Re: 383 timing issues
[Re: Beep Beep]
#135545
10/12/08 09:43 PM
10/12/08 09:43 PM
Posts: 5,314 Carstairs, Alberta, Canada
dave571
You need to shorten the advance slots to match your set up. On the mp dist there is a torx headed set screw that locks the adjuster on the slots. You can reach through the plate, and loosen it, then shorten the slots, and lock it down again. To make it come in quicker, you need to put lighter springs in it. IMHO when you start wiht a high initial (which is a good thing) you don;t need to bring it in quite as fast. I would try shortening the slot for the max you want, then see how it performs before you mess with the springs
[Re: Beep Beep]
#135546
10/12/08 09:55 PM
10/12/08 09:55 PM
RapidRobert
You for sure don't want it to be pinging. I would put the initial back to 20 & with 37 total you are very close to ideal then you could add your vac adv back in & tailor it.
[Re: Beep Beep]
#135549
10/12/08 10:21 PM
10/12/08 10:21 PM
RapidRobert
the spring tension & or the amt of mechanical adv(slot length) would be different between the two. If 20 gave you 37(& no ping ) I would bump the initial up a degree & if the total is 38( which is a good baseline for a BB) & stay there & play with some lighter springs if you wanted the curve in quicker. EDIT your snap on(w dial back) light is good. the fluctuating marks at higher rpm is either the tchain and or needs one of these on the end of the dist shaft to keep the dist tang from moving back & forth in the slot in the top of the intermediate shaft. check how much play yours has by grabbing the rotor & moving the shaft back & forth, not enough to move the weights out against the springs but enough to see how much slop there is where the tang sets onto the slot.
[Re: dave571]
#135551
10/13/08 02:03 AM
10/13/08 02:03 AM
Probably the reason the MP pinged at slightly less total is because the MP probably advanced quicker (weaker springs) than the Mopar.
In theory, distros are pretty simple. If you imagine there is NO mechanical OR vacuum, the base timing is what you set.
The mechanical varies with engine speed, the strenth of the springs, to set the RATE of advance, and the slots that limit the travel sets how FAR (degrees) the advance.
Same deal with vacuum. Some are adjustable. How far they move is the amount (degrees) and whatever internal springs--and whatever vacuum is available at the carb--determines how "fast."
So if you put in lighter springs, and the advance comes in "too much too soon" you might ping at less total.
One suggestion I ALWAYS make is to degree the damper using a "positive stop" so you KNOW where the marks are. This also avoids the need for a delay timing light---I've seen a few that were not accurate, or became inaccurate after being banged around somewhat.
