Group 27 Yellow Top is Toast #135966
10/13/08 07:29 PM
10/13/08 07:29 PM
Central Arkansas
P
Pre_RT Offline OP
Pre_RT  Offline OP
P
Central Arkansas
Hi Ya'All. I have a group 27 yellow cap lead acid battery that is D.R.T. ("Dead right there" in EMS speak). A friend has mentioned that several posters in the past have shown creative ways to make a Battery "cover" out of their old case. Before I go to hacking up this one, has anyone documented this procedure?
Thanks'
Re: Group 27 Yellow Top is Toast [Re: Pre_RT] #135967
10/13/08 08:18 PM
10/13/08 08:18 PM
Minnesota
Hemi_Joel Offline
Hemi_Joel  Offline
Minnesota
Just cut the bottom out and rip the innards out. It's hard work. (Obviously you need to rinse the battery out good first) Up at the top there is a bunch of lead chunks that connect everything together up there. Cut all that away leaving just the posts. Be carefull not to knock the posts loose. Then drill and tap a couple holes in the bottom of the posts. Then bolt a couple of short battery cables to the bottom of the posts. THen put your little battery inside it and hook it up to the cables. I use a Dyna-Batt http://www.performancedistributors.com/batteries.htm I use the one with bolts on top, not batery terminals, then use battery cables with an eye on each end. THe foam packing thet the Dynabatt is packed in for shipping fits nice between the old battery case and the dyna batt to hold it in place.
Have fun!
RS23J71
RS27J77
RP23J71
RO23J71
WM21J8A
Re: Group 27 Yellow Top is Toast [Re: Hemi_Joel] #135968
10/13/08 08:31 PM
10/13/08 08:31 PM
Central Arkansas
P
Pre_RT Offline OP
Pre_RT  Offline OP
P
Central Arkansas
That's the ticket! I have never been inside of a lead acid, just didn't want any surprises! I have several smaller form no-maintenance batteries around here. I guess that one of those would work as well as the dry-cell?
