SB: What heads?? #1357663
12/23/12 03:29 PM
12/23/12 03:29 PM
Texas Afghanistan Iraq etc.
DakFink Offline OP
DakFink  Offline OP
Been looking and talking and contemplating New heads for a Magnum Based engine I want to build.
I'm looking for a set of heads that will fill the bill but not be overkill or fall short either.
Here's what I'm planning.
4.250stroke x 4.040 bore
7000rpm redline
Pump Gas
10.5-11.5:1 compression
Roller Cam
Vehicle:
4000lbs
4.56gears
28" tires
currently 3200 stall convertor
Looking to build a HOT Street motor, Red Light Bruiser/Cruiser.
IF it ever sees the track it would be every once in a while.
The heads I have looked at so far are:
Edelbrock Magnum
Airwolf 220's
Indy 360-1
What say YE!
Re: SB: What heads?? [Re: DakFink] #1357664
12/23/12 04:06 PM
12/23/12 04:06 PM
SoCal
Brian Hafliger Offline
SoCal
Indy -1 is THE only way to go for serious power with that combo!
Brian Hafliger
Re: SB: What heads?? [Re: Brian Hafliger] #1357665
12/23/12 04:08 PM
12/23/12 04:08 PM
SoCal
SoCal
Here's a pic of David Deans heads I did for him:
Re: SB: What heads?? [Re: Brian Hafliger] #1357666
12/23/12 04:11 PM
12/23/12 04:11 PM
SoCal
SoCal
Re: SB: What heads?? [Re: Brian Hafliger] #1357667
12/23/12 04:18 PM
12/23/12 04:18 PM
DakFink Offline OP
DakFink  Offline OP
Figured that!!
I'm just going to have to cough it up and fork over the $$$$ when I finally get around to it!!
I'll probably be calling you none the less!!
Thanks Brian
Re: SB: What heads?? [Re: DakFink] #1357668
12/23/12 04:24 PM
12/23/12 04:24 PM
SoCal
SoCal
More pics
Re: SB: What heads?? [Re: DakFink] #1357669
12/23/12 04:25 PM
12/23/12 04:25 PM
Saskatchewan (SK)
79410aspenrt Offline
Saskatchewan (SK)
I will be doing the same when $$$$ is flowing again. I need the 360-1 real bad to push 3800 lbs down the 1320!
Stop with the pictures Brian!!!!
Re: SB: What heads?? [Re: 79410aspenrt] #1357670
12/23/12 05:04 PM
12/23/12 05:04 PM
long island newyork
Abodyjohn88 Offline
Abodyjohn88  Offline
long island newyork
If it has to be one of those 3 heads than defanitly the Indy...but what ahout a.w8 or w9?
Re: SB: What heads?? [Re: Abodyjohn88] #1357671
12/23/12 05:34 PM
12/23/12 05:34 PM
SoCal
SoCal
Only real problem with the W8-W9 is you really NEED a 48° block.
But I agree, W9 would be nice. I'm this close (thumb and forefinger almost touching) to having Sam at TTI do headers based on the W9 casting.
He's waiting for me to do an engine, supply the car and then mockup for it. This would be just like their LA and W2 headers, but 2" and 3.5" collector.
Once that happens, it'll be much cheaper and easier to do W9's in an A body!
Until then, it's a bit more costly to do than Indy heads.
I'm sure once the Victor heads arrive, they'll be good but I expect shortcomings as with all newly released mopar heads.
Brian Hafliger
Re: SB: What heads?? [Re: Brian Hafliger] #1357672
12/23/12 05:38 PM
12/23/12 05:38 PM
Renton Washington
Triple Threat Offline
Renton Washington
Brian can you share the flow numbers on those -1's? Did they start as 245's?
-Dustin
67 Dart, 9 second, 392" G3 Hemi
68 Barracuda 340 F/SA
Re: SB: What heads?? [Re: Triple Threat] #1357673
12/23/12 05:44 PM
12/23/12 05:44 PM
SoCal
SoCal
I can, but I won't have them until Wed. as we are closed mon. and tues.
They topped out at .750 lift at 360 something, and stayed there, did not lose flow after that up to 1".
At .500 I believe they were 316 or 318. I used a 2.125 x 5/16 intake valve, angle milled them down, our valve job, some short turn work, slight bowl work and chamber work.
This was a 245cnc intake port, but I did the ex. port and chamber myself. I don't like Indy's ex. port and chamber at all.
Brian Hafliger
Re: SB: What heads?? [Re: Brian Hafliger] #1357674
12/23/12 06:45 PM
12/23/12 06:45 PM
Big Western Pencilveinya
U
Uncle Barry Offline
Uncle Barry  Offline
U
KEEP US POSTED ON THIS!
Re: SB: What heads?? [Re: Uncle Barry] #1357675
12/23/12 07:00 PM
12/23/12 07:00 PM
Pa
Hot 340 Offline
Hot 340  Offline
Pa
X2 keep us posted!
Re: SB: What heads?? [Re: Abodyjohn88] #1357676
12/24/12 01:53 PM
12/24/12 01:53 PM
DakFink Offline OP
DakFink  Offline OP
I have W9's sitting on my shelf BUT the cost even cutting corners where I can it still adds up fast and exceeds what I could do with Indy.
As Brian said I would need to get a 48* block at $2200-2600 ad $2000 for machining that it will need. Ad $250-300 for AN Hoses and Fitting for cooling. $200-250 for an AN to Radiator Manifold, $1350 for T&D Rockers, $400-500 for an oil pan, $600-700 for Lifters, $500-800 for Lifter Bushings. ETC ETC!!!
When I have pretty much everything except the rotating assembly and heads. That's a lot of money I shouldn't have to be spending for what I want to do.
OH and the fact that the W8&9's have no place on them to mount Accessories of any kind. At least the Indy's come with LA mounting holes and the Magnum holes can be added (or even ordered from Indy) as needed.
Re: SB: What heads?? [Re: DakFink] #1357677
12/24/12 02:51 PM
12/24/12 02:51 PM
Renton Washington
Renton Washington
I'm sure you're well aware of a stock blocks limitations. I'm not sure building a 435" engine with a stock block and -1 heads is the best idea ever.
-Dustin
Re: SB: What heads?? [Re: Triple Threat] #1357678
12/24/12 03:35 PM
12/24/12 03:35 PM
DakFink Offline OP
DakFink  Offline OP
Don't beat on it like a redheaded step child and it should last a while!!
As I stated in my first post this won't be a Race/Drag car!! Just a cruiser with some UMMPH!!
Plus I have an extra already on the floor of the garage and can pick them up all day long for $600 or less.
Re: SB: What heads?? [Re: DakFink] #1357679
12/24/12 04:40 PM
12/24/12 04:40 PM
Weddington, N.C.
Streetwize Offline
Streetwize  Offline
Weddington, N.C.
Going along with the previous comment, when you have killer heads and big cubes for a stock block, the best advise I can offer is to slightly under-cam the combo, you'll still have massively satisfying torque and power but by limiting the peak torque RPM you'll resist the temptation to over-rev it and beat the block to death.
Opinions vary, but that's the way I'd do it.
WIZE
In Car:
Re: SB: What heads?? [Re: DakFink] #1357680
12/25/12 01:47 AM
12/25/12 01:47 AM
Renton Washington
Renton Washington
That's why I build them Hope you can show more restraint than I would.
Re: SB: What heads?? [Re: Triple Threat] #1357681
12/25/12 03:19 AM
12/25/12 03:19 AM
long island newyork
Abodyjohn88 Offline
Abodyjohn88  Offline
long island newyork
Brian what valve angles are the Indy heads?
Re: SB: What heads?? [Re: Abodyjohn88] #1357682
12/25/12 03:27 AM
12/25/12 03:27 AM
Lubbock,TX
DavidDean Offline
DavidDean  Offline
Lubbock,TX
I think mine are 2.150 & 1.60. They work VERY well for me and Brian's ports don't leak water.
