uncloging heater core tricks #1359455
12/26/12 06:02 PM
12/26/12 06:02 PM
Alton, IL
Dakota_Don Offline OP
Alton, IL
I have a clogged heater core, in the past i have used CLR let it sit over nite and flush it out with clean water and air, what other chems or tricks have you all used.
Re: heater core tricks [Re: Dakota_Don] #1359456
12/26/12 06:17 PM
12/26/12 06:17 PM
I've pulled the hoses off of the nipples & back flushed it with a garden hose nozzle modulating the pressure somewhat with my other hand which helped with a slightly to moderately clogged one. No opinion on a good chemical to use but it'd have to be caustic to do any good. Cooling system deposits are tough. Doug Dutra the /6 guru used a solution of Muriatic acid (swimming pool cleaner) in a bare block & said the insides came out like fresh bare metal. Dont remember what percentage of acid/water he used nor how long he let it sit tho used in a core that might affect its' soldered joints
Re: heater core tricks [Re: RapidRobert] #1359457
12/26/12 11:46 PM
12/26/12 11:46 PM
Chino Valley
RodStRace Offline
RodStRace  Offline
Chino Valley
Always back-flushed, but more often than not, any plugged core that is unplugged tends to leak!
You could try an old speedo cable (just the inside part) to 'snake' out the clogs...
Re: heater core tricks [Re: RodStRace] #1359458
12/26/12 11:59 PM
12/26/12 11:59 PM
Maryland
GO_Fish Offline
GO_Fish  Offline
Maryland
the aluminum, copper and solder on heater cores are thin to begin with. Add some corrosion and some probing and you've got a leak. Not much to loose though... with no heat you'll probably be going into the dash anyways.
Scott B. "I'm a self-made man... I started with nothing, and I still have most of it!" 68 360 rusty B'cuda 'vert (GO Fish)13.59@ 98.72 mph 69 340 GTS stock 14.18@ 95.60 mph 01 5.9L Ram 1500 Quad Cab 4x4 01 3.5L 300M 16.23@ 86.97 mph
Re: heater core tricks [Re: GO_Fish] #1359459
12/27/12 01:51 AM
12/27/12 01:51 AM
IN
ahy Offline
ahy  Offline
IN
If its a coolant related plug (Dexcool?), backflush with a garden hose usually works. If its a hard plug, good luck.
Re: uncloging heater core tricks [Re: Dakota_Don] #1359460
12/27/12 10:11 AM
12/27/12 10:11 AM
MN
Skid_Demon Offline
Skid_Demon  Offline
MN
A number of years ago I bought a 76 Dodge pickup. Okay, it was many years ago. My garden hoses were rolled up for the winter, so I went to the local car wash and used their pressure wand. I figured I had nothing to loose. I brought along a piece of plastic pipe and extra hose clamps to re-plumb if the heater core burst. After a few minutes or so of flushing, the thick green goo started looking cleaner. After a few more minutes, we were good to go. No leaks, excellent heat. Seems like that was one of the few times things worked out as planned.
Re: uncloging heater core tricks [Re: Skid_Demon] #1359461
12/27/12 10:21 AM
12/27/12 10:21 AM
indiana
mcmopars Offline
mcmopars  Offline
indiana
depending on what its in,most always,you will be money ahead to just replace
Re: heater core tricks [Re: RodStRace] #1359462
12/28/12 01:12 AM
12/28/12 01:12 AM
Back home in PA
BulletBob Offline
BulletBob  Offline
Back home in PA
Trash in a cooling system works like stop leak
It finds the leak only being larger & more rigid the stop leak it gathers the rest of the trash & essentially becomes like a clogged filter so to speak
Re: heater core tricks [Re: BulletBob] #1359463
12/28/12 01:21 AM
12/28/12 01:21 AM
Holly/MI
Dean_Kuzluzski Offline
Holly/MI
I've used air pressure from my shop compressor to blow out a plugged heater core. Just ease into it with a nozzle and once opened put it back together. If it leaks, add a little Bars Leak, pepper or whatever trick of choice.
Re: heater core tricks [Re: BulletBob] #1359464
12/28/12 01:40 AM
12/28/12 01:40 AM
Sterling Conn
manymopars Offline
manymopars  Offline
Sterling Conn
I have a 98 Durango that has 210.000 miles on it.About every two years when I start to notice lack of heat at idle I know its time to back flush the heater core.What I do is I disconnect the inlet hose to the core and loop it back to the water pump and then I drive down to the local car wash and using their spray guns I back flush the core through the cores outlet hose. I have probably back flushed the core 3 times and have had no issues yet with the core leaking.At some point I know I will have to replace the core but until that time comes I will just continue to flush it every two years or so..
Re: heater core tricks [Re: manymopars] #1359465
12/28/12 07:51 AM
12/28/12 07:51 AM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
We backflushed a bunch of GM heater cores for no heat.The Dexcool clogged them up.Some you had to do a few times to get good heat.Never had any leaks.I had a 73 Dart that had a plugged core.Flushed it probally 10 times.Still never had good heat.Replaced the core and it roasted you out.Typically though they will be good after a good flush.That and almost never have they leaked.Rocky
Chrysler Firepower
Re: heater core tricks [Re: therocks] #1359466
12/28/12 12:42 PM
12/28/12 12:42 PM
Holly/MI
Holly/MI
Anyone ever try putting some Airsoft BB's into the heater hoses to help clean out the heater core???
This assuming you have both the inlet and outlet hoses detached and can recapture the BB's when they come out.
Re: uncloging heater core tricks [Re: Dakota_Don] #1359467
12/28/12 05:25 PM
12/28/12 05:25 PM
East Brunswick, NJ
finadk Offline
finadk  Offline
East Brunswick, NJ
I have had good luck using CLR. Flush with water, Avoid high pressure air you can easily blow out a weak core. Pour the CLR in through the heater hoses, let it sit, flush with water again. I would flush it into a white bucket and stop once the sediment stops coming out.
Good Luck
Scott 1956 Dodge Custom Royal Lancer (408 Stroker, 4 Wheel Disc Brakes, Rack & Pinion, 6 speed) 2002 Dodge Ram 1500 Quad Cab 1976 Corvette
Re: heater core tricks [Re: Dean_Kuzluzski] #1359468
12/28/12 11:27 PM
12/28/12 11:27 PM
State of Confusion
hp383 Offline
Just a normal tag again
hp383  Offline
State of Confusion
I dont think the passages on the core would pass the BB's
Join the Penguin Liberation Front!!
Stop the Hippo Occupation!
Re: heater core tricks [Re: hp383] #1359469
12/29/12 12:15 AM
12/29/12 12:15 AM
N
NITROUSN Online content
NITROUSN  Online Content
N
Re: heater core tricks [Re: NITROUSN] #1359470
12/29/12 08:18 PM
12/29/12 08:18 PM
Alton, IL
Alton, IL
kool ty
Re: heater core tricks [Re: Dakota_Don] #1359471
12/30/12 07:00 PM
12/30/12 07:00 PM
Amherst,NY
challengermike Offline
Amherst,NY
i have been told liquid plumber or draino works great.
Re: uncloging heater core tricks [Re: Dakota_Don] #1359472
12/30/12 07:06 PM
12/30/12 07:06 PM
San Jose, Ca.
dhkennedy Offline
dhkennedy  Offline
San Jose, Ca.
White vinager worked for me.
