Oil Experimenting #1359282
12/26/12 11:40 AM
12/26/12 11:40 AM
western PA
Sb Valiant Offline OP
western PA
I am still trying to pick apart every little aspect on why our car slowed down! 2 years ago we ran brad penn 20w 50 oil which is partial synthetic and a napa gold filter. Last time out we ran 15w 40 rotella t oil with a cheapy fram filter. Between the 2 oils there wasn't a dramatic oil pressure change but there was a little. My question is has anyone tested the 2 oils and seen any et difference?
Re: Oil Experimenting [Re: Sb Valiant] #1359283
12/26/12 12:29 PM
12/26/12 12:29 PM
Finally a HUSKER again
Moparnut426 Offline
Moparnut426  Offline
Im guessing the MoPar GODS punished you for running a Fram Filter. They were gonna blow up your engine, but thought they would rack your melon with slowing your car down a touch.
Re: Oil Experimenting [Re: Sb Valiant] #1359284
12/26/12 12:58 PM
12/26/12 12:58 PM
Chandler, AZ
Duner Offline
Duner  Offline
Chandler, AZ
How much did it slow down?
And where did it slow down?
Re: Oil Experimenting [Re: Sb Valiant] #1359285
12/26/12 01:01 PM
12/26/12 01:01 PM
Locomotion Offline
Locomotion  Offline
There would likely be too little performance difference to notice or worry about.
Re: Oil Experimenting [Re: Sb Valiant] #1359286
12/26/12 01:04 PM
12/26/12 01:04 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
I did a "somewhat" back to back test years ago going from a conventional Valvoline 10w40 to Royal Purple and picked up almost a tenth but if you don`t keep EVERYTHING the same like; leave rpm`s, engine, oil and trans temps, how can you get a true comparason. Lets not forget corrected altatude, humidity track prep etc............I only run thinner oils like 5w30-10w30 myself.............
Re: Oil Experimenting [Re: Sb Valiant] #1359287
12/26/12 01:10 PM
12/26/12 01:10 PM
Alabama
Mopar-Al Offline
Mopar-Al  Offline
Alabama
what did it run 2 yrs ago? What does it run now? What rpms, how are the springs?
Re: Oil Experimenting [Re: Mopar-Al] #1359288
12/26/12 01:33 PM
12/26/12 01:33 PM
western PA
western PA
So many things changed from 2 years ago and really too many things changed!! It ran 7.50's in the 1/8 but that was with a set of 5.13 gear's because that's all we used to run! Went to a better fuel system then we had previous. Changed out all of the mechanical stuff. Water pump and fan. Took off alternator and got rid of the belt and pulley. Got a new set of plug wires that were same brand. Moroso. Got a new carburetor but same cfm as the last one which was a edelbrock aka edelbog. The new carburetor we kind of messed up in a way but still works. It's just a street serious proform. Added a aluminum 2" open spacer. Changed from 20w 50 brad penn to 15w 40 rotella t. Also took about 40-50 lbs off the car and probaly the worse mistake was a 4.30 rear end gear made the car a dog. Thinking all this stuff would make it go low 7's but ended up going 8.00.. It's really not far to blame it 100% on the rear end gear but I think it's safe to say atleast 50% of the blame could go there! We never got a good pass on it the first pass wasn't real good. Went 8.003 at 87 mph in 1/8 and 12.65 at 104 in 1/4. Also it had a 1.75 60 ft we didn't get a good burnout.. We had our acts together on the second pass we got a much better burnout and got the car staged real good and as soon as we let go off the botton the car came to a holt. One of the bolts that holds the caps for the spool assmebly decided to snap! So who knows on the first pass wether the rearend was starting to fight itself or what? All I know no matter what would do that day the car wasn't getting out of the 12's.. To high of gear. The 7.56 equals out to a ll.78 in the 1/4. Also timing could be hurting us as well especially not knowing where it is at so there could be a decent gain right there! Now that I got a timing light I can get it set correctly! I also got a new leak down tester which will be put to use here soon! I am also going to do a bunch of other checks so I'll deffiently keep everyone updated on this long journey and mystery that we will be going through to pick apart all the problems!!!
Re: Oil Experimenting [Re: Sb Valiant] #1359289
12/26/12 01:43 PM
12/26/12 01:43 PM
Chandler, AZ
Duner Offline
Duner  Offline
Chandler, AZ
Wayy too many changes to even consider the oil as being one of the variables IMO. You are basically just starting over. There are too few things the same to even compare.
Of course, I'll be the very first to admit that I've been wrong before..... but I wouldn't worry about the oil.
Re: Oil Experimenting [Re: Duner] #1359290
12/26/12 02:01 PM
12/26/12 02:01 PM
western PA
western PA
I almost have to start a new post on picking apart our combonation of parts between engine and suspension and see what everyone can come up with? Does anyone think this a good idea? Anyone for it!?
Re: Oil Experimenting [Re: Duner] #1359291
12/26/12 02:02 PM
12/26/12 02:02 PM
western PA
western PA
Anyone up for the challenge I should say lol
Re: Oil Experimenting [Re: Sb Valiant] #1359292
12/26/12 02:09 PM
12/26/12 02:09 PM
Ont. Canada
10.90 Racer Offline
super street
10.90 Racer  Offline
super street
Ont. Canada
I almost have to start a new post on picking apart our combination of parts between engine and suspension and see what everyone can come up with? Does anyone think this a good idea? Anyone for it!?
Yes post all your details in point form........ Sounds like you are trying to get 10 seconds worth of parts into the 11's and beating on it like it owes you 9's.............
Re: Oil Experimenting [Re: Duner] #1359293
12/26/12 02:17 PM
12/26/12 02:17 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
Well that changes everything now.............apples to oranges at this point........
Re: Oil Experimenting [Re: 10.90 Racer] #1359294
12/26/12 03:27 PM
12/26/12 03:27 PM
western PA
western PA
The only thing to mine and everyone else who is trying to help disavantage is I only know what someone told me about the motor. I don't know what the true lift of the cam is and what the true compression is. I guess it's pretty safe to say I don't really no nothing that's in the motor for a fact. Like I said all I know is what someone told me. They also didn't tell us much either. Maybe I should wait untill I tear into the motor and put the leak down test on it and all that other stuff before I start running down through the combo because it wouldn't make a whole lot of sence anyway! So I guess as soon as I find out more deffient answers I will put pics and all the info up and we can go from there!
Re: Oil Experimenting [Re: Sb Valiant] #1359295
12/26/12 03:35 PM
12/26/12 03:35 PM
Before you tear into the motor on inspecting it check the total timing first, write that down Next look at each plug, keep them in order also so you can post some pictures of them on here. Last do the leak down and then the lift at the retainers with the .050 cam timing. BTW, to add onto your engine inspecting plate make sure and check both the intake and exhaust valve lift and timing, post the numbers so we can help you determine if the cam is in straight up, advanced or retarted
Re: Oil Experimenting [Re: Sb Valiant] #1359296
12/26/12 04:43 PM
12/26/12 04:43 PM
MR_P_BODY Offline
MR_P_BODY  Offline
You have WAY TOO MANY variables to even think its oil
Re: Oil Experimenting [Re: MR_P_BODY] #1359297
12/26/12 05:22 PM
12/26/12 05:22 PM
Downtown Roebuck Ont
Twostick Offline
Still wishing...
Twostick  Offline
Still wishing...
Oil is SOOOOOOOOOOOO far down the list of things that could be wrong with your combo....
Kevin
Re: Oil Experimenting [Re: Twostick] #1359298
12/26/12 05:42 PM
12/26/12 05:42 PM
Florida STAYcation
dOOc Offline
The village idiot's idiot
dOOc  Offline
Florida STAYcation
The guy from the 'burbs of Sears, Ontario is ohhhh-sooooo right .. for-once !
Re: Oil Experimenting [Re: Sb Valiant] #1359299
12/26/12 08:16 PM
12/26/12 08:16 PM
North, Alabama
D-50 Offline
D-50  Offline
North, Alabama
I do not think the gears had much to do with your loss of ET. Last year I had a 380 HP 360 crate motor in my D-50.Ran a best of 7.46 at 91 mph with 5.14 gears changed to 3.50 gears and ran a 7.60 at 90 mph.
1.33 60 ft,6.21 at 110.59 in the 1/8, pump gas small block,2950lbs,drag radials,mufflers and driven to track ...
Re: Oil Experimenting [Re: D-50] #1359300
12/26/12 10:54 PM
12/26/12 10:54 PM
Twostick Offline
Still wishing...
Twostick  Offline
Still wishing...
That tells you that you have a well spec'd converter.
Kevin
Re: Oil Experimenting [Re: Twostick] #1359301
12/27/12 03:52 PM
12/27/12 03:52 PM
western PA
western PA
Bingo! That's the problem our converter is not what you call a matched converter for our comobination. It's been under several motors of ours but all 340's. Our first 340 that was way worn out only ran 7.70's 1/8 and it would only stall at 3200 rpm. Another motor who knows what it stalled to because it was a disaster and really never got to find out what anything would do! Now we are on this 340 with the w2 heads. I have personally seen 4000 on the tach on the trans brake in the driveway but it was a cold night and the car kept stalling out. We didn't get a chance to see what it stalled at when we were at the track. Every bit of 4000 that's for sure but I am thinking possibly 4200. So my point is when we changed from a 5.13 gear down to a 4.30 it really hurt performance beccause of the converter. Heck the converter isn't even right for a 5.13 gear but we could get away with it because the gears are so low!!! The lack of performance also comes from a few other things I am not trying to put the entire blame on the converter but it is deffiently one of the things on the list that isn't helping!!! I am doing a leak down test this weekend so I will know alittle more on what shape the motor is in. After that I am going to find out what lift the cam is and what it even is. Also going to get the timing all figured out and set but that will probaly end up doing that last.
