Re: to replace metal or repair it vs/ value.
[Re: JohnRR]
#1357905
12/24/12 02:27 PM
12/24/12 02:27 PM
Posts: 18,582 Rust Belt, SW PA
Silver70
Rust Belt, SW PA
For the cost, sometimes is cheaper to just replace the panel. On my own cars, I keep as much as I can. If it's a car for someone else, then I let them decide.
68 Road Runner, 69 Belvedere, 71 Challenger Vert 340 barracuda, 01 Ram CTD, 95 Ram, 04 Ram, 85 Daytona turbo Z 66 GTO, 06 Magnum RT AWD. 07 Ram CTD, 07 Ram
[Re: Silver70]
#1357906
12/24/12 04:16 PM
12/24/12 04:16 PM
Posts: 454 Ashville, Manitoba, Canada
superbeeman69
super street
super street
The customer is always right! Haha! For my own vehicles, I have my own list of criteria I use. Can it be repaired so that it would be impossible to tell from either side that it had been? I sometimes let the value of the vehicle dictate what KIND of panel I replace it with if that is the desired route. Keep in mind, a 100k resto doesn't always make the car a 100k car....NOS 1/4s on a 73 satellite is a bit of a waste IMO but a V code cuda deserves at LEAST AMD, if not NOS. If a small patch panel is required on a car like that, then I think a hand fabbed, butt welded and metal finished patch is in order to keep from disturbing OEM spot welds as well as retaining as much of the original metal as possible.
1970 FM3 Coronet 440, 1971 FJ6 Dude D100
[Re: ek3]
#1357908
12/24/12 08:15 PM
12/24/12 08:15 PM
Posts: 768 Dry Heat AZ
AAR#2
Dry Heat AZ
That's a tricky subject but one that is ultimately best made by the owner of the car and the body man (if its not the same person). Remember a little rust in 3 sections of a relatively good 1/4 could cost a lot to repair and at what point do you own Abe Lincoln's axe?
Consider the craftsmanship of the shop, cheap scab patch with a fancy fill or true craftsmen that uses minimal fill because his work is shaped properly and welded like he took time and cares. Good work does not come cheap, repaired or replaced panels.
Also consider what could be hiding behind some marginal panels, less a borescope you may not know what danger was lurking until 2 years after your 10k paint starts to show blisters in an area that wasn't inspected and treated correctly.
What type of car, what type of restoration, and your budget and or business sense may all play factors in your decision. As previously stated, 100k Resto may yield a 30, 50, or 80k car
And remember to do your homework, no one ever takes their car to a bad body shop, but plenty can tell stories of picking their car up from one
Good luck whatever you decide !
[Re: ek3]
#1357909
12/24/12 08:32 PM
12/24/12 08:32 PM
superbeeman69
super street
super street
thats what i was thinking. a v code car should keep as much factory metal as you can. does it hurt value to replace the whole panel . how much does it normally reduce values ? i just want to do it the best way . not what someone thinks but, the accepted normal [if there is such a thing]way to repair the metal to the best standard.
I'm sure the answer to your question is a matter for debate after the holidays lol opinions will vary based on car, size and location of patch, technique of repair, etc. I don't think there is a widely accepted way of doing what you want to do...some of the best body men I know make flawless patches and TIG weld them in. If I had my choice of making and installing a patch, that's how I do it. Again, when panel replacement comes into play, I like to use a squeeze type resistance spot welder to duplicate the OEM plug welds but those methods are by no means industry standard if there is such a thing.
Do you have pics of what your referring to? Personally if we're talking about a V code cuda, I'd want a new panel hung if it were rotted to the wheelhouse. I wouldn't bother saving the upper portion. I know some people would. Does that hurt value? Maybe on a historic 1 of 1 but those cars have been found and restored a couple times already. Even I can't say for sure which route I'd take without taking quite a few variables into consideration.
EDIT: spoken like a true body guy I am, sorry! I'm not used to taking money/cost into cosideration when I do something but to the OP....at (enter stupid shop rate here) per hour, replacing the whole panel is wayyy cheaper 95% of the time than patching it, quality patches or metal tape and mud. Time isn't cheap unless your doing it yourself. I love working deals amongst tradesmen for this reason lol
[Re: ek3]
#1357912
12/27/12 02:30 PM
12/27/12 02:30 PM
Silver70
Rust Belt, SW PA
thanks for input guys. i know it is big $ to patch in and mabe less to put in full panels. i personaly think full panels will insure a no rust deal. i just wondered if that was a value killer in your opinions. would'nt most of you agree that a true v code car needs to keep as much of its orig. sheet metal as posb. i was just getting some opinions on it. kind of an all things considered i would pro/ cons...
That's another factor too... sometimes no rust may be showing yet, but could come out soon. I had some pin holes scattered on the ps of my challenger, although it looked fixable, I just replaced the entire lower section. The last thing I want is to paint it, then have to redo it again in a year.
[Re: Silver70]
#1357913
12/27/12 04:47 PM
12/27/12 04:47 PM
Posts: 15,134 Kelowna, B.C. Canada
DPelletier
I always patch vs. replace but it needs to be done properly (butt welded and ground smooth) with all pitted or rusty metal removed. I think it's important to keep as much of the original (and solid) sheet metal as possible. Dave
1970 Super Bee 440 Six Pack
1974 'Cuda
2008 Ram 3500 Diesel
2006 Ram 3500 Diesel
2004.5 Ram 2500 Diesel
2003 Ram 3500 Diesel
2006 Durango Limited
[url] http://1970superbee.piczo.com [/url]
[Re: flypaper]
#1357915
12/27/12 09:05 PM
12/27/12 09:05 PM
OLD318
Just my 2 A car wearing its original panels is always worth more than one with repro sheet metal all other things being equal... Others will not agree.... but that's cool...
[Re: flypaper]
#1357919
12/29/12 10:54 PM
12/29/12 10:54 PM
Posts: 1,899 MYRTLE BEACH SOUTH CAROLINA
ek3
are you asking if one kind of repair will create/hold more value then another kind of repair? i would say no the quality of work done to the car would matter more..
yes, thats exactly what i would like to know. on one hand it seems like factory metal is original and is the best metal and any replacement is no longer factory. on the other hand , if you spend big money on the car and there is no way to tell how much rust may be behind the quarters without removing them and you remove them to check, you lost the factory welds. it goes on and on. i am curious what real "worthy cars" have done in this situation. most likley they are put back with new metal ? i know this can go on and on , i dont want to cause a lot of head butting on this .. just a general opinion from the many knowlageable people on this site. thank's...
[Re: ek3]
#1357921
12/30/12 12:20 PM
12/30/12 12:20 PM
Posts: 18,632 jersey shore
flypaper
I hate Texas
I hate Texas
jersey shore
i say it really doesn't matter to most people. when a car is off survivor status and its a restored car for sale most people don't not care about the path traveled they only care about the end result in front of them. a missing fender tag would bother them and they wouldn't have a thought about how many patches were on the car..
[Re: DAYCLONA]
#1357922
12/30/12 01:42 PM
12/30/12 01:42 PM
Posts: 1,896 New England
Q5_Ed
New England
Either hang the NOS on the car, or the wall, or sell it, carve those rusted turd qtrs off the car and replace both with NOS and or AMD, you'll be glad you did, leave the patches in the trash where they belong
Mike
How would you go about fixing these relatively rust free, but cut wheel lip area spliced in not so good job?s?
WANTED : ...A New Sponsor or Winning Lottery Ticket
69 A12 road runner ,Q5, post coupe, 4 speed, former Drag car restored to "Driver" condition in the early 90's, Showing some Patina. SS/E Track Record Holder 1980 10.40 @ 130mph
