Truck Dana 60 Housing #1355029
12/18/12 05:08 PM
12/18/12 05:08 PM
Wheatfield, NY
Cuda340 Offline OP
Cuda340  Offline OP
Wheatfield, NY
Can you use regular 8 3/4 car ends on a Truck Dana 60 housing? I believe the tube diameters are different. Will it cause a welding issue? Or should I purchase a new pair of housing ends to weld on?
Re: Truck Dana 60 Housing [Re: Cuda340] #1355030
12/18/12 09:15 PM
12/18/12 09:15 PM
Harm City Md.
Dan Halen Offline
Dan Halen  Offline
Harm City Md.
I've done it with 8-3/4 axles. You have to check which spline
you have in the Dana though.
Re: Truck Dana 60 Housing [Re: Dan Halen] #1355031
12/18/12 11:38 PM
12/18/12 11:38 PM
Iowa
76dodgeboy Offline
76dodgeboy  Offline
Iowa
He's referring to the axle flange from what I gather. I think he wants to cut it off an 8.75 and weld to a D60 truck axle to make if 5lug. Almost sound easier to just get new flange I would think
Re: Truck Dana 60 Housing [Re: Cuda340] #1355032
12/19/12 12:35 AM
12/19/12 12:35 AM
Chilliwack B.C. Canada
RUNCHARGER Offline
RUNCHARGER  Offline
New ends are cheap and you don't have to carefully clean them up.
Sheldon
Re: Truck Dana 60 Housing [Re: RUNCHARGER] #1355033
12/19/12 12:47 AM
12/19/12 12:47 AM
Redwood City Ca.
B1arno Offline
B1arno  Offline
Redwood City Ca.
I've used truck Danas and welded on new ends to make them 5 lug before. It works out fine. The only difference I know of is there is no pad for a pinion snubber on the truck rear.
Arno
Re: Truck Dana 60 Housing [Re: B1arno] #1355034
12/19/12 12:59 AM
12/19/12 12:59 AM
S.E.Mich
drew72 Offline
drew72  Offline
S.E.Mich
Make sure you have the 3" dia. dana tube. Heavy trucks used a 3.5" tube
Re: Truck Dana 60 Housing [Re: drew72] #1355035
12/19/12 06:03 AM
12/19/12 06:03 AM
Utah and Alaska
astjp2 Offline
astjp2  Offline
Utah and Alaska
There is also a 4" tube used on some duallys. Dutchman will narrow and weld on the new billet ends for 385 shipped. Tim
Re: Truck Dana 60 Housing [Re: astjp2] #1355036
12/20/12 12:16 AM
12/20/12 12:16 AM
State of Confusion
hp383 Offline
Just a normal tag again
hp383  Offline
State of Confusion
That may be because dually's typically use a Dana 70 or 80 depending on the year.
Join the Penguin Liberation Front!!
Stop the Hippo Occupation!
Re: Truck Dana 60 Housing [Re: drew72] #1355037
12/20/12 09:58 AM
12/20/12 09:58 AM
Central Valley, CA.
Quicksilver440 Offline
Central Valley, CA.
Many of the truck housings have 3/8" thick 3.125" diameter axle tubes...which are perfectly fine to use.....also, a set of 8-3/4" ends work fine and are only about $80.
