572 Ray Barton HP guess #1358300
12/24/12 02:03 AM
12/24/12 02:03 AM
Cincinnati OH
Bishop Offline OP
Bishop  Offline OP
Cincinnati OH
I have taken my freshened up Ray Barton 572 Hemi to Kammmer & Kammer in Huber Heights Ohio to have dynoed. Anyone want to guess the HP #
MP Cast iron 4.5 bore
Callies 4.5 stroke crank
Oliver 7.1 rods
13 to 1 CR gas ported coating on skirts & top
Stage V custom heads raised exhaust ports 2.375 Ti intake valve
Heads flow 466 & 293 @ .800
RB custom cam .812 intake lift
RB rocker arm system
RB crossram with twin 970 hollies
It will be on the dyno at the beginning of the year then going down in my 68 Dart 727 trans brake 4.10 Dana. Care to guess I keep you updated
PS I was told the motor made 920 HP with a single 1250 Gary william Dominator I woundering if the crossram will add to or decrease the HP?
Car shown racing at Kil-kare @ the Mo-powered event
Re: 572 Ray Barton HP guess [Re: Bishop] #1358301
12/24/12 02:09 AM
12/24/12 02:09 AM
Aurora, Oh.
max_maniac Offline
max_maniac  Offline
Aurora, Oh.
LOL - I never have any idea on guessing HP but I will say it's way more then enough to kick my azz
But just for kicks I'll say 920hp 810tq
Sure will be fun (for you) no matter what so stay away from me next year
Russ
Re: 572 Ray Barton HP guess [Re: Bishop] #1358302
12/24/12 02:14 AM
12/24/12 02:14 AM
PA
moparacer Offline
moparacer  Offline
PA
With dominators and a tunnel ram I would say 900+
So with the 970's and a cross ram I say 850
67 Barracuda street/bracket car 11.27-119
68 Dart 502 BB 8.70s-152
414 cid SB Dragster 7.65-174
Re: 572 Ray Barton HP guess [Re: moparacer] #1358303
12/24/12 10:37 AM
12/24/12 10:37 AM
sing sing
U
unknown Offline
unknown  Offline
U
sing sing
Man I would hope that motor makes more then 900hp.
Re: 572 Ray Barton HP guess [Re: unknown] #1358304
12/24/12 10:47 AM
12/24/12 10:47 AM
Middletown, Ohio
Joes66dart Offline
Joes66dart  Offline
Middletown, Ohio
Slightly more than a Briggs and Stratton!
Re: 572 Ray Barton HP guess [Re: unknown] #1358305
12/24/12 11:19 AM
12/24/12 11:19 AM
NJ-USA
HPMike Offline
HPMike  Offline
NJ-USA
MB
Re: 572 Ray Barton HP guess [Re: HPMike] #1358306
12/24/12 01:07 PM
12/24/12 01:07 PM
Pattison Texas
CSK Offline
CSK  Offline
Pattison Texas
the cross ram will hurt it real bad
Re: 572 Ray Barton HP guess [Re: CSK] #1358307
12/24/12 02:11 PM
12/24/12 02:11 PM
Carson City, Nevada
Biginchmopar Offline
Carson City, Nevada
I'll guess around 935HP.
Re: 572 Ray Barton HP guess [Re: CSK] #1358308
12/25/12 02:53 AM
12/25/12 02:53 AM
Canada
WO23Coronet Offline
WO23Coronet  Offline
Canada
Is this a true cross ram or is it the Ray Barton one that's basically a tunnel ram with a tiny bit of offset between the carbs, kind of like the SS HEMI one?
Re: 572 Ray Barton HP guess [Re: WO23Coronet] #1358309
12/25/12 04:27 AM
12/25/12 04:27 AM
Oologah, Oklahoma
Big Squeeze Offline
Big Squeeze  Offline
Oologah, Oklahoma
What was the motor in before and what it run?
It should easily make enough to get into the 8's....
If you can't handle the truth, you're living a lie.......
Re: 572 Ray Barton HP guess [Re: Big Squeeze] #1358310
12/25/12 09:40 AM
12/25/12 09:40 AM
pa
572charger Offline
572charger  Offline
pa
i would think it would be about 1000 hp with a single dominator tq should be close to 900
606 hemi pump gas best 9.60 at 142mph on motor
05 hemi daytona 1500 go-mango 4wd quadcab
2007 hotrod mag pump gas drags runner up, roadkill nights dodge big tire winner 2018 2019 back to back
Re: 572 Ray Barton HP guess [Re: Bishop] #1358311
12/25/12 10:39 AM
12/25/12 10:39 AM
Ontario, Canada
Dodgem Offline
Dodgem  Offline
Ontario, Canada
I would say 1050 hp and 900 tq
Re: 572 Ray Barton HP guess [Re: Dodgem] #1358312
12/25/12 10:58 AM
12/25/12 10:58 AM
Trumbull,CT.
jim sciortino Offline
Trumbull,CT.
With a regular crossram (not SS style) and mild cam, I'll say around 920.
Re: 572 Ray Barton HP guess [Re: WO23Coronet] #1358313
12/25/12 11:39 AM
12/25/12 11:39 AM
Cincinnati OH
Bishop Offline OP
Bishop  Offline OP
Cincinnati OH
It is a cast Al crossram with a Mopar part # made by Ray Barton
Merry Christmas everyone
Re: 572 Ray Barton HP guess [Re: Bishop] #1358314
12/25/12 02:32 PM
12/25/12 02:32 PM
Sherwood park, Alberta.
go green Offline
go green  Offline
That cross ram will make less power than the single . The engine will work great either way , but we should take bets on how long the 727 last before it splits in two .
6.50 @ 226 MPH 4.25 @ 186 MPH
https://www.youtube.com/watch?v=YX86DHGKBo0
Re: 572 Ray Barton HP guess [Re: go green] #1358315
12/25/12 03:33 PM
12/25/12 03:33 PM
Cincinnati OH
Bishop Offline OP
Bishop  Offline OP
Cincinnati OH
Hopefuuly the 727 will last a little while its got all the best parts A&A has to offer & a Griner brake
Merry Christmas everyone Brian
Re: 572 Ray Barton HP guess [Re: Bishop] #1358316
12/25/12 04:28 PM
12/25/12 04:28 PM
SW Ohio
cgall Offline
cgall  Offline
SW Ohio
Jeff Russell can build you a trans that will live. Merry Christmas to you, Brian. I hope to see your car sometime next year (that would mean I would have to get my own junk running again).
Re: 572 Ray Barton HP guess [Re: cgall] #1358317
12/25/12 05:28 PM
12/25/12 05:28 PM
pa
572charger Offline
572charger  Offline
pa
my 727 all crt parts and griner vb works great last long time no problems in 10 yrs just took it out to freshen !!! 8.90s at 156 at 3910lbs!!! and about8000street miles but i did go through a bunch of name brand convertors!!! till i got a ATI blown fuel convertor !!!
Re: 572 Ray Barton HP guess [Re: 572charger] #1358318
12/25/12 08:04 PM
12/25/12 08:04 PM
s e mich
ro23car Offline
ro23car  Offline
s e mich
what gas are you going to use?
Re: 572 Ray Barton HP guess [Re: go green] #1358319
12/25/12 08:08 PM
12/25/12 08:08 PM
s e mich
ro23car Offline
ro23car  Offline
s e mich
what makes you say the single carb will make more than an xram? just curious not bashing.
