pics of the new bullet #1356042
12/19/12 10:30 PM
12/19/12 10:30 PM
North Carolina
Mopar dragster Offline OP
North Carolina
Here are some pics of my new engine. It is a 454 low deck stroker based of a 400 block that has been zero decked and filled. It has Eagle rods, Eagle crank, Ross pistons, and a Milodon oil system. it has Stealth heads that have been ported, polished, and milled to make the chambers 62 cc's. It has an Eddy Victor 383 intake that was also ported and an alky Dominator. Full roller. Going into a 225" dragster. Any ET guesses?
Please see my brother Darrell Kiger at Wyo Racing and Rods for all of your drag car fabrication and restoration needs. From Pro Mod to concours restorations, he is the man. (336)463-4309.
Re: pics of the new bullet [Re: Mopar dragster] #1356043
12/19/12 10:45 PM
12/19/12 10:45 PM
Highland beach Fl
P
poisondart2 Offline
poisondart2  Offline
P
Highland beach Fl
Re: pics of the new bullet [Re: poisondart2] #1356044
12/19/12 10:50 PM
12/19/12 10:50 PM
North Carolina
North Carolina
[Email]8.40@159[/Email]
Running eighth mile, but I like where your heads at.
Re: pics of the new bullet [Re: Mopar dragster] #1356045
12/19/12 11:02 PM
12/19/12 11:02 PM
Highland beach Fl
P
poisondart2 Offline
poisondart2  Offline
P
Highland beach Fl
OK 5.34@125 ? Hardtail?
Re: pics of the new bullet [Re: poisondart2] #1356046
12/19/12 11:07 PM
12/19/12 11:07 PM
communist bloc of new jersey
jamesc Offline
jamesc  Offline
depending on the weight of the car it should run O's or teens at >160 in the 1/4 or 5teens in the 1/8
Re: pics of the new bullet [Re: poisondart2] #1356047
12/19/12 11:13 PM
12/19/12 11:13 PM
North Carolina
North Carolina
OK [Email]5.34@125[/Email] ? Hardtail?
Swingarm suspended car. My mind says it will run 5.0's. my gut says 5.teens. Just so it's consistent I,really don't care though.
Re: pics of the new bullet [Re: Mopar dragster] #1356048
12/19/12 11:20 PM
12/19/12 11:20 PM
Highland beach Fl
P
poisondart2 Offline
poisondart2  Offline
P
Highland beach Fl
So it's around 1600LBS ? 550HP ?
Re: pics of the new bullet [Re: poisondart2] #1356049
12/19/12 11:33 PM
12/19/12 11:33 PM
North Carolina
North Carolina
Weight should be close. HP should be in between 550 and 600, but who knows.
Re: pics of the new bullet [Re: poisondart2] #1356050
12/19/12 11:34 PM
12/19/12 11:34 PM
jamesc Offline
jamesc  Offline
i would think it's heavier and should have 650ish minimum. if it's not real heavy and runs good 5.0s isn't out of the question
Re: pics of the new bullet [Re: jamesc] #1356051
12/19/12 11:36 PM
12/19/12 11:36 PM
jamesc Offline
jamesc  Offline
1600# suspended car is pretty lite u ever weigh it? don't know much about the heads but if that engine doesn't make >600 somethings wrong with it
Re: pics of the new bullet [Re: jamesc] #1356052
12/19/12 11:43 PM
12/19/12 11:43 PM
Highland beach Fl
P
poisondart2 Offline
poisondart2  Offline
P
Highland beach Fl
Yeah I dont see 650 ? But I figured it was going to be light. 650ish I dont know about ? But if it does a fun ride for sure
Re: pics of the new bullet [Re: jamesc] #1356053
12/19/12 11:43 PM
12/19/12 11:43 PM
North Carolina
North Carolina
All guesses on my part. Never weighed it. I will when final assembly is complete. Just hope it's consistent if nothing else. It is built to not be hard on parts hopefully. .650 roller cam so it's not too,aggressive.
Re: pics of the new bullet [Re: Mopar dragster] #1356054
12/19/12 11:55 PM
12/19/12 11:55 PM
Highland beach Fl
P
poisondart2 Offline
poisondart2  Offline
P
Highland beach Fl
Did your brother build it ? Lets see a photo
Re: pics of the new bullet [Re: poisondart2] #1356055
12/20/12 12:01 AM
12/20/12 12:01 AM
North Carolina
North Carolina
Most recent pics I have. It is on the ground now being wired. Tommy Mauney built the car originally. My brother put the swing arm suspension on the back and updated the chassis.
Re: pics of the new bullet [Re: Mopar dragster] #1356056
12/20/12 12:16 AM
12/20/12 12:16 AM
Highland beach Fl
P
poisondart2 Offline
poisondart2  Offline
P
Highland beach Fl
Looks Great Can you loan me your brother?
Re: pics of the new bullet [Re: poisondart2] #1356057
12/20/12 10:54 AM
12/20/12 10:54 AM
jamesc Offline
jamesc  Offline
650 might be a little on the high side but i would expect >600 for sure. the engine in my car is similar 451, eheads, 11.5:1 cr, hp950 on gas, m1 single plane, 275°/.575ft cam. you have more cam, cr, carb and on alky those things should make more hp for sure. last time i weighed my car it was around 1575 without driver. some things have changed but the weight should be close. i figure minimum of 1750-1800 on the starting line and it regularly runs 160 which i figure would equate to around 600hp
