Re: Measuring Pinion Bearing Preload???
[Re: mopowers]
#1359805
12/27/12 05:48 PM
12/27/12 05:48 PM
Posts: 288 Birmingham, England
Mick70RR
Birmingham, England
How about bolting an 18" bar to the pinion and using your kitchen scales. Should read 1lb on the scales.
1970 Road Runner
505 cid
MCH CNC ported Stealth heads
MP 528 camshaft
4 speed
GV overdrive
11.98 @ 117 on street treads
[Re: Cab_Burge]
#1359809
12/28/12 10:45 PM
12/28/12 10:45 PM
Posts: 323 Raleigh, NC
Meangreen68
Raleigh, NC
I bought this CDI on Ebay for $40. It has a memory-needle. Keep a look out
[Re: Meangreen68]
#1359810
12/28/12 10:56 PM
12/28/12 10:56 PM
Meangreen68
Raleigh, NC
Yep, the stars were aligned when I set up my 8-3/4. I bought this brand-new 4-foot CDI 6004 (600lb) click-type for $115. I drove onto Fort Bragg and bought it from a soldier's wife. When she brought it out from her closet, it stood almost as tall as her!
[Re: Meangreen68]
#1359811
12/28/12 11:13 PM
12/28/12 11:13 PM
Meangreen68
Raleigh, NC
...and I won't depress you any further for what I paid for this. Anyone in the Raleigh, NC area that needs help setting-up, I'd be more than happy to oblige. I sold my shop press a while back, so you'd need to have one
[Re: Meangreen68]
#1359813
12/29/12 04:37 AM
12/29/12 04:37 AM
Posts: 3,010 Sac, CA
mopowers
Sac, CA
Keep a look out
That's an awesome torque wrench, Wish I had one! But that memory needle won't help with bearing preload. Nice tool though. And great price!!
[Re: Commando1]
#1359815
12/29/12 11:33 AM
12/29/12 11:33 AM
Mick70RR
Birmingham, England
No, I have a factory manual here showing preload being checked with spring scales. I've also seen factory tools that are just a calibrated bar that bolts to the pinion and a weight is slid along the bar until the pinion moves, then the torque is read off the bar. These days it's easier to just buy a suitable torque wrench but any method is better than just guessing.
1970 Road Runner
505 cid
MP 528 camshaft
4 speed
GV overdrive
[Re: NITROUSN]
#1359816
12/29/12 11:52 AM
12/29/12 11:52 AM
Posts: 685 SW Ohio
AAR-B4
SW Ohio
I never checked with a torque wrench. I always went by feel. Not to seem like a smart a$$ but feel is all I went by. One you have set up 20 or so you will know what I feel.
If you have adjusted tapered roller bearings you know when you have the preload correct. Assemble it without the seal to get the real feel and have a good selection of shims.
[Re: mopowers]
#1359817
12/29/12 01:05 PM
12/29/12 01:05 PM
Meangreen68
Raleigh, NC
I disagree, I turn the memory pointer against the main pointer when I get beyond the breakaway-torque.
And also, the memory pointer is independent of its own knob, which means the memory pointer "slips" once it makes contact with the main pointer of the torque wrench.
You can turn and turn the memory pointer's knob pushing the memory pointer against the main pointer, and the main pointer won't budge.
The tension on the memory pointer is very light and it can be turned against the main pointer at any time in the wrench's cycle.
Just my
[Re: Meangreen68]
#1359818
12/29/12 03:14 PM
12/29/12 03:14 PM
mopowers
Sac, CA
Just my
Wow! That's awesome. Can I borrow it? HAHA!
[Re: mopowers]
#1359819
12/29/12 09:55 PM
12/29/12 09:55 PM
Posts: 4,872 connecticut
pnypwr
connecticut
maybe im just weird but when it comes to a torque wrench I wont buy the cheapest thing out there...for 40 bucks how accurate is it really? I guess if your going to use it once and its your own stuff...but doing it professionally and have to guantee stuff...I guess Ill spend the money.
if you were local id let ya borrow mine or do it for ya, but ca isnt close to ct
"Are you gonna bark all day lil doggy? Or are you gonna bite?"
05 ram 2500 ctd 74 gremlin x 360 65 mustang 347 70 coronet R/T 440 03 Mach 1
