Fuel Pump Recommendations? #1359434
12/26/12 05:30 PM
12/26/12 05:30 PM
Way North Idaho
1KoolBee Offline OP
1KoolBee  Offline OP
Way North Idaho
Hi all, looking for your recommendations on a fuel pump for my 500 stroker, 6 Pack , MP .557 solid cam, 1.6 rockers. Will be running a 4-speed with a 3.54 gear, street driven, occasional strip. I was considering the Carter M4862 strip mechanical but will 8-8.5 PSI be too much for the street? Would carter street pump be better? Other suggestions? Thanks.
'68 Bee 383/TF/Factory Air...high school sweetheart
'67 GTX Clone project,500 six pack,Hemi4-speed,Dana
05 Dodge Viper, 505 V-10, 6-speed Tremec
Re: Fuel Pump Recommendations? [Re: 1KoolBee] #1359435
12/26/12 05:51 PM
12/26/12 05:51 PM
Stuart FL
mercman1 Offline
mercman1  Offline
Stuart FL
I have found that with todays fuels you are asking for vapor locking trouble with a mechanical pump. Todays fuels vaporize/boil at much lower temps than in the old days. Just like a radiator cap raises the pressure to also raise the boiling pont, the higher the fuel presure that you run will also raise the boiling point of the fuel. If you lower the pressure (vacuum) the fuel will boil at an even lower temp. That hot mechanical pump sucking fuel from the tank is no where near as desireable as a cool electric pump pushing fuel up to the carb.
My personal preference with my cars is....on my cruiser GTX 450 hp is a Mallory Comp 110 no regulator needed as they are set at 7psi and on my higer hp cars 500-600+ hp is a Comp 140. they are very quiet and durability has been excellent.
Re: Fuel Pump Recommendations? [Re: mercman1] #1359436
12/26/12 07:08 PM
12/26/12 07:08 PM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
I was using the red Holley pump preset at 7 PSI but I stepped up to the Firecore 140 Pump with the reg when I put my 493 in my 63. The pump has worked real good and you can get them from a member here (SunroofGTX) . Both are electric pumps. Ron
Re: Fuel Pump Recommendations? [Re: 1KoolBee] #1359437
12/26/12 08:57 PM
12/26/12 08:57 PM
Jacksonville, FL
Chris2581 Offline
Chris2581  Offline
Jacksonville, FL
Red or Blue Holley is what I'd use.
Nautilus Racing-
Re: Fuel Pump Recommendations? [Re: Chris2581] #1359438
12/27/12 01:34 AM
12/27/12 01:34 AM
Washington
skrews Offline
skrews  Offline
Washington
Mallory 110
Re: Fuel Pump Recommendations? [Re: skrews] #1359439
12/27/12 04:21 AM
12/27/12 04:21 AM
Gilroy,CA.
mopardude318 Offline
Gilroy,CA.
use a Walbro GSL-392 good for 600 boosted EFI HP, Fuel Pump is $100.00 and it is super quiet. The Walbro is the least expensive and most efficient fuel pump
408 Stroker 533 HP 520 FT LBS...........................1970 Dart RMS AlterKation
