Re: 572 Ray Barton HP guess
[Re: Bishop]
#1358324
02/06/13 08:25 PM
02/06/13 08:25 PM
Posts: 1,301 Penna
70satelliteguy
Penna
"but we should take bets on how long the 727 last before it splits in two . " My 572 Wedge B Body at 3550lbs.with single 1250 Quickfuel and Brake has not broke my 727 yet(500 + passes so far) but it also has all of the A&A goodies in it and I check it every year! "Going in a 68 dart 3400lbs with me in it ET & MPH????" My heads do not flow anywhere near what yours do and I am able to run mid to low 9"s at 100 lbs. more than you so I would think high 8's should not be a problem. " best timing @ 28 degree total." Is this typical for a Hemi ? Mike
[Re: 70satelliteguy]
#1358325
02/06/13 08:44 PM
02/06/13 08:44 PM
Posts: 1,162 s e mich
ro23car
s e mich
"but we should take bets on how long the 727 last before it splits in two . " My 572 Wedge B Body at 3550lbs.with single 1250 Quickfuel and Brake has not broke my 727 yet(500 + passes so far) but it also has all of the A&A goodies in it and I check it every year! My heads do not flow anywhere near what yours do and I am able to run mid to low 9"s at 100 lbs. more than you so I would think high 8's should not be a problem. " best timing @ 28 degree total." Is this typical for a Hemi vs. a Wedge? Mike
why do you think the trans will fail?
[Re: Bishop]
#1358327
02/07/13 01:58 PM
02/07/13 01:58 PM
Posts: 1,608 Rudolph, Ohio
moparguy7074
Rudolph, Ohio
I made it to the shop today @ K&K in Huber Heights Ohio today. A big thanks to Bob & Ted Kammer and Greg on the Dyno. Well it made 895HP @6500 RPM & 781 TRQ @ 4700 It looks like the unmodified Ray Barton Crossman lost 25 HP, ran it to 7000RPM HP fell off slightly. 112 gas and best timing @ 28 degree total. I'll post Dyno sheet later.
Brian
Are you sure it needed that 112 fuel?
[Re: moparguy7074]
#1358328
02/07/13 07:31 PM
02/07/13 07:31 PM
Posts: 915 Cincinnati OH
Bishop
Cincinnati OH
I'll probabaly run Cam 2 110 I can get it for 6.50 a gallon down the street
[Re: Bishop]
#1358330
02/08/13 02:05 PM
02/08/13 02:05 PM
Posts: 1,260 Las Vegas NV
moparmanjames
Las Vegas NV
Brian
28 total timing? That's a little low isn't it? Did you mean 38?
