NEED ADVICE ON MIG WELDER TO BUY
#1359440
12/26/12 05:44 PM
12/26/12 05:44 PM
Posts: 398 Texas
70Runnerdude
Texas
I would like to buy a mig welder to do some body panel repair on my roadrunner. I am on a $950 budget. I dont seee my self using it all the time and but do want a good name brand so I can get parts if needed. I looked at the Hobart 210 MVP around $850 and the Hobart handler 140 arond $500. It looks ok I think. You all have any ideas ? Thanks! Dave
Re: NEED ADVICE ON MIG WELDER TO BUY
[Re: 70Runnerdude]
#1359441
12/26/12 05:49 PM
12/26/12 05:49 PM
1_WILD_RT
Management Trainee
Management Trainee
Today? Who Knows?
My advise, check your local Craigslist.... Make sure you get one with gas.... Miller, Lincoln & Hobart all make decent stuff with good support...
[Re: 70Runnerdude]
#1359443
12/26/12 06:06 PM
12/26/12 06:06 PM
Posts: 323 Raleigh, NC
Meangreen68
Raleigh, NC
I own a Miller 130XP. It's one of the best 110v welders out there. It's an older model but they can be found used on Craigslist, snatch one up if you get the chance. It has serrated lower/smooth upper drive rollers. I put many miles of wire through mine. A 200 amp welder is too big/much for thin sheet metal repair. Use a copper bar to back up thin/butt welds, it'll help absorb the heat BTW, Here's one being sold locally. welder, tank, gauges, cart... http://raleigh.craigslist.org/tls/3502334650.html
[Re: 1_WILD_RT]
#1359447
12/26/12 06:46 PM
12/26/12 06:46 PM
Posts: 859 VA
AtomicDog
VA
If you are not in a tremendous hurry, you can get a lot more welder by buying used from craigslist. I'm very happy with my Lincoln PowerMig 255 - it's an extremely versatile welder that will be able to handle most any MIG welding job you have. I found it on our local craigslist a while back for $1000 and it even had a spool gun attachment to allow for welding aluminum. There was no way I could have purchased that much welder new, as it would have been more than double the price..
[Re: sdweatherman]
#1359452
12/26/12 10:13 PM
12/26/12 10:13 PM
Posts: 509 Middle River, MD
Mapandjlp
Middle River, MD
I purchased a Miller - matic 140. Great little machine for sheet metal and light steel. Got a cart, gas, and helmet and kept the total price under $1000. It has variable settings so you can dial in exactly where you need it. I had no welding experience and was able to jump right into my car after just a few practice welds.
[image]http://www.cardomain.com/ride/2598982/1971-plymouth-satellite/page-3/#25989824043[/image]
[image]http://www.cardomain.com/ride/2598982/1971-plymouth-satellite/page-3/#15990699[/image]
Good luck with whatever you choose!
Just bought the same unit, with cart/bottle/etc., under $1k as well. Nice unit!
