Re: 572 Ray Barton HP guess [Re: Bishop] #1358320
12/25/12 08:49 PM
12/25/12 08:49 PM
Phoenix,Az.
hemicop Offline
hemicop  Offline
Phoenix,Az.
My flat tappet, x-ram 528 Barton Hemi made 829, so I'm guessing 920-935. Ket usknow how it turned out....
Re: 572 Ray Barton HP guess [Re: Bishop] #1358321
12/26/12 11:06 AM
12/26/12 11:06 AM
NC
440Jim Offline
440Jim  Offline
NC
Hopefuuly the 727 will last a little while its got all the best parts A&A has to offer & a Griner brake
Merry Christmas everyone Brian
What 1st gear set did you put in the 727? 2.45, 2.28, 2.10 ?
And did you upgrade the input shaft and hub it attaches to?
http://aandatrans.com/Products/727-Stainless-Steel-Input-Shaft-Hub__22575S.aspx
Re: 572 Ray Barton HP guess [Re: Bishop] #1358322
12/27/12 09:18 AM
12/27/12 09:18 AM
gregsdart Offline
gregsdart  Offline
I run a full rollerized 727, no issues. The killer is nitrous that puts the torque through the roof! Thats when stuff starts to break.
Re: 572 Ray Barton HP guess [Re: gregsdart] #1358323
02/06/13 07:34 PM
02/06/13 07:34 PM
Cincinnati OH
Bishop Offline OP
Bishop  Offline OP
Cincinnati OH
I made it to the shop today @ K&K in Huber Heights Ohio today. A big thanks to Bob & Ted Kammer and Greg on the Dyno. Well it made 895HP @6500 RPM & 781 TRQ @ 4700 It looks like the unmodified Ray Barton Crossman lost 25 HP, ran it to 7000RPM HP fell off slightly. 112 gas and best timing @ 28 degree total. I'll post Dyno sheet later.
Brian
Going in a 68 dart 3400lbs with me in it ET & MPH????
Re: 572 Ray Barton HP guess [Re: Bishop] #1358324
02/06/13 08:25 PM
02/06/13 08:25 PM
Penna
70satelliteguy Offline
Penna
"but we should take bets on how long the 727 last before it splits in two . "
My 572 Wedge B Body at 3550lbs.with single 1250 Quickfuel and Brake has not broke my 727 yet(500 + passes so far) but it also has all of the A&A goodies in it and I check it every year!
"Going in a 68 dart 3400lbs with me in it ET & MPH????"
My heads do not flow anywhere near what yours do and I am able to run mid to low 9"s at 100 lbs. more than you so I would think high 8's should not be a problem.
" best timing @ 28 degree total."
Is this typical for a Hemi ?
Mike
Re: 572 Ray Barton HP guess [Re: 70satelliteguy] #1358325
02/06/13 08:44 PM
02/06/13 08:44 PM
s e mich
ro23car Offline
ro23car  Offline
s e mich
Is this typical for a Hemi vs. a Wedge?
Mike
why do you think the trans will fail?
Re: 572 Ray Barton HP guess [Re: ro23car] #1358326
02/07/13 12:25 PM
02/07/13 12:25 PM
Chicago land, IL
dafixr Offline
dafixr  Offline
Chicago land, IL
We run a 727 in our Duster running 7.60"s in the 1/4.
496 cu in and spray a 500 shot off the brake, we also come out in 2nd gear. No trans problems. JIM
Here is video
https://www.facebook.com/photo.php?v=269...e=2&theater
Re: 572 Ray Barton HP guess [Re: Bishop] #1358327
02/07/13 01:58 PM
02/07/13 01:58 PM
Rudolph, Ohio
moparguy7074 Offline
Rudolph, Ohio
Brian
Are you sure it needed that 112 fuel?
Re: 572 Ray Barton HP guess [Re: moparguy7074] #1358328
02/07/13 07:31 PM
02/07/13 07:31 PM
Cincinnati OH
Bishop Offline OP
Bishop  Offline OP
Cincinnati OH
I'll probabaly run Cam 2 110 I can get it for 6.50 a gallon down the street
Re: 572 Ray Barton HP guess [Re: Bishop] #1358329
02/07/13 08:21 PM
02/07/13 08:21 PM
s e mich
ro23car Offline
ro23car  Offline
s e mich
try c-14
Re: 572 Ray Barton HP guess [Re: Bishop] #1358330
02/08/13 02:05 PM
02/08/13 02:05 PM
Las Vegas NV
moparmanjames Offline
Las Vegas NV
Brian
28 total timing? That's a little low isn't it? Did you mean 38?
Re: 572 Ray Barton HP guess [Re: moparmanjames] #1358331
02/08/13 02:12 PM
02/08/13 02:12 PM
Utah and Alaska
astjp2 Offline
astjp2  Offline
Utah and Alaska
Brian
Hemi's dont like too much timing, most get 32 total, so 28 is realistic. Tim
1941 Taylorcraft
1968 Charger
1994 Wrangler
1998 Wrangler
2008 Kia Rio
2017 Jetta
Re: 572 Ray Barton HP guess [Re: astjp2] #1358332
02/08/13 03:11 PM
02/08/13 03:11 PM
Shelton, Ct.
572_HEMI_Cuda Offline
Shelton, Ct.
c12 and 28 degs is good for that combo.
30-32 if tune-up is on.
