Tire treatment? #1356987
12/22/12 12:08 PM
12/22/12 12:08 PM
South Park, Pa.
68LAR Offline OP
68LAR  Offline OP
South Park, Pa.
Do any of you guys use tire treatments and if so what do you use and why?
4 speed street legal. Best time 10.99 @ 124 mph on 93 octane pump gas @ 3926# total weight
Re: Tire treatment? [Re: 68LAR] #1356988
12/22/12 12:26 PM
12/22/12 12:26 PM
Ambridge, Pa.
rickraw Offline
rickraw  Offline
Ambridge, Pa.
i tried endust. makes tires look clean & natural.
Re: Tire treatment? [Re: 68LAR] #1356989
12/22/12 12:59 PM
12/22/12 12:59 PM
New Hampshire, USA
O
oldiron Offline
oldiron  Offline
O
New Hampshire, USA
Hey Merry Christmas to you!
Back when I was in school I worked at a typrwriter shop (getting old huh). We cleaned the platens (rubber roller) with a chemical called FEDRON. What it did to the rubber was amazing. It cleaned and softened it and looked new. It did not coat it. I've used it on wiper blades and it worked great. Was planning on getting some to try it on the tires.
http://www.teeveesupply.com/product_pages/chemicals/fedron.htm
I suspect that you don't want to drink this.
66 Belvedere Vert, 4 Speed/Jerico, slowly, very slowly, getting faster - NA LD Wedge
New New Best: 10.56 @129
68 B'cuda 4 gear Jerico - Another New Best of 9.86 & Trying to slow up
https://www.youtube.com/watch?v=T4jDLKwd9Gs
Re: Tire treatment? [Re: rickraw] #1356990
12/22/12 01:48 PM
12/22/12 01:48 PM
South Park, Pa.
68LAR Offline OP
68LAR  Offline OP
South Park, Pa.
i tried endust.
I tried Pledge, but this isn't what I was wanting the treatment for. I just bought a set of used slicks and they look and feel "hard". I have used Formula V to treat the tread area in the past. I'm out of it now and need to buy some more. Looking for suggestions on other products, if any.
Merry Christmas to you.
I looked on their web site. They only seem to sell it in small quantities. I wonder how much would be needed to do 2 tires? I'm actually looking for something to soften the tread area of the slicks, not really concerned about cleaning them.
Re: Tire treatment? [Re: 68LAR] #1356991
12/22/12 02:08 PM
12/22/12 02:08 PM
Az
Crizila Offline
Crizila  Offline
Az
Formula V is what I've been using also. I start using it when the tires are a couple of years old or more, but still have some rubber left on them. Usually give them 3 coats the day proir to going to the track. Works pretty good to get the last bit of use out of them.
Fastest 300
Re: Tire treatment? [Re: Crizila] #1356992
12/22/12 02:16 PM
12/22/12 02:16 PM
PA
moparacer Offline
moparacer  Offline
PA
I always use WD40 to soften up a set of old slicks.
67 Barracuda street/bracket car 11.27-119
68 Dart 502 BB 8.70s-152
414 cid SB Dragster 7.65-174
Re: Tire treatment? [Re: moparacer] #1356993
12/22/12 02:37 PM
12/22/12 02:37 PM
South Park, Pa.
68LAR Offline OP
68LAR  Offline OP
South Park, Pa.
Really????????
Re: Tire treatment? [Re: 68LAR] #1356994
12/22/12 02:53 PM
12/22/12 02:53 PM
New Hampshire, USA
O
oldiron Offline
oldiron  Offline
O
New Hampshire, USA
I think 8 or 16 oz would do a set of tires. Its been a lond time since working with it, but a little went a long way. It definately softened the rubber. The platens would get hard as a rock on the surface because of constantly being beat by the typing bars. You could not push your fingernail into it. We would wet it with the fedron and lightly (very lightly) sand it. You could then push your fingernail into it.
Hope this helps.
Re: Tire treatment? [Re: moparacer] #1356995
12/22/12 03:23 PM
12/22/12 03:23 PM
Lubbock,TX
DavidDean Offline
DavidDean  Offline
Lubbock,TX
I thought it was crazy. We've sprayed it on wipe it off between rounds the car picked up almost .05. Its an old trick but works well.
Re: Tire treatment? [Re: DavidDean] #1356996
12/22/12 06:23 PM
12/22/12 06:23 PM
corpus christi tex
Cheatham Offline
Cheatham  Offline
corpus christi tex
Trac Tac has a few diff products for dirt or asphalt tires check them out they have alot of good info, Track Claw is good also, age and heat cycles remove the oils from the tire. i dont think ppl pay as much attention to the tires as they should, they are the first contact on the track that make the suspension do its job
Re: Tire treatment? [Re: DavidDean] #1356997
12/22/12 06:54 PM
12/22/12 06:54 PM
PA
moparacer Offline
moparacer  Offline
PA
I always put a couple heavy coats on the night before and I dont wipe it off either but I have seen some guys do it awhile before they make a pass.
Amazing what it does to a old pair of slicks.
Re: Tire treatment? [Re: 68LAR] #1356998
12/22/12 07:02 PM
12/22/12 07:02 PM
South East VA
Joel71 Offline
Joel71  Offline
South East VA
Purple Power or Castrol Super clean. I took a brand new set of oval track tires, knocked the new off with a wood file then washed the tread with purple power. It made them as sticky as my set of MT drag radials.
Re: Tire treatment? [Re: 68LAR] #1356999
12/22/12 07:24 PM
12/22/12 07:24 PM
MYRTLE BEACH SOUTH CAROLINA
E
ek3 Offline
ek3  Offline
E
track tac.. use grape and sand the surface with an 80 grit pad to open it up before treating. treat 2-3 times and you will see/feel the effect .. they will be soft and bite hard. a small burnout will really make this pay off huge.. be ready to fix broken parts!
Re: Tire treatment? [Re: DavidDean] #1357000
12/22/12 09:02 PM
12/22/12 09:02 PM
South Park, Pa.
68LAR Offline OP
68LAR  Offline OP
South Park, Pa.
I'm really intrigued about this WD40 thing, mainly because it can be had for allot less money than the other stuff. If I decide to use it, is it necessary to applied it before every race or does it last awhile?
Re: Tire treatment? [Re: 68LAR] #1357001
12/23/12 09:46 PM
12/23/12 09:46 PM
corpus christi tex
Cheatham Offline
Cheatham  Offline
corpus christi tex
Creosote, thinner mixed with marvel mystery oil, tranny fluid mixed with thinner, all kinds of cheap home brews, Creosote is real potent if you can get it, ever hear of goat pee? or better than goat piss? lots of tire preps out there.
Re: Tire treatment? [Re: Cheatham] #1357002
12/23/12 10:08 PM
12/23/12 10:08 PM
Mt.Vernon ,Ohio
VernMotor Offline
Happy Birthday VernMotor  Offline
Mt.Vernon ,Ohio
WD-40 works and works well. after you spay it on wrap them in plastic wrap. done it for years.
