throttle response - which carb has the best? #1357563
12/23/12 04:02 AM
12/23/12 04:02 AM
Lethbridge, AB, Canada
dangina Offline OP
dangina  Offline OP
I've used the old carters on previous mopars, and quite frankly I never liked the lack or response or that 1-2 sec delay when you put down the gas. i have a edlebrock 600 cfm kicking around on an engine and i also have a holley 750 cfm double pumper, both needing a rebuild - i haven't tried out either one yet so I can't comment on performance, so I thought what is the best out there? I love the instant throttle response of fuel injected cars so i would like to get the best I can. Is it worth rebuilding the edlebrock or the holley or should I just end up selling them and getting something better. It will be going on my 383 4 speed, 3:55 gears, relativly stock build other than cam, intake and headers.
heres the catch, In about a year I'll be doing a 451 stroker, So I probably will have to upgrade anyways for the build probably an 850. I just wanna hear some opinions on your experiences with carbs...
sorry I should mention the car is a pro-touring car that is daily drivin during the spring & summer, while getting in some autox and road race when possible...
Re: throttle response - which carb has the best? [Re: dangina] #1357564
12/23/12 07:18 AM
12/23/12 07:18 AM
Janesville, WI
SpareParts Offline
SpareParts  Offline
Janesville, WI
Had a Quick Fuel 850 annular booster double pumper on my 360 once, now on my brother's stout 318. Carb is extremely responsive, previously we had it on a 437" sbc nitrous motor.
Re: throttle response - which carb has the best? [Re: SpareParts] #1357565
12/23/12 09:11 AM
12/23/12 09:11 AM
Mississippi
Mr. T Offline
Mr. T  Offline
Mississippi
Between the two you have, I would go with the Holley. I bracked raced for years using a 750 D.P. I finally wore it out. I am currently using a QuickFuel 680 vacuum secondary, and am very well pleased with it on my 360. I would recommend it for your use. The electronic choke would probably come in very handy on those cool Canadian days.
Re: throttle response - which carb has the best? [Re: SpareParts] #1357566
12/23/12 09:52 AM
12/23/12 09:52 AM
Andrews,In. U.S.of A.
67_Satellite Offline
Part of the reason such a large-for-c.i. carburetor,like that 850 on a 318, has such good throttle response is that it will allow much more air into the engine for a given pedal movement. If you press the pedal "X" amount with a small throttle blade, then try it again,the same amount with a much larger throttle blade,the larger throttle blade will drop the manifold vacuum further. Less vacuum = more cylinder pressure = more throttle response. How far the cable mounting point is from the centerline of the throttle shaft will also affect the amount of opening for a given pedal movement.
Re: throttle response - which carb has the best? [Re: dangina] #1357567
12/23/12 11:01 AM
12/23/12 11:01 AM
The Netherlands
BigBlockMopar Offline
The Netherlands
1-2 seconds? Sounds more like the operator needs a tune-up first.
Re: throttle response - which carb has the best? [Re: BigBlockMopar] #1357568
12/23/12 07:50 PM
12/23/12 07:50 PM
Cab_Burge Online work
Cab_Burge  Online Work
The accelerator pump adjustment arm and squirter size should be check now
Re: throttle response - which carb has the best? [Re: dangina] #1357569
12/23/12 08:32 PM
12/23/12 08:32 PM
Denison,Ia.
Cuda367 Offline
Cuda367  Offline
Denison,Ia.
I wish I could give you a personnel experience, but I can't. I am very interested in the new Street Demon carb. If it works as it should, I beleive it has all the street demands for a less than 400 inch motor meet in spades. When right the old thermo quad was almost unbeatable, and they took that tech and tried to solve the short comings. I just wish they offered it bigger. At 750 or so it could be unreal as a street strip carb.
Re: throttle response - which carb has the best? [Re: Cab_Burge] #1357570
12/23/12 08:57 PM
12/23/12 08:57 PM
dangina Offline OP
dangina  Offline OP
the operator does need a tune up first! The carter and thermoquads i use to have weren't bad carb's - They weren't that responsive off the line - I'd even take it to a tuner and I'd still get a delay of 1/2 second or so when you stop on the gas before the engine kicked in. Although I do admit the old motors were pretty close to stock, I'm looking at a better response time, as instant as possible. I'm still going to take it to a tuner when the engine is in
Re: throttle response - which carb has the best? [Re: dangina] #1357571
12/23/12 09:06 PM
12/23/12 09:06 PM
MR_P_BODY Offline
MR_P_BODY  Offline
The smaller the carb is, the more responsive it will
be but it also hurts HP so you have to come up with
a balance... with a 1050 on my 405ci I dont have a
problem because I dont foot brake.. so I am up in
the revs soon enough using the trans brake... I have
a 850 Holley on my 416 street car and it reacts quickly
Re: throttle response - which carb has the best? [Re: MR_P_BODY] #1357572
12/23/12 09:37 PM
12/23/12 09:37 PM
nielsville, minn.
Q
quickd100 Offline
quickd100  Offline
Q
nielsville, minn.
My old 750 Carter AFB had explosive throttle response. My 2 850 thermoquads on the tunnelram are just as good if not better.Dave
Re: throttle response - which carb has the best? [Re: quickd100] #1357573
12/23/12 10:00 PM
12/23/12 10:00 PM
MR_P_BODY Offline
MR_P_BODY  Offline
And if you put 2 2bbls on that tunnel ram it would
be MUCH faster responding... its just a matter of
how much air you move through the venturi per RPM
Re: throttle response - which carb has the best? [Re: MR_P_BODY] #1357574
12/24/12 12:12 AM
12/24/12 12:12 AM
Downtown Roebuck Ont
Twostick Offline
Still wishing...
Twostick  Offline
Still wishing...
If there is any discernible lag in response to pedal input, and your tuner is OK with it, you need a new tuner. Unless of course you have major flaws in your combo that the tuner has pointed out and you haven't addressed ie too much cam and not enough converter or gear.
Kevin
Re: throttle response - which carb has the best? [Re: dangina] #1357575
12/24/12 01:35 AM
12/24/12 01:35 AM
MD
Kevins493 Offline
Kevins493  Offline
MD
If they're set up right they work just fine. Been 1.34 60' with 2 eddy 750 performer (AFB style) carbs. Car will 60' as good or better than most dominator/backhalf/4 link type cars that run the same et.
Re: throttle response - which carb has the best? [Re: Kevins493] #1357576
12/24/12 08:34 AM
12/24/12 08:34 AM
gregsdart Offline
gregsdart  Offline
Throttle response on a constant flow FI setup is so great because with no accelerator pumps the idle has to be so rich that alky actually puddles on the intake valves. It doesn't get much better than that. The reason I mention it is a fat idle in a carb will help a bit also. Of course with gas you have a narrower tuning/HP window, so finding the perfect combo of idle/accelerator pump/carb size can be pretty tricky. But I can see why D100s Hemi responds so well. Two small venturis to maintain decent AFR as it transitions from off idle to full jet flow to secondary opening. Not to mention his tuning skills.
Re: throttle response - which carb has the best? [Re: Mr. T] #1357577
12/24/12 09:40 AM
12/24/12 09:40 AM
dangina Offline OP
dangina  Offline OP
thanks for the great info guys! Maybe I should just stop playing around with rebuilds and start off new...I read that the smaller ones will get you better response but sacrifices hp, but I've also read the 383's respond better with bigger carbs when you swap out the cams and intake. Its an 71 rr air grabber car I don't know if that helps i the decision making...
I thought about getting a carb with an electric choke for our cooler springs/falls. I never have owned one and was curious how do they work? Do you just have it on a switch and turn it off when your car is warmed up?
Re: throttle response - which carb has the best? [Re: dangina] #1357578
12/24/12 10:49 AM
12/24/12 10:49 AM
nc
E
emarine01 Offline
emarine01  Offline
E
nc
Annular boosters w/any double pump
Re: throttle response - which carb has the best? [Re: emarine01] #1357579
12/24/12 11:00 AM
12/24/12 11:00 AM
Northport, al.
tvt59 Offline
tvt59  Offline
Northport, al.
On my bracket cars I always used 1 to 1 linkage on them. After sorting them out They revved like a fuel injected car. They worked good on the street also. Just could not get any fuel mileage with them.
Re: throttle response - which carb has the best? [Re: tvt59] #1357580
12/24/12 12:39 PM
12/24/12 12:39 PM
Rittman Ohio
fourgearsavoy Offline
Rittman Ohio
Some good features on this carb and it might be big enough for your application
http://www.demoncarbs.com/1900.asp
Gus
64 Plymouth Savoy
Dana 60
Re: throttle response - which carb has the best? [Re: dangina] #1357581
12/24/12 02:36 PM
12/24/12 02:36 PM
My 383 dart has a Holley 1850 that I added a electric choke on it, I hooked the positive feed wire to the ignition circuit that feeds the coil resitor that way it is on as soon as I start the car, it work great after I got it adjusted properly
As far as your hesitation your experiencing, all cars should have no discernable hesitation in nuetral or in gear If you do there is a problem, not neccessarily you But the carbs. do All things mechanical can go bad and be faulty, but they can be fixed also I've seen carbs. act up with old gas in them, some wouldn't even start without priming them with fresh gas or starting fluids
Re: throttle response - which carb has the best? [Re: dangina] #1357582
12/24/12 02:45 PM
12/24/12 02:45 PM
Ontario, Canada
Dodgem Offline
Dodgem  Offline
Ontario, Canada
383 4 speed hands down the 750 DP and it will be great on the 451 stroker too!!!!
