73 Dart 340 K-frame #1358386
12/24/12 10:37 AM
12/24/12 10:37 AM
Ohio
jimmyg Offline OP
jimmyg  Offline OP
Ohio
I have a 73 Dart Sport that was a 340 car. I am going to put a big block in it using a motor plate. I this K-frame worth removing and using any a-body k-frame like out of a 6-cyl or is the V-8 k-frame stronger? This is going to be a strictly strip only. Also - I thought 73 was the transition year to tegh 4 1/2 bolt pattern - where 4" BP on the drum cars and 4.5 on the Disk. I must thougth worng as this car has 4.5" BP with drums. - How hard is this to change to disk? will I need new spindles?
Thanks!
Jimmy G 1970 340 Dart Swinger 1971 Charger 1973 Dart Sport
Re: 73 Dart 340 K-frame [Re: jimmyg] #1358387
12/24/12 03:14 PM
12/24/12 03:14 PM
Granite Bay CA
Kern Dog Offline
Striving for excellence
Kern Dog  Offline
Granite Bay CA
The 73-76 A body cars had spool type k members that most enthusiasts agree is superior to the biscuit/pad type. Personally, I'd pull and sell the original and slip in a common 68-72 unit since you plan to use the motor plate.
The brake situation with A bodies is a bit fuzzy, but here is what I have seen in years of 'junkyarding:
67-72 were all small bolt pattern. Most were 9 inch drums on all corners.
73-76 used small bolt pattern when the cars had 4 wheel drums and the larger 4.5 bolt pattern when they had front discs. YES, some cars as late as 1976 did come with front drum brakes with the small pattern. I've seen them and I have owned one: 1976 Dart Swinger 2 door with a slant six.
Here is where your car fits in: The large pattern drums up front probably are from a 62-72 B body since they used a spindle the same size as the disc equipped 73-76 A bodies and they shared the same sized upper ball joint. It is easy to swap a drum assembly in there if the discs were pirated for another project.
Re: 73 Dart 340 K-frame [Re: Kern Dog] #1358388
12/24/12 07:53 PM
12/24/12 07:53 PM
Park Forest, IL
slantzilla Online content
slantzilla  Online Content
Park Forest, IL
I have heard rumors there were some BBP drum brake cars, but I have never seen one myself.
Re: 73 Dart 340 K-frame [Re: slantzilla] #1358389
12/24/12 08:11 PM
12/24/12 08:11 PM
AndyF Offline
AndyF  Offline
BBP drum A-body cars are most likely swaps from a B-body. There isn't a part number for a BBP drum brake A-body setup in the parts book.
