BEST SHOT on a 4.15 crank ..?? #1355632
12/19/12 08:44 PM
12/19/12 08:44 PM
Florida STAYcation
dOoC Offline OP
The village idiot's idiot
dOoC  Offline OP
Florida STAYcation
...as far as quality and price ? ....any thoughts of a group-buy ?
Re: BEST SHOT on a 4.15 crank ..?? [Re: dOoC] #1355633
12/19/12 09:42 PM
12/19/12 09:42 PM
florida dade
cesar perez Offline
cesar perez  Offline
florida dade
ohio crankshaft or 440 source
Re: BEST SHOT on a 4.15 crank ..?? [Re: cesar perez] #1355634
12/19/12 11:17 PM
12/19/12 11:17 PM
Chilliwack B.C. Canada
RUNCHARGER Offline
RUNCHARGER  Offline
Re: BEST SHOT on a 4.15 crank ..?? [Re: RUNCHARGER] #1355635
12/20/12 02:31 AM
12/20/12 02:31 AM
Tucson, Arizona
MRMOPAR Offline
MRMOPAR  Offline
Tucson, Arizona
http://chucker54.stores.yahoo.net/440426he4st6.html
Interesting ...
Rod & Main journal: -.010" undersize.
68 RR 528" INDY MAXX 07 2500 CTD Southwest International Raceway - IHRA - Tucson, AZ
Re: BEST SHOT on a 4.15 crank ..?? [Re: MRMOPAR] #1355636
12/20/12 12:05 PM
12/20/12 12:05 PM
dogdays Offline
dogdays  Offline
OF COURSE it's a "blem" crank, nothing in the world wrong with being 10 under, except if you already have bearings at standard size and can't afford new ones. But, iff you can't afford bearings you can't afford the $700+ that a perfect new crank would bring.
R.
Re: BEST SHOT on a 4.15 crank ..?? [Re: dogdays] #1355637
12/20/12 02:06 PM
12/20/12 02:06 PM
Florida STAYcation
dOoC Offline OP
dOoC  Offline OP
Florida STAYcation
a 10/10 crank ?.... not a bad-thing .. less bearing area - LESS drag/friction ! ....
A couple of other Q's ... are some of these PREbalanced ? ... how about the ones that have the OVERLYaggressive knurling on the rear main seal area(that tears-up the seal itself).
Re: BEST SHOT on a 4.15 crank ..?? [Re: dOoC] #1355638
12/20/12 07:01 PM
12/20/12 07:01 PM
MR_P_BODY Offline
MR_P_BODY  Offline
I have a Callies 4.15 for sale... its turned down to
chevy rod journals with 440 mains... the fly weights
are turned down also to move the weight in closer
to centerline.... its new... never put in a engine
Re: BEST SHOT on a 4.15 crank ..?? [Re: MR_P_BODY] #1355639
12/21/12 01:30 PM
12/21/12 01:30 PM
Florida STAYcation
dOoC Offline OP
dOoC  Offline OP
Florida STAYcation
P-guy .... will those Chebbie-rod combo work with a 1.09 pin? -(stocker type OEM pistons ....cast or forged) .. how will that balance-up? ..
NO OTHER interest ? ... or is this just old-school stuff now? ..
Re: BEST SHOT on a 4.15 crank ..?? [Re: dOoC] #1355640
12/21/12 03:21 PM
12/21/12 03:21 PM
Eighty Four, PA
B G Racing Offline
B G Racing  Offline
Eighty Four, PA
We have a few good used 4.15 cranks out in the shop.
Re: BEST SHOT on a 4.15 crank ..?? [Re: B G Racing] #1355641
12/21/12 03:28 PM
12/21/12 03:28 PM
Florida STAYcation
dOoC Offline OP
dOoC  Offline OP
Florida STAYcation
Hay BG ....R U anywhere close to I-80 ? ...I am headed that way in a couple of days ...on my way to MA.
Re: BEST SHOT on a 4.15 crank ..?? [Re: dOoC] #1355642
12/21/12 03:31 PM
12/21/12 03:31 PM
Eighty Four, PA
B G Racing Offline
B G Racing  Offline
Eighty Four, PA
A little over 1 hour south of I-80.Just of I-79,20 miles south of Pittsburgh.
Re: BEST SHOT on a 4.15 crank ..?? [Re: B G Racing] #1355643
12/21/12 04:40 PM
12/21/12 04:40 PM
Florida STAYcation
dOoC Offline OP
dOoC  Offline OP
Florida STAYcation
Hay BG ..... email me at drtq2@yahoo.com ... my PM's aren't working and my MF email is not either ... probably because of my lousy dial-up ISP.
I looked on a map .. is 28 a good road heading back up-to 80 ?
