Re: 68 Charger 451 engine build 25 MPG and 515 HP
[Re: Chargervic]
#1355349
12/21/12 08:52 AM
12/21/12 08:52 AM
Posts: 52,972 Romeo MI
MR_P_BODY
Cool... now do me a favor and post up your dyno sheet... I'm trying to compare your numbers thanks
It's all up there already. The post with the flashing red and green Pentastar.
I'm more concerned with the other numbers, fuel, oil temp,egt, and the other things that the dyno would read....I have a engine very close to yours in my 38 and want to compare thanks
[Re: MR_P_BODY]
#1355350
12/21/12 09:23 AM
12/21/12 09:23 AM
Posts: 8,165 Plymouth, MI
Blusmbl
Plymouth, MI
Unrelated from the power discussion, I have to commend you, that is an absolutely beautiful '68. It could have a /6 in there and you should still be proud of that thing!
[Re: MR_P_BODY]
#1355353
12/21/12 10:49 AM
12/21/12 10:49 AM
Posts: 3,300 Northern Indiana
Dunnuck Racing
Northern Indiana
He stated in his post that the numbers for his engine were from Desktop Dyno. He wont have the other info Mr. P
Keith
[Re: MR_P_BODY]
#1355355
12/21/12 01:16 PM
12/21/12 01:16 PM
Posts: 6,562 Downtown Roebuck Ont
Twostick
Still wishing...
Still wishing...
Sounds like he is quoting a chassis dyno. He says the torque # could be skewed because of his converter which certainly makes sense. Was the 496 done on the same dyno? Same heads cam and intake with 40 odd more cubes should make the same numbers, just at a lower RPM. A different dyno might explain the discrepancy. Oh and that Charger is gorgeous. Kevin
[Re: Twostick]
#1355356
12/21/12 01:58 PM
12/21/12 01:58 PM
Posts: 413 Norway (old world)
Oyvind Mopar
Norway (old world)
Hi torque at low rpms is what the auto industry tries to make. And the recipe is long tubes manifold with FI,and free flowing exhaust tuned if possible to low rpms. Good flowing heads make up for the modest cam in the upper rpms. It is much easier for a hobbyist to achieve the high torque in somewhat higher rpms, as ram tuning then does not demand insanely long tubes, and commercial headers are on the spot. This is what makes me wonder how the 600 lbs can be achieved with the described combination at those low rpms. (And do not forget: 500++ lbs down below will also kick butt!!) Is the 2-barrel intake path in the 6-p setup so efficient? This is not criticism, but I am not sure if it is correct. Please allow me to make such a comment, as I struggle for the best results myself (knowing how hard it is to hit correctly), and I am always interested in new-thinking. Maybe the desktop dyno has a black spot down low rpms (like calculating high VE due to "ram tuning")? And, I would really like to get some tips, as I live in a dark side of the world with pumped up gas taxes, and heavily taxed modern cars (but not the old ones!) so making engines this way is somewhat of a target. If, for nothing else, to feel the torque and hear the sweet V8 rumbling.... And, I have been working with Mopars since 1973, but I am not an "expert" (LOL)
[Re: cudaman1969]
#1355363
01/02/13 10:26 AM
01/02/13 10:26 AM
Posts: 24,562 Brookeville, Md
Mr.Yuck
Brookeville, Md
Not what I wanted to hear so i'll go with higher compression and roller cam, thanks
probaby be easier and cheaper with a supercharger. Buy a used or re-manned Chevy/Furd unit off of e-bay modify the main bracket and roll. You can use whatever you have now. You can also use a lower gear 3.55-3.73. Not sure it will match the mpg of a 6-pack but it should get you close to 17hwy.
[Re: cudaman1969]
#1355366
01/02/13 08:52 PM
01/02/13 08:52 PM
Posts: 559 Idaho
LaRoy Engines
Idaho
Camshaft and cylinder heads were the reason it did as well as it did. The 452 heads were flowing in excess of 290 cfm. Later, with 906 heads and the same compression, it was making 694 HP. Both configurations were running on 91 octane. Would it make more with higher compression? Sure!
