Page 1 of 3 1 2 3
440 source roller rockers #1357046
12/22/12 01:44 PM
12/22/12 01:44 PM
maryland
buck440 Offline OP
buck440  Offline OP
maryland
anyone using them likes dislikes? lookin for opinions thanks in advance.
Re: 440 source roller rockers [Re: buck440] #1357047
12/22/12 01:45 PM
12/22/12 01:45 PM
Utah, USA
1964superstock Offline
Utah, USA
Don't use them. You will regret it. The roller bearing will fall apart and dig into the shaft. Poor quality part.
Re: 440 source roller rockers [Re: 1964superstock] #1357048
12/22/12 02:23 PM
12/22/12 02:23 PM
Cleveland, Ohio
BB73Challenger Offline
Cleveland, Ohio
Got a set OFF a motor just in time.
One was starting to crack at the shaft. I shutter to think of it.
The best advice is not to cheap out here. Not that anything about the hobby is "cheap".
Re: 440 source roller rockers [Re: BB73Challenger] #1357049
12/22/12 03:11 PM
12/22/12 03:11 PM
Virginia Beach, VA
O
Old School Offline
Old School  Offline
O
Virginia Beach, VA
why do people keep buying this junk? by the time you buy theese, then replace them with others, it would be cheeper in the long run to buy good ones from the start. not to mention the cost to repair the damange caused by the failure of junk.....
68 cuda formula S 588" bb 5sp
70 CUDA CONVERT 500" 5SP (SUBLIME)
70 CUDA CONVERT 500" 5SP (PLUMCRAZY):TOO MUCH HORSEPOWER, IS ALMOST ENOUGH!
Re: 440 source roller rockers [Re: Old School] #1357050
12/22/12 03:31 PM
12/22/12 03:31 PM
lancaster,california
johnnycuda Offline
johnnycuda  Offline
I agree,they're junk,I put a set on mine when I first assembled motor,put it on the dyno,2 froze/locked up on the shaft during warm up,bent a pushrod,broke a lifter...yes,pushrod length was correct.as was oil pressure etc.
1970 'Cuda,Lime Light,499 Indy S/R's 10.70's @125,street driven ALOT!
1966 Barracuda 360,now a 5spd,Hemi Orange,Hot Rod Air,
New daily driver-2003 Ram 2500 Cummins 5.9
'69 Valiant 2-dr, sleeper!
New project---1938 Dodge truck, plan is a 360 with a A500, AC, Calvert rear susp., rack and pinion front with coils.
Re: 440 source roller rockers [Re: buck440] #1357051
12/22/12 03:40 PM
12/22/12 03:40 PM
So Cal
Sinitro Offline
Sinitro  Offline
So Cal
Pay now or pay later...
Just check the stress/workload the valve train has to handle..
Next bring up the RPM....
Not the place to cut corners, use quality components...
Just my $0.02...
Re: 440 source roller rockers [Re: Sinitro] #1357052
12/22/12 04:04 PM
12/22/12 04:04 PM
Pittsburgh PA
Eric Offline
Eric  Offline
Pittsburgh PA
I bought a set a few years back...looked at them and desided they we not what i would use on a race motor. I had HS on the Duster and for years Crane Golds on the Arrow...the Cranes held up well but I did go back to HS this year.
5.53 @ 125 1/8th on the launch control..more left in her!
Re: 440 source roller rockers [Re: buck440] #1357053
12/22/12 06:50 PM
12/22/12 06:50 PM
North Carolina
Mopar dragster Offline
North Carolina
I like a lot of their stuff and use it, but rockers, lifters, locks, and retainers are NOT the place to go cheap. 440source has made Mopar performance parts affordable, but you have to use discretion in how they will be used and which parts you are actually considering.
Please see my brother Darrell Kiger at Wyo Racing and Rods for all of your drag car fabrication and restoration needs. From Pro Mod to concours restorations, he is the man. (336)463-4309.
Re: 440 source roller rockers [Re: Mopar dragster] #1357054
12/22/12 11:13 PM
12/22/12 11:13 PM
Vista, California
67Satty Offline
67Satty  Offline
Vista, California
I've been running their rockers for a couple years and so far no problems. 28 runs and lots of street miles so far. Maybe they are holding up because my spring pressures are low - 130 seat and 320 open?
Re: 440 source roller rockers [Re: 67Satty] #1357055
12/23/12 04:26 PM
12/23/12 04:26 PM
maryland
buck440 Offline OP
buck440  Offline OP
maryland
well thanks fella's for the input not what i wanted to hear but hey thats life right lol..
Re: 440 source roller rockers [Re: buck440] #1357056
12/23/12 04:51 PM
12/23/12 04:51 PM
Holly/MI
Dean_Kuzluzski Offline
Holly/MI
Some guys were talking about the "PRW" brand rockers a few weeks ago. Dunno what the consensus ended up being on those. It didn't sound all bad.
I have been bidding on some old Crane/Isky/Erson ductile iron rockers on Ebag for a few weeks now. They've gone up and the price of new is pretty startling.
Soooooo, I just got some Harland Sharps from Mancini Racing. These are the "Exclusive" ones, supposedly, only available from them. They advertise them as a "bushed type" but there's NO bushing just a "non-roller" set-up. Which is OK by me since I'm not going over .600 lift for my deal. The shafts look real nice, appear to be hard-chromed and very thickwall (less flex).
So, for a little more than the PRW's, I bought an American made (as far as I know) rocker system that will not disintegrate under useage.
Re: 440 source roller rockers [Re: Dean_Kuzluzski] #1357057
12/23/12 07:46 PM
12/23/12 07:46 PM
Crane use to call those type rockers "Extruded aluminum roller tip rockers" They will break on the bottom if misused, roller cam with a lot of spring pressure(600+ lbs) and RPM(6000+ RPMs)
OP, I bought several sets of CAT brand alumimun full roller rockers arms(Harland Sharp Chinese clones ) several years back before it became known that they where not that great I put one set on a set of Speed Pro H.D. chromed rocker shafts in a solid roller lifter cam motor, the rollers ate the shafts up real quick I have since bought several sets of the 440 Source roller rocker shafts so I can use those rockers on a hydraulic lifter motor for myself with 350 Lbs open pressure, I'm hoping that works out If not they all (four sets)go in the trash
Re: 440 source roller rockers [Re: buck440] #1357058
12/23/12 08:26 PM
12/23/12 08:26 PM
Akron, Ohio
ProSport Offline
ProSport  Offline
Akron, Ohio
Once again, buy the regular Harland Sharps and race for many years w/o even having to worry about your rocker arms.
Re: 440 source roller rockers [Re: Cab_Burge] #1357059
12/23/12 08:51 PM
12/23/12 08:51 PM
MR_P_BODY Offline
MR_P_BODY  Offline
I used those Crane rockers for years with ZERO problems
and ran 8000 RPM with 720 psi open(those were the
rockers MP sold for many heads... I used them on my W-2s)
Re: 440 source roller rockers [Re: 67Satty] #1357060
12/23/12 09:17 PM
12/23/12 09:17 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
I have been told one can only have an opinion if they have actually bought a set and had them fail, destroying their engine ... but I am happy to report the good part is the source will replace the failed rocker
Re: 440 source roller rockers [Re: Dean_Kuzluzski] #1357061
12/23/12 09:23 PM
12/23/12 09:23 PM
Mt.Vernon ,Ohio
VernMotor Offline
VernMotor  Offline
Mt.Vernon ,Ohio
So did you call them and ask where your bushing are ? If they are advertise that they are. I would been upset if they did't come that way. I been thinking about buying a set of them.. But this might change my mind.
Re: 440 source roller rockers [Re: MR_P_BODY] #1357062
12/24/12 12:09 AM
12/24/12 12:09 AM
So Cal
Sinitro Offline
Sinitro  Offline
So Cal
The PRW rockers are cheapo..
@ the Long Beach Swap Meet full sets are selling for $125. I guess if one is on a tite budget and driving only street maybe one can get away with them..
Regarding the Crane ductile iron rockers sets sold by Mopar about 5 years ago just before Crane went bankrupt...
Be careful, they had a major quality problem where the valve stem would wear through the rocker contact point due to a faulty hardening process. We had several wear issues and went back to Mopar and Crane engineering and they just gave us the sunshine treatment....
Tossed them in the dumpster, spent the $ and installed Harland Sharps...
If you guys had any idea of how many complaints/returns 440Source gets you would move on to another brand..
Just my $0.02...
Re: 440 source roller rockers [Re: Old School] #1357063
12/24/12 03:42 PM
12/24/12 03:42 PM
Salt Lake City
camastomcat Offline
camastomcat  Offline
Salt Lake City
Exactly, why do they? With he amount of cash to build a decent power plant, it doesn't make any sense at all to use the cheap sht, yet they do. Some think it's OK for a street motor but that application has the most cycles. It's just that, junk. JMO
Re: 440 source roller rockers [Re: camastomcat] #1357064
12/24/12 04:30 PM
12/24/12 04:30 PM
communist bloc of new jersey
jamesc Offline
jamesc  Offline
the sad thing is if there was no demand there would be no supply. cranks and rods are one thing, rockers...no way. never time to do it right but always time to do it over, same with the quality of parts
Re: 440 source roller rockers [Re: jamesc] #1357065
12/24/12 07:12 PM
12/24/12 07:12 PM
Worst Weather USA
493_DART Offline
493_DART  Offline
Worst Weather USA
If you cant quite afford the Harlands...the next step would be Dove or Hughes . I ran used Doves for several years with now problem and I "think" they still make them in Ohio ?
Either one is around $425 last time I looked.
Page 1 of 3 1 2 3
