Re: 6bt Cummins in an abody? [Re: pinkduster] #1359794
12/29/12 12:27 AM
12/29/12 12:27 AM
Oakville, Wa
HOTMOPR Offline
HOTMOPR  Offline
Oakville, Wa
A 6 bt is a 3' cube for a idea of size. They are 3' from edge of turbo to edge of pump. 3' from front of engine pully to bellhousing flange and 3' from top of valve cover to bottom of oil pan. I though about cramming one into my barracuda. I had a 95 standard cab 4x4 that ran mid 12s at 6800 lbs. drop 3200 lbs and it would be fun..
67 Barracuda, 470" B, Glide, FuelTech FT600, Precision, Ptc, QA1, Calvert, Smith racecraft, Afco, Dana 60. 275 radials
Re: 6bt Cummins in an abody? [Re: HOTMOPR] #1359795
12/29/12 12:50 AM
12/29/12 12:50 AM
St. Louis, MO
Blues_Cuda Offline
Blues_Cuda  Offline
St. Louis, MO
There are a couple 70 or 71 Monte Carlos in St. Louis with turbo diesels in them.
Re: 6bt Cummins in an abody? [Re: HOTMOPR] #1359796
12/29/12 12:55 AM
12/29/12 12:55 AM
Sherwood park, Alberta.
go green Offline
go green  Offline
Its the last frontier IMO. The diesel drags are still attainable for entrepreneurial people .I am trying to convince my cousin to go halfers on a max effort car to destroy the class now .
6.50 @ 226 MPH 4.25 @ 186 MPH
https://www.youtube.com/watch?v=YX86DHGKBo0
Re: 6bt Cummins in an abody? [Re: go green] #1359797
12/29/12 12:47 PM
12/29/12 12:47 PM
maryland
buck440 Offline
buck440  Offline
maryland
put a straight axle under it gasser style.
