Hemi Magnesium Tunnel ram
#1360375
12/28/12 10:43 PM
12/28/12 10:43 PM
Posts: 915 Cincinnati OH
Bishop
Cincinnati OH
I have a old 426 HEMI Magnesium TR that is filthy, whats the best way to it cleaned and get a uniform appearance, its been sitting on a shelf for 30 years collecting dirt & grime. Glassbead???
Thanks Brian
Re: Hemi Magnesium Tunnel ram
[Re: Bishop]
#1360382
02/01/13 05:46 PM
02/01/13 05:46 PM
Posts: 902 Mopar Lane,Mississippi
67HEMI
I took my old milodon magnesium v/c and sand blasted them and then had them powder coated silverchrome with clear coat. Before pic After pic
'33 Plymouth 5 Window Coupe Blown Aluminum HEMI w/bolt ons (under construction)
'69 Chrysler 300 Convertible 375 HP 440
'71 Plymouth Duster 360 W/EFI (Wife's Ride)
'12 Ram MegaCab Dually 6.7 Cummins
[Re: 67HEMI]
#1360383
02/01/13 06:08 PM
02/01/13 06:08 PM
Posts: 4,785 Utah and Alaska
astjp2
Utah and Alaska
Eagle one mag cleaner. If you grit blast, you have to only us media that has been used on Mag. if you use grit that blasted steel or aluminum, you can inbed the steel or alum. it into the mag and create a disimilar metal corrision.
1941 Taylorcraft 1968 Charger 1994 Wrangler 1998 Wrangler 2008 Kia Rio 2017 Jetta
[Re: Bishop]
#1360384
02/01/13 06:10 PM
02/01/13 06:10 PM
Posts: 951 Temperance, MI
prochargedhemi
Temperance, MI
Thanks Brian
Not to be a D!CK but thats a pretty easy way to try and over double your money. Guess i should of just paid the $395 for it
[Re: astjp2]
#1360385
02/01/13 06:17 PM
02/01/13 06:17 PM
Posts: 6,257 gulfport, ms, west mi
rowin4
Beat me to it. I would be careful with just sand blasting. some sands can erode the surface and ruin your part. I would think a soda blast or walnut may be the way to clean the oxidation. Years ago where I worked they had multiple sand blast machines, a few were set up and called recycle machines, They were hand cabinets that would lay down a smooth satin finish on parts. Don't know if it was a finer aluminum oxide or what but the finish nice, not rough at all. I cleaned up a few intakes, came out just like new.
[Re: HEMIFRED]
#1360387
02/01/13 07:52 PM
02/01/13 07:52 PM
Posts: 952 Stockholm, Sweden
MrSixpack
Stockholm, Sweden
I put my magnesium Hemi Enderle FI intake in my new blasting cabinet and I used glass to clear it up, then clear coat.
1970 Super Stock Challenger ex. Paul Rossi 1968 Dodge Dart GT 340 1968 Dodge Charger /6 3 speed manual 1966 Chrysler 300 Loaded 1968 Dodge Charger R/T 440
1968 Mini Cooper
