Re: Whats your thoughts on a start retard box?
[Re: dartman366]
#1355376
12/19/12 09:52 AM
12/19/12 09:52 AM
Posts: 1,301 Penna
70satelliteguy
Penna
"I put one on mine because the timing is locked at 35 degrees because of the crank trigger and 13.0 to 1 compression, have never had a kick back problem." I love mine! Solved all of my starting problems,especially in the staging lanes with the motor warm. Mike
[Re: 70satelliteguy]
#1355377
12/19/12 10:44 AM
12/19/12 10:44 AM
Posts: 4,330 Lynchburg, VA
Leon441
Lynchburg, VA
Get one that is adjustable. This way you are not stuck with a default setting like some of the boxes. Some are 20 and some are 25. I usually do 15-20 depending on what the engine likes.
[Re: Leon441]
#1355378
12/19/12 02:11 PM
12/19/12 02:11 PM
Posts: 1,613 Deerfield, Ohio
70dusterjohn
Deerfield, Ohio
Thats what we ended up using... Its great and worth every penny...
[Re: 70dusterjohn]
#1355379
12/19/12 02:28 PM
12/19/12 02:28 PM
Posts: 7,506 Az
Crizila
Az
I just went with light springs a a very short curve in my dist. At cranking rpm, I'm at about 18-20 degrees advance. When it fires and at about 1200-1500 rpm, it's all in.
Fastest 300
[Re: Al_Alguire]
#1355382
12/19/12 08:30 PM
12/19/12 08:30 PM
Posts: 240 Shingle Springs Ca
haddixj
Shingle Springs Ca
I have been fighting mine on occasion and I have now ended up going back to light springs and no start retard, motor likes it better and the timing is all in by 2400 rpm. less then I leave the line at. My motor is on methanol also so it is hard to start when its cold.
70 duster 25.1E,73 barracuda, 70 gran coupe, 71 cuda
[Re: CHAPPER]
#1355384
12/19/12 11:57 PM
12/19/12 11:57 PM
70dusterjohn
Deerfield, Ohio
Never used one never had an issue. Seperate ignition and start buttons like most switch panels use will work wonders. Get the motor spinning before you hit the ignition and there will be no problem. Just my
Also, just one thought....might check with SSR and see how he started his rig with 50-60-70* or whatever timing he was running!
Now that is some funny sh@# there.... But for the cars that are using the stock ignition the retard is the best way to go...
[Re: pleasantk]
#1355387
12/20/12 12:43 AM
12/20/12 12:43 AM
Posts: 369 California, USA!!!
WheelsUp73
California, USA!!!
Not sure what distributor you are running, but I was having similar problems with my MSD. Motor ran best locked out but kicked back on hot starts. Ended up using one light spring only. When cranking engine is retarded and when it fires, it is all in at idle. No more kick back and locked from idle on up. Best of both world. Ran it about 1000 miles on it that way this summer and raced it several times at the track as well. Best part is it didnt cost me anything and does essentially what the box does.
I set up my Pontiac the same way as above. Even when I had a retard box hooked up it would kick back once in about every 15 starts or so. And then one day it kicked back and pruned some teeth off the ring gear . My friend who runs B Gas starts his car in the same manner as Al does. See ya at the races.
[Re: Jeepmon]
#1355389
12/20/12 01:51 AM
12/20/12 01:51 AM
Posts: 19,369 Las Vegas
Al_Alguire
Las Vegas
The Camaro used to have a start retard on it and broke three ring gears with it on. Locked out at 36 degrees, uses a stock ignition switch and key. On occasion it gets grumpy when hot but has never broken anything do we deal with it.
[Re: Al_Alguire]
#1355390
12/20/12 01:19 PM
12/20/12 01:19 PM
Posts: 8,094 Sunnyvale, CA
Jeepmon
Sunnyvale, CA
So are you saying that even with a Start Retard, I'll get kickbacks with -20 degrees of timing?
[Re: Jeepmon]
#1355391
12/20/12 01:25 PM
12/20/12 01:25 PM
Al_Alguire
Las Vegas
We only had it set for 10, but yes that was the result. Since you are using a racecar it is a moot point IMO. You siply need to get the engine spinning first then switch on the ignition. I have never used a start retard on a race car set up like that. Only tried it on a steet car.
The Camaro had one, still have the box if you want it only used a few times and the Belvedere. On the Belvedere we just recurved the distributor eventually and removed the box. Said box went on Camaro for about three months. After having to pull the trans a couple of times to fix broken teeth on the ring gear we went back to the old way with no retard.
[Re: Al_Alguire]
#1355393
12/20/12 02:47 PM
12/20/12 02:47 PM
Posts: 12,675 Columbia, CT
moper
Columbia, CT
"Seperate ignition and start buttons like most switch panels use will work wonders. Get the motor spinning before you hit the ignition and there will be no problem. " what Al said... BTW - Merry Christmas Don!
