is any gain in going from my gasket matched weiand x-celerator single plane to the edelbrock performer air gap intake?motor/vehicle specs as follows;
88 dakota 3360#, 2 wheel drive
pump gas, 9.8compression, 340 stroked to 418cid
street legal drive to track 40 minutes 1 way
cast iron x- heads full port/polish.2.055/1.625 valves
solid roller cam .246/.253 dur at .050. .585in/.600 ex lift
harland 1.5rollers/ shaft
weiand x-celerator single plane intake
aed 850 db pumper carb
1 3/4 tri-y long tube headers into 3"x-pipe to magnaflow stainless muffler ,tailpipes out the back
msd 6al ignition
rplba 727 tranny
10"t/a converter reflashed by ptc flashes 3500 on motor
8 3/4 rear posi with 3.91 gears
m/t street drag radials 25-55-15
100 hp shot of nos
in street form
runs7.30@95 1.62 60fts
on 100 shot has been
6.83@102 1.50 60fts
launch at 2000 shift at 5800-6000rpm
looking for input on this intake???
