tools #1359913
12/27/12 07:56 PM
12/27/12 07:56 PM
South Bend, Indiana
E
Ellies Dart Offline OP
E
South Bend, Indiana
what are these two tools used for,found them in a car last summer.there is tool-A and tool-B.thanks moparts
Re: tools [Re: Ellies Dart] #1359914
12/27/12 08:28 PM
12/27/12 08:28 PM
McGregor,Iowa 52157
500ciDuster Offline
500ciDuster  Offline
McGregor,Iowa 52157
i've seen them in a bondage chamber before
Re: tools [Re: 500ciDuster] #1359915
12/27/12 08:31 PM
12/27/12 08:31 PM
fredericksburg virginia
mopwrd340 Offline
mopwrd340  Offline
Tool a is for installing locking strips around windshields and other glass usually on trucks and heavy equipment,
Re: tools [Re: Ellies Dart] #1359916
12/27/12 08:45 PM
12/27/12 08:45 PM
tool A, the spoon edge of one of the 4 extensions spreads the type of windshield gasket like on my 65 Dart that has the wide center groove, further apart so the locking strip is fed into the groove thru one of the 4 extensions using whichever one that matches the gasket/locking strip width you are working with as you push the tool along/into the gasket groove
Re: tools [Re: RapidRobert] #1359917
12/28/12 10:33 AM
12/28/12 10:33 AM
s.w.fl
bonefish Offline
bonefish  Offline
s.w.fl
i think tool b is a nose hair remover,my uncle had somthing like that in his barber shop.
