Re: 440 Six Pack carb questions
[Re: lewtot184]
#1357604
12/23/12 02:17 PM
12/23/12 02:17 PM
Posts: 238 Florida, US
72ls5fla
Florida, US
I seemed to remember the center flowing around 350 CFM ....
The end carbs maybe 400 CFM each .....
I think 1350 is to high of a number.
Got me a NEW Project 1970 GTX 440+6, 4 spd, 4.10 Dana and N96 FE5 (top/bottom) and black bucket interior. Original transmission and Dana - Engine is a service replacement block.
Body has all stamped #s + VIN/TRIM tag and door sticker. Been hunting like all hell to find the Build Sheet.
garage find, only had 41,850 miles on ODO.
[Re: mikemee1331]
#1357607
12/23/12 04:21 PM
12/23/12 04:21 PM
Posts: 959 Chicago
PurpleBeeper
Chicago
Here's the deal... the outboard carbs are both rated at 500cfm and the center carb is rated at 350cfm for a total of 1350cfm. However... 2-barrels flow are rated differently (more favorably) than 4-barrels (something about pressure drop and inches of mercury I can't exactly recall). So, to compare 2bbls. to 4bbs. directly you have to make a calculation adjustment.
Here's a quote from someone much smarter than me:
To convert: multiply 2 bbl. rating by 70.71% to get flow at the 1.5" (lower) vacuum 4 bbl. rating. Multiply the 4 bbl. rating by 141.4% to get the 3" 2 bbl. rating. The formula is simple: New flow rate = (new vacuum level ÷ old vacuum level)^.5 × old flow rate 500 2 bbl. flows 353.55 CFM at the 1.5" vacuum level.
Another way to look at this is multiply the 2bbl rating x 0.7071
So 1350 x 0.7071 = roughly 955 cfm for a six pack in 4bbl. terms.
70 Roadrunner convt. street car
440+6, NOS, 4-spd, SS springs
'96 Mustang GT convt. street car
'04 4.6 SOHC, NOS, auto, lowered
"Officer, that button is for short on-ramps"
[Re: B5 Bee]
#1357608
12/23/12 06:03 PM
12/23/12 06:03 PM
Posts: 3,916 usa
lewtot184
usa
Holley rates 2bbls differently. The 2bbl rating for the Six Pack is 1350, 2x500 outboards, 350 center.
To get an idea of the outboard flow rated like a 4bbl, the throttle bore and venturi is the same as a 750DP. So just the 2 outboards total 750cfm. The center 350 is estimated to have a 4bbl rating of 230-240. Total Six Pack flow is 980-990.
venturi and throttle bore sizes for the end carbs is the same as an 850 4bbl; 1 9/16" venturi and 1 3/4" throttle bores. the original end carbs were rated at 390cfm each. the center was 250cfm.
[Re: lewtot184]
#1357609
12/23/12 07:41 PM
12/23/12 07:41 PM
Posts: 8,020 Pangaea
B5 Bee
Pangaea
I stand corrected, I just measured an end carb. The throttle bores are 1 3/4" but the venturi is not 1 9/16", it's 1 7/16". Holley made a 2300 carb with the same specs and it was rated 650cfm. The #6425 attained a big part of it's 650cfm flow from the lack of boosters.
[Re: B5 Bee]
#1357610
12/23/12 08:37 PM
12/23/12 08:37 PM
Posts: 3,916 usa
lewtot184
usa
the carb in the picture isn't mopar. it was a very special 2bbl for the guys who had to run "2bbl only" classes, like in roundy-round racing. they're kinda rare. fuel comes out of the venturi walls rather than thru a booster. eliminating the booster allowed for greater air flow.
