Page 4 of 4 1 2 3 4
Re: Scotty/Dustedu's 440 W9 rp [Re: fishy340] #1358694
03/02/13 08:40 PM
03/02/13 08:40 PM
Hilltown Pa
1967dartgt Offline
1967dartgt  Offline
Hilltown Pa
What are you going to get rp now Andy?
Brett Miller W9 cnc'd heads
STR Chassis fabraction
Re: Scotty/Dustedu's 440 W9 rp [Re: 1967dartgt] #1358695
03/02/13 09:51 PM
03/02/13 09:51 PM
LONG ISLAND
fishy340 Offline
fishy340  Offline
LONG ISLAND
Oh hell no,Im EXTREMELY happy with mine that Brett did
Re: Scotty/Dustedu's 440 W9 rp [Re: fishy340] #1358696
03/03/13 11:40 AM
03/03/13 11:40 AM
Louisville, MS
Dustedu Offline
Dustedu  Offline
Louisville, MS
Here's a spreadsheet with numbers copied from dyno sheet, the actual dyno sheet had a higher correction factor than we used on this spreadsheet, after entering the weather data in several calculators we feel this is correct.
Re: Scotty/Dustedu's 440 W9 rp [Re: Dustedu] #1358697
03/03/13 12:29 PM
03/03/13 12:29 PM
PA
W5DART66 Offline
W5DART66  Offline
PA
What was the weather the day/time you tested?
Why did you pull the engine so slow? Build like this should be done at 600 rpm per sec
Slower pull will show more HP most of the time.
I think raw # are closer to what this engine really will make in the car going down the track.
Killer engine anyway you slice it can't wait to see how it runs in the car.
Good job Lavern and Scotty
Re: Scotty/Dustedu's 440 W9 rp [Re: W5DART66] #1358698
03/03/13 02:45 PM
03/03/13 02:45 PM
Louisville, MS
Dustedu Offline
Dustedu  Offline
Louisville, MS
Weather was bad, a front was moving through with severe thunderstorms, Tony was suspicious of the correction factor so we changed it to match calculator. Some of the data is on the sheet...
I would have to ask Tony why he pulled it slow
We' ll see soon what it has on the track, Not Gonna argue...thanks for your insight though
Also need to talk about belt drive gimme a call/ check pm
Re: Scotty/Dustedu's 440 W9 rp [Re: Dustedu] #1358699
03/03/13 04:09 PM
03/03/13 04:09 PM
Hilltown Pa
1967dartgt Offline
1967dartgt  Offline
Hilltown Pa
What are the cc's of the chamber if you know. Thanks
Re: Scotty/Dustedu's 440 W9 rp [Re: 1967dartgt] #1358700
03/03/13 05:18 PM
03/03/13 05:18 PM
Finland
mafo Offline
mafo  Offline
Finland
shouldn't be to hard to get the converter right with that torque curve
-65 Valiant,420", all motor,2700#, dot tires, 8,42 @ 160,2
Re: Scotty/Dustedu's 440 W9 rp [Re: Dustedu] #1358701
03/03/13 10:41 PM
03/03/13 10:41 PM
LONG ISLAND
fishy340 Offline
fishy340  Offline
LONG ISLAND
Nice brother,u can make some quick $ w that.Not many fear sb mopars around here.
Page 4 of 4 1 2 3 4
