I am trying to put a motor "together" for motivation (myself and the car) out of parts that I have, as Im starting over for the 2nd time in as many yrs (plant clossings)money is non existent. What I do have is a 383 that looks fairly clean but is unknown. .020" deck with 10cc dish-almost entire piston. I also have a 400 that has been rebuilt with L3014F Flat top .030" over pistons but, with a .120" deck. I have a set of 915 with 79/80 cc. this +.018 HG will give the 383 +/- 9.0 and the 400 +/- 8.3
For parts I have an DP4B Dual plain, xe274h comp, also a I-.440"/E-.470" cam, 3 way timing sprocket,isky adj 1.5 rockers, 1 7/8" header, or HiPo manifolds,windage tray, elec ign. Going into a 69 RR POST 4spd car. 3.55 or 3.23 posi.
Would I be better to go for the 383's higher comp. or the fresh 22 extra cubes of the 405? Im leaning to the 400 because it is some what fresh, if it where a 440 at 8.3 there would be no question I would go for the cubes but, is 22 enough to make up for the comp of the 383? what are your thoughts? I had something close onetime 400, milled 906, Engle K7HYD .517"
244@50 ran cam adv.same header, intake,700DP auto,stock conv. 3.23 in a 68 GTX. ran like a scalled dog. weld:
Mr.Runum.
