Re: Do needle and seats go bad and stick closed?
[Re: Ramrod39]
#1360353
12/28/12 10:55 PM
12/28/12 10:55 PM
RapidRobert
If you're sure nothing is rubbing/hanging up mechanically on the float assy then blast the needle/seat with a shot of starting fluid to clean it. If the needle comes out seperately wipe the neoprene tip of it with your thumb to polish/clean it. Are you sure the pump is priming/gas is being delivered to the carb inlet?
[Re: 500ciDuster]
#1360355
12/28/12 11:18 PM
12/28/12 11:18 PM
Posts: 12,043 State of Confusion
hp383
Just a normal tag again
State of Confusion
You will probably find shellac or gummy gas in the bottom of the float bowl(s) as well.
A good disassemble and cleaning with carb cleaner wouldn't hurt. Or if you have the time and funds, toss in a rebuild kit too.
Join the Penguin Liberation Front!! Stop the Hippo Occupation!
[Re: hp383]
#1360356
12/29/12 02:13 AM
12/29/12 02:13 AM
Posts: 9,122 Tucson, AZ
Ramrod39
My New Title
My New Title
Tucson, AZ
Funny thing is, none of the gas seems gummy or seems to have shellac. Bottom of the bowl looks OK. I sprayed the needle and seat with carb cleaner and figured that world take care of it. Wrong. I guess I'll buy a kit and throw the new needle and seat in.
[Re: Ramrod39]
#1360357
12/31/12 11:24 AM
12/31/12 11:24 AM
Posts: 1,290 New Kent, Va.
bobbyb
New Kent, Va.
I had a little problem with my boat motor carbs. I removed the bowls and could see trash in the bottom from alcohol/gas. I cleaned up the carbs and a rebuild kit, but the kit didn't have needle valve. Installed carbs and still had a problem, bought a new kit with new needle valves and fixed the problem. Old needle valves didn't look that bad, but I guess they were bad enough to cause a problem.
2004 Dodge Rumble Bee 5.7 Hemi
1969 Plymouth Roadrunner
