Re: 46re trany ?
[Re: stumpy]
#1358704
12/24/12 10:11 PM
12/24/12 10:11 PM
Posts: 12,419 Kalispell Mt.
HotRodDave
Kalispell Mt.
Hold off pulling the trans, check the temp sensor and LU solenoids as well as the actual engine temp reading of the coolant temp sensor for the computer not just the gauge. All of those are easily checked with a scanner, there are other ways to test them without one but the scanner method is easiest. They can also all be changed without removing the trans.
Re: 46re trany ?
[Re: DAYCLONA]
#1358707
12/25/12 01:27 PM
12/25/12 01:27 PM
Posts: 644 Warner Robins, Georgia
DusterMan
super street
super street
I had a 96 and I believe there was a service bulletin about the front drum not machined correctly. Mine would not go into drive unless you let off the gas.
Pete: 2003 Dodge Quad 2500 Hemi 69 RoadRunner 4 sp Alpine White 2019 Dodge Charger
