I plan to remove the master cylinder from a 1973 Dart this winter. I would like to cap the lines to prevent brake fluid from dripping on the inner fender and damaging the paint. As I understand, inverted flare caps are not available. As a workaround in the past, I have used a union and a plug. I believe the master cylinder ports are 1/2-20 and 9/16-18. A 1/2-20 union and plug is readily available, but I am having trouble locating a 9/16-18 union and plug. Anyone know of a source for these fittings?
