Looking in a
HOLLANDER interchange manual - it looks like '72 was the last year for a big u-joint E-body driveshaft.
1973-'74 Barracuda/'Cuda -
ALL43-25/32" lg. x 3-1/4" dia. w/727 & 8-3/4" rear axle part #2996134 (also used in some '71-'72s w/small u-joints)
47-7/8" lg. x 3-1/4" dia. w/904 & 8-3/4" rear axle part #2996138 (also used in some '71-'72s w/small u-joints)
Factory E-body 4-speeds (PP833) are the same lenght as 727s & use #2996134
Factory E-body 3-speeds (PP230?) are the same lenght as which automatic transmission?
