What carb for a street / strip 451?
#1356310
12/20/12 02:04 PM
12/20/12 02:04 PM
Posts: 4,319 Puyallup, WA
StealthWedge67
Puyallup, WA
I'm contemplating a new carb this winter. I've been running an older 830 cfm "race" series carb, list #4788-1. I'm contemplating a Holley Street-HP 950 (#82951). What would you guys look to as the best option for my car? -451 low deck @ 10.3:1 -RPM manifold -Stealth heads -252* / .573 lift solid FT cam -1-7/8" headers -Primarily street driven, with 3 or 4 trips to the track per year.
Re: What carb for a street / strip 451?
[Re: 1967Valiant]
#1356314
12/20/12 06:56 PM
12/20/12 06:56 PM
Posts: 3,698 NE Oklahoma
Von
NE Oklahoma
4781 DP ought to work well...
IM experince the idle circuit on a 950HP is super fat, on a motor similar to yours. But, Dwayne did tell me that the Street HP carbs do have a lot cleaner idle circuit, more suited to a BB Mope.
72 RR, Pump gas 440, 452s, 3800 lbs, Corked, ET Radials,. 11.33@117.72.
Same car, bone stock 346s, 9.5 comp, baby solid. 12.24@110.
[Re: 1967Valiant]
#1356315
12/20/12 07:26 PM
12/20/12 07:26 PM
StealthWedge67
Puyallup, WA
The 4788 is a downleg booster carb. I run 3.91's with 27-1/2" tall tires and a 9-1/2" Dynamic converter.
If you guys think I won't gain anything over the the 830, then I can find somewhere else to spend the money. I just figured it would go a little faster with the bigger carb, and the street HP version should offer good street manners (??).
[Re: StealthWedge67]
#1356318
12/21/12 12:02 AM
12/21/12 12:02 AM
Posts: 52,972 Romeo MI
MR_P_BODY
I would think that engine could use one of the new Holley 950... from what I've heard they flow real good.... the new 850 would be another choice
