Re: Rr St firewall rule? Rr Seat w/roll bar? Battery?
[Re: Sixpak]
#1356337
12/20/12 04:48 PM
12/20/12 04:48 PM
Posts: 2,586 Illinois, Indiana, Louisiana
ProStDodge
Yes, if you move the battery to the trunk, there needs to be a metal firewall (includes package tray area), unless the battery is in a sealed (NHRA Approved) battery box. Also the battery hold downs should be attached to tabs off the frame rail or through the frame rail, not just through the trunk floor. Quote:
8:1 BATTERIES All batteries must be securely mounted; must be of sufficient capacity to start vehicle at any time. Batteries may not be relocated into the driver or passenger compartments. Rear firewall of .024-inch steel or .032-inch aluminum (including package tray) required when battery is relocated in trunk. In lieu of rear firewall, battery may be located in a sealed .024-inch steel, .032-inch aluminum, or NHRA-accepted poly box. If sealed box is used in lieu of rear firewall, box may not be used to secure battery and must be vented outside of body. Relocated battery(s) must be fastened to frame or frame structure with a minimum of two 3/8-inch-diameter bolts. OEM located batteries without complete OEM hold-down hardware must be secured to OEM battery box/tray using the same 3/8-inch diameter bolt hold-down method described in previous sentence. (“J” hooks prohibited or must have open end welded shut.) Metal battery hold-down straps mandatory. Strapping tape prohibited. A maximum of two automobile batteries, or 150 pounds combined maximum weight (unless otherwise specified in Class Requirements), is permitted. Maximums may vary according to Class Requirements.
Also a battery disconnect switch needs to be mount on the back of the car to disconnect the + side of the battery from the electrical system.
Most newer batteries are not really affected by hard launches, particularly any dry cell unit. I have always placed the posts parallel with the tail panel to reduce the possibility of the plates shifting backward and shorting, however I have NEVER heard of this happening.
You didn't mention what rear suspension you have. With leaf springs I would run the back braces to the point in the frame the rear shackles mount to, which would be near the tail panel.
On a coil-over car I would terminate about halfway between the tail panel and the shock mount bar, with a support tube down from the brace to the shock mount tube.
Sorry your on your own on the back seat, there is no "easy" way! The good news is you can cut some of the seat supports out since no one will be sitting back there.
[Re: ProStDodge]
#1356338
12/20/12 04:56 PM
12/20/12 04:56 PM
Posts: 632 Casco, MI
Savoy1964
Casco, MI
NHRA rulebook for 7.50 or slower says .024 inch steel or .032 aluminum. Bulkhead must isolate driver compartment from trunk. Doesn't say how to mount it.
Fireproof caulking
2003 Dodge 3500 Diesel
1964 Plymouth Savoy White 2dr sdn. 512 stroked, Dominator, New Best 9.75 @ 138.50mph 2019 Challenger Scat Pack 1320 White Knuckle-K&N Cold air filter, Billit Oil catch can, drag radials stock 11.911 @ 114mph
[Re: dOoC]
#1356340
12/20/12 06:24 PM
12/20/12 06:24 PM
ProStDodge
How about another firewall Q ? .... a engine - with severe setback.
Doc - not sure what you are looking for, but here is the general regs firewall section
7:4 FIREWALL Each car in competition must be equipped with a minimum .032-inch aluminum or .024-inch steel firewall, extending from side to side of the body and from the top of the engine compartment’s upper seal (hood, cowl, or deck) to the bottom of the floor and/or belly pan. Firewall must provide a bulkhead between the engine and/or fuel tank and driver compartment. All holes in firewall must be sealed with aluminum or steel. In certain instances, fiberglass, carbon fiber, or other composites may be used. See Class Requirements or consult NHRA. Use of magnesium prohibited.
HOWEVER - the kicker is IF you "alter" the OEM firewall, or floor pan, a Roll CAGE is needed for 11.00 (6.99) and faster instead of a roll bar.
Roll cage mandatory in cars running 10.99 (*6.99) or quicker or any car exceeding 135 mph. In full-bodied cars, with unaltered firewall, floor, and body (from firewall rearward, wheeltubs permitted), running between 10.00 (*6.40) and 10.99 (*6.99), roll bar permitted in place of roll cage. In convertibles running 10.99 or quicker or exceeding 135 mph, roll cage mandatory.
[Re: ProStDodge]
#1356341
12/20/12 06:35 PM
12/20/12 06:35 PM
Posts: 30,451 Florida STAYcation
dOoC
The village idiot's idiot
Florida STAYcation
THX for the rule-book info/quote Pro-uN !
The severe engine set-back I am talking about is the Caravan project ... putting the RB engine in where the regular front seat driver and passemger is ...and then drive-it from the second-set of seats in the rear.
Have to build a special dog-house with cover. Small round or square tubing with two layers of 032 alum on either side of the tubing with some foam insulation inside ? ..
[Re: Savoy1964]
#1356342
12/20/12 06:40 PM
12/20/12 06:40 PM
ProStDodge
Fireproof caulking
First, this is ONLY required if the battery or fuel cell has been relocated to the trunk. And, as mentioned the posts above, if only the battery is in the trunk, a sealed battery box can be used in place of a firewall.
Mounting of the rear firewall is open to the car owner, as long as it is not with zip ties or hose clamps!
Screws or welding is preferred.
There NO requirement for fireproof caulking, but any gaps around items passing through (i.e. roll bar) should be minimal. Metal patches can be used to cover holes (NOT duct tape!).
I would agree that the fireproof caulk is a good added measure, but it not required. Might be good for an extra pat-on-the-back from the tech guy!
Scott NHRA D-3 "silver" tech
[Re: dOoC]
#1356343
12/20/12 07:05 PM
12/20/12 07:05 PM
ProStDodge
The rule due NOT require two layers of metal on the doghouse cover. But there is a difference in which fire suit/gloves/shoes the driver must wear if aluminum is used, depending on speed and if power adders or alcohol fuel is used.
And while not in the rule book, I highly advise against any foam sound deadener. Burning plastic foam is similar to Napalm.
Depending on how you configure the engine cowling, it may be difficult to pass tech with a motor relocated into the drivers compartment.
Again depending on how it is built, it may need to be classified as an exhibition vehicle.
I know this guy was having issues a few years back.
Scott
[Re: ProStDodge]
#1356344
12/20/12 07:56 PM
12/20/12 07:56 PM
dOoC
Florida STAYcation
Scott
The two-layer idea is just my thought from a heat and sound issue. If alum is a problem .. then I would stick to steel... ISN'T there a foam-type insulation material that is considered "fire-proof"?
Configuring the cowling (doghouse) ?
That chopped top Caravan ? ... I talked to one guy that had worked on it with the owner .... THAT ONE had a solid-mount rear axle and the driver sat IN FRONT of the engine. IIRC .. he ran it in Bracket 1 ... 11.50 or so.
ALL I want is a driver .. that will surprise a few Corvettes and Mustangs ... and I honestly prefer keeping the top OEM.
What issues did you hear he had?
[Re: dOoC]
#1356345
12/21/12 04:02 AM
12/21/12 04:02 AM
ProStDodge
Doc, With that many major chassis/frame modifications, I think it will be hard to convince a local track tech to "approve" it for racing. Even if you only wanted to run 11.50's I would not approve it without a chassis sticker already in place. You want to drive it? from the back seat? I can't believe any local law enforcement would let it around the block without questioning it. Sorry, way too "different" for me to give any approval or even an indication of what would be needed with just an internet description. Interesting idea - just not sure about how to qualify it. Scott
[Re: dOoC]
#1356347
12/21/12 09:17 PM
12/21/12 09:17 PM
Posts: 1,751 Graham, WA
Polarapete
Graham, WA
I think the best answer is to contact the NHRA or IHRA tech department directly and pose your question with as much detail as you can. In the back of National Dragster is a list of the Divisional offices with phone numbers for the tech directors, since the rules are always evolving it is best to get the latest thinking and preferably in writing. I am doing a similar project where I am mounting a fuel cell below the floor in my 2wd Ramcharger and need to cut a hatch in the existing floor to fill the cell. I am recuperating from surgery and I am not ready to actually do it, but I am doing a lot of planning and measuring first. Good luck with your project.
1986 Dodge Ramcharger 440 2wd, Bracket Racer Under Construction 1998 Ram 2500 QuadCab, new daily driver. 2008 Honda Element 2014 Carry-On 7x14 Cargo Trailer
[Re: dOoC]
#1356348
12/22/12 06:05 AM
12/22/12 06:05 AM
ProStDodge
So you seem quite familiar with drag-strip-tech ... ?
You could say that.
I have been a member of the NHRA Division 3 Safety Certification team for 3 years as a tech for the Lucas Oil Divisional Races Series, as well as the Jegs Super-Quick series.
I worked the Staging areas for 4 NHRA National events last year, including the U.S. Nationals.
I was track announcer at Indianapolis Raceway Park for two years, and I am still the announcer for the Monster Mopar races.
I was also recently named as the Tech Director for the NADM (Diesel Motorsports).
Here's a picture. I am the one in the black hat.
